Author Topic: What did you do to your bike today ?  (Read 3779291 times)
0 Members and 61 Guests are viewing this topic.
« Reply #9075 on: January 29, 2012, 01:54:03 PM »
Steve-o, Nice upper triple and clamp.  Keeping it that way in and around the bar mounts are small pita but can be done.  I deal with that.
On the ignition thing, is the frame similar to the 750 up in that area?  I dunno, me thinkin' it is not.  Prolly can't mount it the same.  Can you move it a bit lower down the frame and turn it around to the back side of the frame to get in somewhat the same location as the 750?
Tews - The upper triple comes off easy with a rubber mallet. I had a replacement part waiting.
Really? - The frame is differant. I thought about moving the bracket too, but I don't have much slack in the wiring to move it down any more.
Offline MarkP
« Reply #9076 on: January 29, 2012, 02:20:32 PM »
39 degrees out, rode my up and down the street trying to figure out my carb issues.
Offline CycleRanger
  • No comment about being an
« Reply #9077 on: January 29, 2012, 03:39:41 PM »
As promised, I pulled the head on the XL250.  I couldn't get the head off so I pulled head & cylinder as a unit.
I had to get creative in figuring out a way to separate the head without damaging the fins. It was truly stuck tight.
Ring gap?  Check!  Yeah it's got some! :o
No wonder it smoked like a 2-stroke...
I measured everything I could and it looks like I'll be able to just have it bored .25 over.
Then I broke out the K5 and went for a ride.   :D
I should have brought my gloves, it was a beautiful day but it was a little chilly.
Offline tweakin
  • tear down
« Reply #9078 on: January 29, 2012, 03:41:12 PM »
I got the brakes bled, reinstalled the Gordon frame kit and placed my newly repainted tins on so I can get an idea of what the finished product is going to look like.  Thanks again to Larry (nvr2old) for the awesome paint job...
Now I just have to wait for my new sprockets so I can complete the 530 chain conversion, then I get to start tuning the 915.. ;D
Offline mjstone
  • I'm definitly not a
« Reply #9079 on: January 29, 2012, 04:55:48 PM »
Also reloated the ignition switch under the tank with a 750 bracket I had laying around but don't really like it. Suggestions?
How about putting one for the 500/550 on.  It installs behind the front frame rail on the left side just under the tank.  There should be a bracket for a bolt to go through just inside the frame.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
« Reply #9080 on: January 29, 2012, 04:56:13 PM »
Tweakin - one word...WOW!  I see a future BOTM winner. Great job.
Offline Tintop
« Reply #9081 on: January 29, 2012, 06:42:35 PM »
MJ
+1 MJ, the (early?) 500's had one under the tank that used a coil mount bolt.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Raef
« Reply #9082 on: January 29, 2012, 07:29:43 PM »
+1
« Reply #9083 on: January 29, 2012, 07:52:34 PM »
Beautiful..... ;)
Offline mick7504
« Reply #9084 on: January 29, 2012, 08:44:06 PM »
That is what I call a masterpiece sir.  8)
Both internally and externally.
If I was you
I'd be worried about me.
« Reply #9085 on: January 30, 2012, 02:17:50 AM »
Thassa beautiful "F" Tweako, you've done a brilliant job mate, and that paint job is outstanding! Are you using a Cyclex 915 kit? If so, what's the quality like, I'm about to order one for my K1? Cheers, Terry. ;D
Offline tweakin
  • tear down
« Reply #9086 on: January 30, 2012, 06:03:55 AM »
Thanks to all of you for the compliments!  This build has been a labor of love.
Terry the cycle X 915 kit is top notch.  Wiseco pistons, super nice sleeves and you don't have to bore the cases.
« Reply #9087 on: January 31, 2012, 01:50:12 AM »
Hey thanks mate, that's what I was hoping, and if they're Wiseco's, they must be pretty good. Cheers, Terry. ;D
Offline petercb750
« Reply #9088 on: January 31, 2012, 03:43:37 AM »
Sensational...congratulations. jealous as.
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Offline wardenerd
  • '77 550F '81 650C
« Reply #9089 on: January 31, 2012, 04:45:56 AM »
Sunday I bled the brakes after rebuilding the front brake system and it worked great.  Only problem was the squeking that will drive a porpoise to suicide.  Looked on the forum and cut a line on both pucks.  Used brake lube on both puck backs and the barrel of the movable side.  Put it back together and at least right now no squeak.
« Reply #9090 on: January 31, 2012, 08:25:35 AM »
Rode it!!!
maduncle
« Reply #9091 on: January 31, 2012, 09:33:49 AM »
Sold it!!!
Offline bender01
« Reply #9092 on: January 31, 2012, 10:18:06 AM »
Removed the forks and dissasembled them. Washed everything in await for my new tubes from cycle-x! Should be here tommorow. Seals were harder than I thought to remove. Once one was out the second was easy.
Update. Fed ex came a day early!
« Last Edit: January 31, 2012, 11:22:26 AM by bender01 »
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #9093 on: January 31, 2012, 12:39:06 PM »
Rode it!
« Reply #9094 on: January 31, 2012, 01:45:09 PM »
Thats a tidy little 500 you have there Greg..... ;)
« Reply #9095 on: January 31, 2012, 04:25:19 PM »
Rode it and developed a problem:(
Offline piute
  • Piute
  • TRICK OR TREAT...B....es
« Reply #9096 on: January 31, 2012, 07:08:12 PM »
Took the tins in the house for a good cut N polish ,new week and we hit 60s in Jan.
« Last Edit: January 31, 2012, 07:13:51 PM by piute »
Ride to live Live for Jesus
1977 750 F2
Offline thrutheframe
« Reply #9097 on: January 31, 2012, 08:02:39 PM »
  I made money to feed it parts, gas, and oil.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Shane72
« Reply #9098 on: January 31, 2012, 08:13:10 PM »
Adjusted points, set timing, installed Hondaman ignition today.
Cut and installed 3/4 inch fork spring spacers, new plugs and resistor caps yesterday, and rode a little since it was 55 degrees here in IA.
Shane
I mount and balance MC tires--while-you-wait service by appointment.  Send me a PM.
« Reply #9099 on: January 31, 2012, 08:18:34 PM »
Bought this!
And a whole bunch of other stuff!
http://forums.sohc4.net/index.php?topic=101665.0
