Author Topic: 1976 CB550 - amateur resto attempt  (Read 5973 times)
Offline deimzig
« on: November 09, 2009, 05:06:45 PM »
I picked up this '76 CB550 a few years ago.  It has 3,100 Miles, runs great, and even has the original set of tires.
Minimal rust and solid mechanics - seemed like a good candidate for an attempt at a cosmetic restore.  My intent is to stay factory.  I welcome any thoughts or tips or ideas or whatever :)
2004 Ducati M800
2000 Harley Electra-Glide
1976 Honda CB550K
Offline deimzig
Re: 1976 CB550 - amateur resto attempt
« Reply #1 on: November 09, 2009, 08:16:38 PM »
I started disassembly.  No real concerns...
...no concerns except that the right controls had been jimmy-rigged (broken starter button) and the throttle cables from the control module had been wrapped with electrical tape.  I will be looking for a replacement.
This bolt is really lame.  Socket by hand didn't work.  Impact wrench rounded the hex.  So then I cut slots in the bolt head with a hack-saw and used an impact screwdriver on it.  Broke two bits.  So I took the grinder to it knowing that I'd probably destroy the oil filter cover.
2004 Ducati M800
1976 Honda CB550K
Offline hoodellyhoo
  • CB350F
« Reply #2 on: November 09, 2009, 08:21:02 PM »
Glad to see that you are going to restore that bike. Sure picked a perfect canidate for a resto. That oil filter bolt is a common issure on these bikes. PO's like to over-tighten them which can crack the crankcase.
Offline deimzig
« Reply #3 on: November 09, 2009, 08:26:07 PM »
I removed the carbs, airbox, lights, dash, speedometer & tachometer cables, gauges and main wiring harness.
This is where I'm at now.
Questions:
What's the best way to remove the front brake hydraulics... in other words, how do I best avoid making a mess with spilled brake fluid?
Should I stuff something in the open orifices of the engine?
2004 Ducati M800
1976 Honda CB550K
Offline BeSeeingYou
« Reply #4 on: November 09, 2009, 10:02:59 PM »
I would plug up the openings into the engine just to keep critters/insects from making a home in there.  If you intend to rebuild the caliper and MC dismount the caliper keeping the lines intact and hang it over a bucket and use the MC to force out the piston for cleaning and replacing the seal.  Most of the fluid will come out right behind the piston.
Offline deimzig
« Reply #5 on: November 09, 2009, 11:30:28 PM »
Removed coils, main fuse panel, chain guard, rear brake pedal & rod, foot pegs, tank rubber bits, seat lock...
...and tried to take off the sprocket cover but the bottom/front bolt/screw is stubborn.  Sprayed PB Blaster - will try impact screwdriver tomorrow...unless anyone has any other suggestions?
2004 Ducati M800
1976 Honda CB550K
3rob3
« Reply #6 on: November 10, 2009, 03:39:57 PM »
How weird. I have the same bike, same year, same color. My oil filter housing now looks exactly like yours! I decided to replace it with one of these so I never have to del with it again:
http://www.randakks.com/Engine%20Parts.htm#1
Offline fastbroshi
  • Puppet
« Reply #7 on: November 10, 2009, 05:20:32 PM »
A cosmetic restore?  That thing's pretty cherry, I don't know if I would've broken it down as much as you have.  Are you going to get it painted too? Weird how those brown paint jobs always fade to green - ya never know what base they used on those candy jobs.  I cleaned the heck outta mine when it was in the same condition as yours, but I had the head off, wiring harness gone, etc.
Just call me Timmaaaaay!!!
Offline deimzig
« Reply #8 on: November 10, 2009, 10:49:25 PM »
Removed sissy-bar and chrome & plastic rear fenders.  I also started to wipe dirt & grime off and did some scrutinizing.
I don't suppose there's an effective way to straighten this fork ear?
Should I replace this wire due to frayed insulation?
I want to take the center-stand & kick-stand off so I can set the bike on a crate once I have the wheels off.  Any tips for removing the stands & manhandling the bike up onto the crate?
Also, the chain is grimy and very likely original.  Should I get a new chain or just clean the one I have?
2004 Ducati M800
1976 Honda CB550K
Offline dagersh
    • Photos
« Reply #9 on: November 11, 2009, 10:11:38 AM »
Nice project.  Remove the chain, and check the condition of your sprockets.  If they are not too worn, then the chain may be cleaned and reused.  I would use liquid WD-40 as it will thin out the gunk on the chain and it will be easy to clean.  If you replace the chain, make sure you replace your sprockets as well.
Keep on truckin'!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline j-conn
  • Federico Fabrizi
« Reply #10 on: November 11, 2009, 10:24:21 AM »
that is where i am at!!!
76 cb550 as well!
cheers
1976 CB550
Member #7772
Offline vorhese
« Reply #11 on: November 11, 2009, 10:29:02 AM »
I think I have a spare oil filter cover if you need it. Yours free if you pay shipping.
vorhese@gmail.com
Also you can probably fix that ear with a hammer and some wood blocks. It won't be perfect but pretty good.
« Last Edit: November 11, 2009, 11:51:21 AM by vorhese »
Offline fastbroshi
  • Puppet
« Reply #12 on: November 11, 2009, 07:11:34 PM »
  How's your exhaust?  Those models were notorious for rusting out the bottoms because the pipes wouldn't get hot enough to burn off condensation on short trips and the water would just pool.  Again, very nice bike.
Offline deimzig
« Reply #13 on: November 11, 2009, 08:09:04 PM »
Exhaust pipes are rust-free, but there's a dent in one, and some scuffs in a couple places.  I think I'm going to reuse them & just clean them up best I can.
2004 Ducati M800
1976 Honda CB550K
Offline deimzig
« Reply #14 on: November 11, 2009, 10:55:02 PM »
Got the left crank-case cover off.  There is white stuff on the oil pressure sensor and more white stuff at the bottom of the oil pump.  Anyone know what that is?
2004 Ducati M800
1976 Honda CB550K
Offline steamnjn23
« Reply #15 on: November 14, 2009, 10:18:42 PM »
D, the white stuff you asked about...in my case, it was from moisture. also found that in my carbs too.
of course, i could be wrong.
1976 cb550
Offline deimzig
« Reply #16 on: November 15, 2009, 11:11:30 PM »
I spent some time cleaning 33 years of grime off the swing-arm & around the sprockets & left crank-case cover.  The crud was on there like glue.  I also took off the shocks & rear wheel.  I'm wondering if I should reuse the shocks?  If I do, can I replace the rubber bushings here:
There's some weathering or something that won't easily rub off the rear brake housing... guess I'll have to secure a buffing wheel.
Anyone got any tips for getting this ancient sticker off the fender?
Some shots of the clean-up progress.  Not sure how much can be seen in these shots.
2004 Ducati M800
1976 Honda CB550K
Offline gregk
« Reply #17 on: November 16, 2009, 04:49:42 AM »
deimzig
i've got the identical bike.  As someone else has commented,it's strange that the paint on the tank fades to green?
Good luck with your project.
greg
I don't want it to go like a motorcycle, I want it to go like a rocket!
Offline deimzig
« Reply #18 on: November 22, 2009, 09:11:30 PM »
Did some more cleaning today.  Also some paint touch-up.
Started to polish a few things.  Polishing is hard work & I haven't perfected the technique.
2004 Ducati M800
1976 Honda CB550K
Offline steamnjn23
« Reply #19 on: November 23, 2009, 12:28:40 PM »
deimzig, read this post here.  its what i've done and it may help you.
http://forums.sohc4.net/index.php?topic=61880.0
1976 cb550
Offline cgancos
    • Flickr Page
« Reply #20 on: November 23, 2009, 12:58:59 PM »
I've got the headlight ears from a 78 550. If I remember correctly they're straight, but might need some polishing. I'll try and snag some pictures when I get off work. If you want them, they're yours for the cost of shipping.
Offline JIMLARCH
« Reply #21 on: November 23, 2009, 01:22:09 PM »
Get yourself a decent pair of aftermarket shocks.  They will make a big difference to the handling of the bike.
Offline dagersh
    • Photos
« Reply #22 on: November 23, 2009, 01:56:01 PM »
For that old sticker glue try Goof Off, Goo Gone.  You can get them at your grocery store.  If not, Mayonaise works....  I know, it sounds weird, but it works.
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #23 on: November 23, 2009, 01:59:41 PM »
So does WD-40....
