Author Topic: 72 cb750 Cruise control knob problem.  (Read 1827 times)
Offline Deceptibong
« on: November 16, 2009, 06:35:04 AM »
http://www.mrcycles.com/fiche_section_detail.asp?section=126077&category=MOTORCYCLES&make=HONDA&year=1972&fveh=3000
(numbers 11 and 12 are the bolt and spring knob Im talking about.)
I have an issue where my cruise control knob doesnt seem to hold or catch the throttle.  I took apart the assembly, and it looks like the knob screws in and out normally but i dont feel the bolt hold the throttle at all.  Has anyone seen or experienced it before?  Looking at the diagram, it appears mine is put together the same way.  Im not sure what to change/replace.
1972 CB750k2
Build / Travel Reports: http://easterntowestern.blogspot.com
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Re: 72 cb750 Cruise control knob problem.
« Reply #1 on: November 16, 2009, 07:03:31 AM »
if the throttle "lock" wont work, usually #9 is missing. It actually pushes against the throttle tube when the knob is screwed in.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
« Reply #2 on: November 16, 2009, 10:01:41 AM »
That tensioner shoe usually falls out if you are not watching for it, many are missing..
 if you step on it, it is probably hooped.. :o
 should look like a strip of shim stock bent sorta like a sideview of a  weiner.. has a little hole to catch the screw end..
Offline Deceptibong
« Reply #3 on: November 16, 2009, 11:13:05 AM »
looking on bike bandit and others, i dont see any available for sale.   :-\ so maybe i could make my own?  any suggestions on that??
1972 CB750k2
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: November 16, 2009, 11:28:19 AM »
There's an equivalent part for Harleys that I though might be made to work, but I've not taken any measurements or anything.  Perhaps you could make one out of scrap metal but it'd have to be springy enough to do the job.
I got mine new from Honda about 10 years ago, have you checked your local dealer to see if they're still available?
mystic_1
- John Augustus Shedd
Offline Deceptibong
« Reply #5 on: November 16, 2009, 11:47:36 AM »
I havent really checked anyone in town but Ill call around.  Ive never seen the part i need up close and the diagram online kind of sucks so I wouldnt have a very good idea what Im making.  i imagine its moon shaped with a rubber layer on the inside curve so it grabs the throttle.  maybe ill look closer to my bike and try and figure out how big it should be...anyone know where i can see more detailed schematics?
1972 CB750k2
Offline westondc
  • Wes Mantooth
« Reply #6 on: November 16, 2009, 12:40:19 PM »
i took apart the throttle grip housing on my cb500 and cleaned it the other day and applied a little lithium grease. i believe the cruise controll knob (more like a friction plate that reduces the recoil from the return spring) looks the same as yours. I'll take another look at it and i might be able to help you figure out what your missing. You should stop by 6 Cycle Salvage in Ashland. I bet they'll have what your looking for. http://www.6cycle.net/
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: November 16, 2009, 12:48:12 PM »
It's very similar to this part sold by Drag Specialties for Harleys:
http://www.dragspecialties.com/fatbook/12/201/7729351
I'm thinking of just ordering one to check out, they only cost $0.95.
The OEM Honda part number, btw, is 53163-300-020
The harley part is #56396-74A
If the harley part works I'll let you know.
mystic_1
« Last Edit: November 16, 2009, 12:57:44 PM by mystic_1 »
