Author Topic: CB750 K0 Restoration - Round #3  (Read 49670 times)
Offline Simpson
  • I ain't no
  • Aged to perfection
« on: November 14, 2009, 11:35:15 AM »
After buying my k0 #1029054 last winter of 2008 and doing a restoration, it was a pretty good summer of about 4-5k. Unfortunately about two weeks ago I developed an oil leak between head and cylinder. Therefore after some SOHC.net advice (Gordan and others), I immediately took it out of service for rebuild. This thread we follow my progress.
Here are my goals this winter:
1.) Top end engine rebuild of seals, gaskets, rings etc.
2.) Refurbish Instrument cluster for covers and face gages
3.) Refurbish seat with new foam, cover and hardware
4.) Rebuild master cylinder and plumbing
5.) Refurbish and add vintage Shoei saddle bags
6.) Add a few new bling items
Here's a shot of last summer on a local ride...
« Last Edit: December 28, 2011, 08:44:09 PM by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
Re: CB750 K0 Restoration - Round #2
« Reply #1 on: November 14, 2009, 11:38:24 AM »
Picture just after getting it road worthy this summer...
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #2 on: November 14, 2009, 11:39:05 AM »
Pictures of some of my issues
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #3 on: November 14, 2009, 11:40:34 AM »
Current state today getting ready to pull the engine
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #4 on: November 14, 2009, 11:42:55 AM »
Issue found today. Now I know where my cold start issues come from...
I lined them up on first assembly but took it the carb links apart couple time and didnt check after.
Opps!
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #5 on: November 14, 2009, 11:49:41 AM »
These are the saddle bags to be refurbished.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #6 on: November 24, 2009, 04:39:18 PM »
Painter has qouted me 340.00 plus shipping for the paint job of both saddle bags.
This comes with 5 coats of clear. Seems a tad high?
Also concerned about tears in fiber glass on saddle bag hidges.
Anyone hear fix and re-enforce worn out saddlebags?
The stress from opening the top and leaning back has the top ripping around the mounted bracket. Might have to drill out rivets and add plate with epoxy.
« Last Edit: November 24, 2009, 04:44:09 PM by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #7 on: December 08, 2009, 09:53:02 AM »
Removed oil pan today (never been removed before with 14k on engine), except for a metal thread on the bottom there was little slugde, flakes or dirt. There is absolutely zero plastic chips or parts of the cam/drive chain tensioner visible.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #8 on: December 08, 2009, 09:59:55 AM »
If compression is good on all cylinders, I will not rebuild engine and just re-torque head.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline KB02
« Reply #9 on: December 09, 2009, 05:32:51 AM »
That's a nice looking bike you've got there. (and some other nice looking bikes hanging out around it, too.  ;D )
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Simpson
  • I ain't no
« Reply #10 on: December 16, 2009, 06:38:18 PM »
Thanks!
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #11 on: December 16, 2009, 06:43:58 PM »
Status Report:
-SaddleBags sent to painters
-Sent some carb items to be nickel plated (clips and thumb screws)
-New engine screws and other hardware ordered to replace existing
-Placed order for yamiya for seat cover, seat foam, gauge faces/covers, etc finally
-Compression tester purchased should be coming in th mail anytime
-Purchased matching shoei top case on ebay for 25 bucks shipped. Man i'm stoked!
Hopefully I can test compression and pull engine out this weekend. :)
« Last Edit: December 16, 2009, 06:49:36 PM by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #12 on: December 16, 2009, 06:46:37 PM »
Note to self:
Need to design and draw up the mounting hardware for the saddle bags this weekend and have it send out to be machined.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline gonzobrian
« Reply #13 on: December 17, 2009, 04:30:10 PM »
Looking good.  I love those Shoei saddle bags!  I have a KO sandcast I have been picking up parts for for years now and hope to get started on soon.  Your Yamiya purchase sounds like a good Christmas present to self.   Where did you find those saddle bags?
Offline Simpson
  • I ain't no
« Reply #14 on: December 17, 2009, 09:28:27 PM »
Pressure tester arrived today!  ;D Just checked the compression
cyl #1 - 158
cyl #2 - 150
cyl #3 - 155
cyl #4 - 155
Seems okay I think  ???  Thoughts anyone  ???
Cylinder #2 readings started at 137 but i re-seated and got 152.
The third try gave me 150 after re-seating again.
Saddlebag parts designed and sent out to be machined in steel.
Later I will have them chromed.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #15 on: December 17, 2009, 09:38:26 PM »
Yeah, I just ordered these parts for my project:
1 x WASHER SET, TONGUED (AS043)  = 735 JPY
1 x TUNING SET, LEVER SYSTEM (F044)  = 2,373 JPY
1 x K0 CUSHION, SEAT (RED SPONGE) (T029)  = 23,100 JPY
1 x KO COVER SET, SPEEDOTACHOMETER (D011)  = 25,200 JPY
1 x K0 HOOK, SEAT CATCH (T034)  = 1,575 JPY
1 x BAND SET, AIR CLEANER CONNECTING (T076)  = 1,556 JPY
1 x COLLAR, REAR BRAKE PANEL SIDE (AS069)  = 1,575 JPY
1 x K0 BLUE FACE DIAL SET, METER (MPH) (DM014)  = 15,750 JPY
1 x K0 OUTER SKIN, SEAT (T024)  = 22,050 JPY
1 x OIL SEAL, 18X29X7 (E081)  = 257 JPY
1 x OIL SEAL, SB TYPE, 13.8X24X5 (E080)  = 278 JPY
1 x GASKET, CLUTCH COVER (E019)  = 1,050 JPY
1 x CYLINDER SET, MASTER (F045)  = 3,381 JPY
1 x K0-K4 GASKET, OIL PAN (E038)  = 1,145 JPY
2 x BOLT, DRAIN PLUG 12MM (T065)  = 190 JPY
1 x K0-K2 CLIP, SPEEDOMETER CABLE(CHROME) (F113)  = 2,100 JPY
1 x ELEMENT SET, OIL (E034)  = 788 JPY
1 x K0LAST~COVER SET, HANDLE LOCK CASE (F117)  = 2,100 JPY
1 x SWITCH ASSY, STOP (AS015)  = 2,625 JPY
Talk about feeling like a kid at Christmas.
The saddlebag was a ebay "win".
I nearly bought a set of bates saddlebags but something about these got my attention.
Yesterday I grab a matching shoei top case for 25 shipped.
Man was  I excited.  ;)
« Last Edit: December 18, 2009, 08:23:27 AM by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #16 on: December 17, 2009, 09:42:58 PM »
Next step is to pull the engine this weekend and scope the top portion of the engine.
I have a lighted fiber scope I can snake into the engine to check cam chain tensioner etc...
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #17 on: December 20, 2009, 08:56:41 AM »
Engine out...
I made the mistake of trying to get the engine out with the swing arm, breather, shocks, and front forks attached. I'll never try that again. i scraped up my frame so bad I may get it power coated again. Engine looking extremely healthy looking down the top end.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #18 on: December 23, 2009, 09:53:02 AM »
Head re-torqued today and then re-assembled.
After broken loose, many bolts seemed to tighten up a 1/4-1/2 turn.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #19 on: December 23, 2009, 09:53:51 AM »
Getting ready to add some NOS bling items.  ;D
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #20 on: December 27, 2009, 12:26:19 PM »
Last minute decision change.
Probably will just re-build top end now.
Just ordered NOS wire harness.
Contacted painter, said he would paint the top case for additional 60 bucks.
Could not resist, sending out top case tomorrow.
« Last Edit: December 29, 2009, 04:41:33 PM by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
traveler
« Reply #21 on: December 27, 2009, 02:17:44 PM »
Have your head and cylinders O-ringed together, and with a cometic head gasket...will never leak again!
~Joe
Offline Simpson
  • I ain't no
« Reply #22 on: December 30, 2009, 01:30:56 PM »
Received Yamiya shipment today and went straight to work.
Refurbished the seat and instruments.  8)
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #23 on: December 31, 2009, 12:57:30 PM »
Master Cylinder and brake switch rebuilt and upgrade.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #24 on: December 31, 2009, 12:58:30 PM »
Time or paint touch ups to the frame and engine.
Changed my mind again today.
I will not rebuild top end of engine.  ::)
1970 CB750 K0
1975 CL/CB 360 Mix
