Author Topic: specs for degreeing cam on cb550  (Read 1127 times)
Offline dragon79
« on: November 16, 2009, 05:57:22 pm »
just curious if anyone knows what the specs for intake opening and closing are in degrees? same with cb650
Offline w1sa
Re: specs for degreeing cam on cb550
« Reply #1 on: November 17, 2009, 07:03:37 am »
These are the valve timing numbers I found in FAQ Manuals section.
CB500-CB550    http://www.mediafire.com/file/m3f2jageg2m/CB500
CB550       Intake         OPEN  5* BTDC,       CLOSE   35* ABDC
               Exhaust       OPEN  35* BBDC       CLOSE   5*  ATDC
CB650    http://cosky0.tripod.com/
CB650   Intake OPEN 5*BTDC@1mm lift,58*@ 0 lift CLOSE 35*ABDC@1mm lift, 127*@ 0 lift
         Exhaust OPEN 40*BBDC@1mm lift,121*@ 0 lift CLOSE 5*ATDC@1mm lift, 65*@ 0 lift
Hope this helps.
