Author Topic: What did you do to your bike today ?  (Read 3206829 times)
Offline WhyNot2
  • I'm finally an
« Reply #9425 on: March 03, 2012, 12:43:46 PM »
Is 38 miles per gallon a good gas milage for these bikes?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #9426 on: March 03, 2012, 12:44:32 PM »
Depending on how you ride, and which bike you're riding, that's pretty solid.
Offline WhyNot2
  • I'm finally an
« Reply #9427 on: March 03, 2012, 03:11:03 PM »
Thanks Greggo.................
Its a 75 750k5 with stock air box and wide, wide open pipes.
Online 70CB750
« Reply #9428 on: March 03, 2012, 03:18:41 PM »
Rode it for 30+ miles. Life is fun.
Offline CrankyOldGuy
  • Wish I was a
« Reply #9429 on: March 03, 2012, 03:46:19 PM »
Unpacked my oil pump (750K1) last night after its rebuild by Hondaman.  Looks like new and turns over real smooth.  Another small step completed.
Harry O.
750 K1 Original Owner
Offline heffay
« Reply #9430 on: March 03, 2012, 04:28:05 PM »
Now that the 350f is running pretty well, I had to dig into the Banshee quad.
Elizabeth helped me flush and bleed the brakes... since I test rode it, it had none, until today.
Trying to get the jetting right, PO had the airbox all out and it was barely running when I bought it.  Had to rig it all together with gorilla tape and zip ties, works like new!
Its really running a lot better but still needs adjustment.
Its a 2 stroke BEAST, I originally bought it for her, but she may get the 250r for a while.   ;D
Offline S_Spiff
  • Reality continues to ruin my life.
« Reply #9431 on: March 03, 2012, 08:12:45 PM »
Test Ride @ 31 degrees.  Just got back.
In January, I started changing the stock bars to euro bars.  Had to take the airbox off to get the throttle cables back on.  While it was off, found I had no accelerator pump function.  Ended up cleaning the carbs, spending quite a lot of time waiting on the ups man to bring me tiny o-rings.
Tonight, I finally got it back together and took it for a spin.  Fun.
Rob
'78 CB750k
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #9432 on: March 04, 2012, 04:39:01 PM »
Just got done putting a new 18T front sprocket on the K3. Man, the sprocket was not a bad job at all. Now on the other hand, cleaning all the old grease off the case...quite another story. One roll of papertowels, a half bottle of Simple Green, and two pairs of rubber gloves to make it look all pretty where not a soul will see. Huh, HondaFever comes in many degree's of insanity! LOL
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Grnrngr
« Reply #9433 on: March 04, 2012, 06:29:16 PM »
It's not bad, I get 40-45 around town, 50ish on the road with my 72 750. Do you have points or electronics?
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline Raef
« Reply #9434 on: March 04, 2012, 06:46:24 PM »
I ride a 75 550, It is in good tune and runs very well, if you go off the odometer it get close to 50 but in reality the actual mileage is closer to 35-40 mph using a GPS for speed and mileage.
« Reply #9435 on: March 04, 2012, 08:49:55 PM »
Well, not just today, but in the last week I've been getting ready for the Relay:
Adjusted steering stem bearings.
Changed out fork oil for ATF.
Drained out the gas that has been in the tank since October.
Mounted 17 tooth sprocket in place of the 16 tooth, lubed and adjusted the chain.
Adjusted valves and cam chain.
Re-gapped spark-plugs to .058". (Newly found Gerex ignition instructions actually called for .063- .065"  :o)
Mounted the fairing I got from mrbreeze, after enduring the winds on the Relay last year. (Thanks Fred!)
This year, I'm going to be ready!!!!
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=8jr3rdl0uh1a9i0ipghil0keb0&/topic,60973.0.html
« Reply #9436 on: March 05, 2012, 12:36:31 AM »
painted side kovers..did not go well..got parts for front fork repair..nev sealings..and thange fork oil...new tires must vait..the cbx eat all my money
i hate all this v-w.... vords
Offline Dimitri13
  • 1974 CB550K
« Reply #9437 on: March 05, 2012, 12:44:14 AM »
Replaced the oil pan, replaced the tach seal gasket, and changed the oil and filter while I was at it. So far it seems like it's not leaking anymore :)
Wanted to test it out and burn all the oil off the headers, so I took it out. But it was pouring.
Offline WhyNot2
  • I'm finally an
« Reply #9438 on: March 05, 2012, 01:06:52 AM »
Points
« Reply #9439 on: March 05, 2012, 04:35:05 AM »
painted side covers..did not go well..got parts for front fork repair..nev sealings..and change fork oil...new tires must wait..the cbx eat all my money
Looks like your sidecovers got the classic syndrome call fisheyes or orange peel in the paint.Usually caused by silicone or some other contaminant on the base. If spraying from a spray gun there is an additive for that.If from a spray can sometimes building it up in lighter mist coats can help.Base has to be super clean though before painting.
Offline tweakin
  • tear down
« Reply #9440 on: March 05, 2012, 05:24:32 AM »
Changed the mains and needle jets and synched the RS34's... ;D
Offline thrutheframe
« Reply #9441 on: March 05, 2012, 05:45:45 AM »
  Put the center stand back on, adjusted the clutch, started on the body work on the tank.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Really?
« Reply #9442 on: March 05, 2012, 07:04:48 AM »
Dropped off the swingarm at the mailroom where I work.  Off to HM it goes!
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Online 70CB750
« Reply #9443 on: March 05, 2012, 07:10:36 AM »
Left her home, wintery mix today.
Offline Picasoo
« Reply #9444 on: March 05, 2012, 07:23:36 AM »
My baby was "singing" for the first time... :D
'75 cb750F super sport
Offline bikerbart
« Reply #9445 on: March 05, 2012, 08:33:34 AM »
put new seals in my forks,rebled my brakes because I put on the drilled disc,tightened lubed everything and went for a FAST ride to check out the difference since I also put on the steering damper.BIG improvement,I love my bike again.
Offline kpier883
  • is quite the
« Reply #9446 on: March 05, 2012, 09:01:02 AM »
Yes, it does eat the money faster than the SOHC for sure!
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline Prospect
« Reply #9447 on: March 05, 2012, 12:18:36 PM »
Installed new spokes on my rear wheel and drilled the clutch basket to improve oil circulation.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline gnarlycharlie4u
  • Far from being an
« Reply #9448 on: March 05, 2012, 12:30:52 PM »
swapped a brake line on the GL1000
also swapped a master cyl on the K3 750, then bled.
We also mounted those seat brackets (thanks a bunch Stev-o) and the freshly repaired starter solenoid.
AAAAAAAND??? I want updates on how they're running ASAP please.
« Last Edit: March 05, 2012, 12:34:55 PM by gnarlycharlie4u »
Offline Bailgang
  • Scott
  • Indiana
« Reply #9449 on: March 05, 2012, 02:42:47 PM »
Still waiting on the main jets I ordered for my 550, in the meantime I'm trying to get an 83 Yamaha XS650 road worthy again for a friend of mine. Typical kind of bike that's sat for the last 9 years. Thorough cleaning of the carbs got it running again then adjusted valve lash and cam chain and it actually doesn't sound too bad but now electrical gremlins are popping up. The headlight won't come on because the alternator isn't charging worth a squat and I'm finding out the alternator is one of Yamaha's weakest links at least on this bike it is. Just my luck.  >:(
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
