Author Topic: front axle nut stuck  (Read 2128 times)
« on: November 17, 2009, 08:56:34 AM »
 After searching I came back here, My front axle nut is frozen to the axle, any tips on removal? I tried heat and Kroil yesterday.
Offline vorhese
Re: front axle nut stuck
« Reply #1 on: November 17, 2009, 09:29:27 AM »
Is it off the bike?  I had to put a bolt through the other side of the axle's hole and hold it with vice grips, and cranked the nut with a big crescent wrench. Bent the bolt but nut came loose. You may need to let it soak for a while in Kroil, WD-40, or MArvel's Mystery Oil.
« Reply #2 on: November 17, 2009, 10:13:50 AM »
Yes it's off the bike, I tried an old screwdriver in the hole and a crescent wrench. It's soaking in kroil now.
Offline voxonda
« Reply #3 on: November 17, 2009, 10:20:32 AM »
Give it a few seconds with the old torch.
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: November 17, 2009, 12:58:11 PM »
There's never been a better combo (for me at least) than heat and PB Blaster.
More heat than you think.  If a heat gun doesn't get it, you could try a torch or one of those cheapo propane torches.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #5 on: November 17, 2009, 01:03:43 PM »
+1 on PB blaster and heat.  i don't even try to remove a bleed screw without soaking for a few days.  i firmly smack the bleed screw duing this waiting period, then heat and remove.  so, i'd try smacking the nut (no, not choking your chicken) also. ;D
searching for a dr350se
« Reply #6 on: November 17, 2009, 03:31:32 PM »
 Thanks, heat worked, I'm well on the way to double discs. I got the speedo drive modified and will assemble it soon. I didn't get the speedo mod until I saw it apart in person then it all made sense.
  Now I will attack the speedo drive on my K0 with the lester, for some reason it won't drive the cable.
