Author Topic: What did you do to your bike today ?  (Read 3309403 times)
0 Members and 9 Guests are viewing this topic.
Offline Johnie
« Reply #875 on: January 31, 2010, 06:03:50 PM »
Hey Johnie. I noticed aways back you were putting white in the letters of your tank badges.What type-brand of paint did you select.??   I did some with Testors model paint but found it pretty thin and translucent. Had to lay in around 3 coats. Little bottle got better as the fumes worked out and thickened a bit though.
Spanner...I also went to the local hobby house. The guy thought I should try an enamel white which I thought looked pretty crappy after 3 coats. So I removed that and now used Model Master Acryl which flows much better and gives a nice even look to the paint. It is easier to work with too. Cleans up with water vs the thinner needed for the enamel. I have done 3 coats but will do 1 more. It goes on thin, but I think that is why I get a nice even look.
« Last Edit: January 31, 2010, 06:08:49 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #876 on: January 31, 2010, 06:15:46 PM »
Hey, there's nothing wrong with water cooled brakes mate, and rusty brake drums produce a "pitted" friction surface, thus increasing the surface area and creating more friction = better stopping, perfect! I'm off to drill some holes!;D
what if I drilled the drum? :o
http://www.tffn.net/drilldrum.html
« Last Edit: January 31, 2010, 06:17:47 PM by Industrial Cafe »
Offline myhondas
  • Not really such a
« Reply #877 on: January 31, 2010, 07:46:31 PM »
Well, another year has come and the show is over now. Don't think there were as many people this year as last. Probably due to the economy. Still, had a good time and got some good deals on some things I needed. This year I was part of the VJMC display and we had some great bikes there.
And there were some cool deals even if they were a little rough.
 ;D ;D ;D ;D ;D
« Last Edit: January 31, 2010, 08:35:15 PM by myhondas »
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
« Reply #878 on: January 31, 2010, 08:24:19 PM »
today I went to the local auto mechanic...knowing they work on a lot of bikes.  the reason I went is because I am mid-project on my '71 cb750...which is to become a cafe of sorts.  I've stripped it down to the frame and am at the point where I need to mount the battery and electrical components at the tail section.
So i took the raw frame to the shop to talk to the guys there.  i was met by there resident 'bike guy'...  Now I am not the kind of guy to attach any stereotypes based on one's geographic origins...but this guy pulled some hardcore "Euros are better than Americans" bull#$%* on me.
I noticed that every bike in the shop was a Ducati or BMW...  And when the guy caught wind of what I was doing he says with a thick Italian accent.  "I don't understand you Americans with your 'bike building'.  I am Italian and we are very precise.  We do not just...cut here...and weld there."  Bla bla bla...I won't bore you with the rest.
Long story short, I told him to piss off and took my business elsewhere...
Outside of that I separated all the parts that are getting polished...and all that are headed off to the powdercoater.  Its getting close!!
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline 78 k550
« Reply #879 on: January 31, 2010, 09:02:59 PM »
CB650 Terry and I moved the bike around to the garage. Cleaned up a bit and had a good afternoon of kinda chilly weather.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #880 on: February 01, 2010, 03:36:23 AM »
Well I can't see why not mate, don't go overboard and "swiss cheese" it considering that you'll be drilling thru your hub, and you'll probably need a fancy right angle drill to achieve the aim, (unless you're gonna pull your wheel apart?) but I'm sure it's do-able, and I'm interested in the results! ;D
« Reply #881 on: February 01, 2010, 03:42:29 AM »
The F2 that I restored 5 years ago is all back together after it's second engine tear down, it's now got an entire K6 top end installed, but with the F2 cam and carbs. It starts, it runs, it needs some minor adjustments, but all in all, I'm a happy boy. I fitted the seat, airbox, sidecovers and chain, and rode it around my backyard tonight after work, and tomorrow I'll take it for a longer "shakedown" ride, and all going well, I'll post some pics when I get back. Cheers, Terry. ;D
  • Like a well oiled
    • Undead Asphalt
« Reply #882 on: February 01, 2010, 04:48:17 AM »
I'll try my hand at it on a spare hub I have hanging up. I was thinking 21-36  0.25inch holes in a swept pattern between the cooling fins.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #883 on: February 01, 2010, 09:26:47 AM »
Offline Johnie
« Reply #884 on: February 01, 2010, 04:46:57 PM »
K4 - dismantled the gauges today and got the cases ready for paint. Sure did work nice using the paint can opener to pry those rings off as posted earlier by another member. The lenses cleaned up nicely and are prestine using a special plastic polish. The gauge faces have not seen much sun and cleaned up great.
Oshkosh, WI  USA
« Reply #885 on: February 01, 2010, 05:38:30 PM »
Painted the oil pressure gauge housing black for the K0 and put the split K7 engine back together. Temporairly lost the new O rings for the oil pump and called it a day.
« Reply #886 on: February 01, 2010, 05:56:37 PM »
C'mon John, stop dicking around mate, start a K4 resto thread! ;D
Offline Johnie
« Reply #887 on: February 01, 2010, 07:18:24 PM »
I know what you mean Terry. But I am about 75% done now and it just does not pay to start it now. I should have started the K4 resto thread when I started this project in November. I do have a nice picture book though... ;D I have one of those for my KO & K1 too.
Oshkosh, WI  USA
« Reply #888 on: February 01, 2010, 10:47:38 PM »
Fair enough John, but I think everyone here would be happy to just see the pics? Anyhoo, I thought I better take a pic of my F2 while it still looks this nice, because if it keeps dicking me around, I'm gonna set it on fire, ha ha! ;D
« Last Edit: February 02, 2010, 02:02:00 AM by Terry in Australia »
« Reply #889 on: February 01, 2010, 11:05:40 PM »
Nice looking F2 there Terry......
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #890 on: February 01, 2010, 11:13:04 PM »
every single person that has come into my room since the wife brought my laptop to me has gotten an earful about project fuzzycycle, seen the pics and heard all about my second family (you ladies and gents here) 2 things that i'll talk and talk about till you run away in self defense are my kitties and fuzzycyle. they even know why it was called fuzzycycle and why the name fuzzybutt. though the night nurse found that out the hard way when she caught me heading into my bathroom. fortunately for any potential roommate i'm in a single room because then theyd be a captive audience. between my pain meds and the prednisone i talk like i've drank 2 pots of Tim Hortons coffee  ;D almost too bad i'm coming home tomorrow, i like the bed with the mattress that inflates and deflates whenever you move around. i wish i could afford a hospital bed here at home, i'd be happy as hell about that.
Mark Twain - Notebook, 1894
Offline Frankenkit
  • Industrial Strength
« Reply #891 on: February 02, 2010, 12:27:46 AM »
Quote from: Bucky Katt
you know, I actually somehow read that line first, then went back and reread your whole post that way. :D :D :D
Too bad you're not at my hospital, I'd end up talking your ear off about Delilah and Lola, and we'd blow through my whole shift havin' fun!
...wait, maybe that makes it a good thing you're not at my hospital?
;D
Feel better, man... and see if you can sleep?
« Last Edit: February 02, 2010, 12:29:53 AM by Kit »
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
« Reply #892 on: February 02, 2010, 02:06:07 AM »
Thanks Mick, as soon as it's running properly, it's going on EBay! ;D
« Reply #893 on: February 02, 2010, 10:40:49 AM »
Terry,
Can't believe you'd get rid of the best bike you have. Hell, I'd take that any day over that stump pulling Triumph with the Ford Pinto engine you have  ;)
What exhaust is that?
Offline gearhead ed
« Reply #894 on: February 02, 2010, 02:44:42 PM »
That's a very nice F2 that you have there Terry. Who makes the header/muffler?
Thanks
1978 750f    1964 Chrysler 300
Offline scooter1
  • 1973 cb750
« Reply #895 on: February 04, 2010, 05:43:12 PM »
Well I got my tail today ;D ;D ;D ;D and started the install process
« Last Edit: February 04, 2010, 07:03:42 PM by scooter1 »
  • Like a well oiled
    • Undead Asphalt
« Reply #896 on: February 04, 2010, 06:25:36 PM »
I like that tail Scooter, I think VanGo has a similar one.
I made some headlight brackets.
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #897 on: February 04, 2010, 08:20:16 PM »
I got my new ebay helmet today! does that count?
Present: 1978 CB750A, 1978 CB400A, 1983 Nighthawk 550, 1984 CM250C
Past: 1977 XL100, 1982 KZ1300
  • Like a well oiled
    • Undead Asphalt
« Reply #898 on: February 04, 2010, 08:23:10 PM »
cool helmet
Offline Frankenkit
« Reply #899 on: February 05, 2010, 12:24:58 AM »
I spent a number of hours in the garage remembering how much I hate old aluminum and stripped threads.  yay!
On the plus side, Lola now has her newly rewired control pods on, new clutch and throttle cable, refurb'd brake cable...
« Last Edit: February 05, 2010, 12:29:17 AM by Kit »
1973 CL350- Lola?
Stuff for sale
