Author Topic: 650 cam issues in 550 motor  (Read 1735 times)
Offline Aaron Richard
  • 1975 CB550 cafe
    • shop
« on: November 09, 2009, 06:05:02 AM »
Hey all, quick issue, I installed a 650 cam in my 550. its in there correctly, but my adjusters are now slightly hitting the tappet caps. Has this happened to anyone? do I need to grind down the adjusters some?
Offline buffalogt750
Re: 650 cam issues in 550 motor
« Reply #1 on: November 09, 2009, 08:29:35 AM »
I have a 650 cam in my '76 550 and do not have that problem. How many miles does the engine have on it? Is it possible the valves and valve seats are worn thereby pushing the valves further up into the head which would put the adjusters closer to the tappet caps?
1976 Honda CB550K   SOLD
1993 Ducati 750 SS
2000 Suzuki Bandit 1200
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: November 09, 2009, 08:32:37 AM »
No issues with my cam swap either.
Stupid question, but have you adjusted the valve clearances yet, or are they still backed out all the way?
  • 1975 CB550 cafe
    • shop
« Reply #3 on: November 09, 2009, 08:35:23 AM »
head is all rebuilt, had no issues with the 550 cam in it. Everything is adjusted to specs.
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: November 09, 2009, 08:37:44 AM »
I just saw your post in the other thread about clearance issues.  Which problem are you having?  Is it a tappet clearance problem or a cam lobe/head clearance problem?
  • 1975 CB550 cafe
    • shop
« Reply #5 on: November 09, 2009, 08:51:39 AM »
when I installed the cam I had to shave a bit of the wall of the head where the cam lobe was hitting a bit, I finished the install and adjusted the valves. I noticed the tappet covers were being hit by the adjusters by flipping them over and seeing the wear marks. they didn't do that before. Not sure if the cam is rubbing somewhere else that would cause the tappets lifting too high
« Reply #6 on: November 09, 2009, 09:10:01 AM »
Tappet adjusters are closest to the caps when the valves are closed, not when they open. The extra lift of the 650 cam will not put the adjusters any closer to the caps.
1993 Ducati 750 SS
  • 1975 CB550 cafe
    • shop
« Reply #7 on: November 09, 2009, 09:29:19 AM »
something is going on in there. the top end is louder than usual. I'll have to pull off the cover and see if its rubbing anywhere else.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #8 on: November 09, 2009, 10:13:35 AM »
he's right here. the only thing i can think of that would cause this problem (aside from the adjuster being run out too far) is if the valve seat was cut too deep and he valve stem not trimmed accordingly. maybe go back through it and make sure you didn't make some silly error setting the valve lash?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #9 on: November 09, 2009, 10:23:02 AM »
Boy, you would really have to sink the valves to have this problem. I'm thinking something wierd with the valve lash too.
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: November 09, 2009, 10:29:46 AM »
Take a look at this thread:
http://forums.sohc4.net/index.php?topic=59144.0
Could this be the problem?
Offline paulages
  • 1976 cb735
« Reply #11 on: November 09, 2009, 04:18:18 PM »
you would... and would likely have some serious flow issues sunk that far.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
