Author Topic: Thinking of going to a 1.85 x 17 front wheel  (Read 2869 times)
Offline azuredesign
  • Knupping pin
« on: November 17, 2009, 02:57:51 PM »
 sohc 750: Are there any problems or disadvantages with doing this? Can the speedo gear be changed to work with a 17" wheel? How wide a front tire could I run with this rim?
Thanks for any ideas.
Offline crazypj
  • I'm brill, me
Re: Thinking of going to a 1.85 x 17 front wheel
« Reply #1 on: November 17, 2009, 03:18:51 PM »
If your going 17" why go so narrow on rim?
 1.85rim has max tyre size around 3.50" although 3.25 would be better.
A modern120 tyre needs a 3.00 rim but it's more usual to see them on 3.50"rim
PJ
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #2 on: November 17, 2009, 03:19:04 PM »
You are still limited by clearance issues with the mounts for brakes and fender.
A 1.85 rim is made for 90 (maximum) tires. Smaller, really.
This sounds like a small wheel for a sohc4, really. What bike is this for?
« Last Edit: November 17, 2009, 03:21:09 PM by mlinder »
No.
Offline azuredesign
  • Knupping pin
« Reply #3 on: November 17, 2009, 03:36:20 PM »
Ah, I came across a 1.85x17 alloy rim for cheap and i though maybe I could use it, but I think I'll hold out for a 2.85.
Is the max front tire size with clearance a 120?
Thanks!
Offline kos
    • m3racing.com
« Reply #4 on: November 17, 2009, 04:36:39 PM »
Watch out for some serious head shake if your over all diameter get's to small. Better use a steering dampener, but if it is a "look at Me" bike..go for it! Steering head angle might be getting a bit steep with a very small diameter wheel.
KOS
220...221, whatever it takes.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #5 on: November 17, 2009, 04:58:53 PM »
Thanks!
I have never tried a 120 front on a 750.
Not sure if it's possible with stock fender on and such. 120 is wiiiide.
No.
Offline azuredesign
  • Knupping pin
« Reply #6 on: November 17, 2009, 05:19:34 PM »
So what's the max then, 100 or 110? Couldn't I put a 100/90 on that 1.85 x 17 rim?
Offline Alan F.
« Reply #7 on: November 17, 2009, 06:03:31 PM »
Here ya go Ben, this guy's in Boston even.... he's got a 120/80-17 up front with stock brakes and fender.
http://forums.sohc4.net/index.php?topic=50756
And I think MCRider is still going with a 17" front too, maybe he'll chime in with some of his findings.
Cheers.
-Alan
Offline azuredesign
  • Knupping pin
« Reply #8 on: November 17, 2009, 08:44:05 PM »
Thanks Alan,
I'll look forward to speaking with you tomorrow eve over some Cervezas and guacamole. After seeing how small the 17 looks on there, I think I might go stock or 18" alloy, but I want to see what my tire and rim options are.
Offline crazypj
  • I'm brill, me
« Reply #9 on: November 18, 2009, 12:20:50 PM »
I have a WM3x18" genuine Boranni rim off back of CB750, not sure if I want to sell it though as will cost too much to replace if I ever get round to swapping front rim on 550 or building it into 'new' hub (it has 19" Boranni at present)
PJ
