Author Topic: Should I change my 400/4 Primary Chain?  (Read 1828 times)
Offline neilma
« on: November 20, 2009, 09:27:17 AM »
Was just wondering what the consensus was one whether it was necessary to change the primary chain? Just about to start a complete engine rebuild and wondered if it was necessary to change the primary chain? I was reading a review from the 80's that said they were bulletproof and likely to outlast the engine and the owner however elsewhere people say to change them as a matter of course?
Engine has done aroun 34K miles and I have never heard the engine running so couldnt say if it was making a noise before stripdown. If ithelps, the guide shows no sign of wear but not sure how relevant that is. Are there any measurements around to compare to a new chain?
Or should I just change it and forget about it??
Thanks
Neil
Offline mystic_1
  • 1970 CB750K
Re: Should I change my 400/4 Primary Chain?
« Reply #1 on: November 20, 2009, 09:35:01 AM »
Changing it now is (relatively) cheap insurance.  I'm replacing the primary chains and tensioner in my 750 for exactly this reason.
mystic_1
- John Augustus Shedd
Offline Deltarider
« Reply #2 on: November 20, 2009, 09:57:23 AM »
These are heavy duty chains and they'll live forever. Mine (in a CB 500) is in there for more than 130.000 kms now.
CB500K2-ED Excel black
Offline bistromath
« Reply #3 on: November 20, 2009, 10:20:36 AM »
Deltarider, you might want to rethink that statement -- the CB500 has no primary tensioner and tends to let the primary chain wear through the oil galleys when it gets slack. I *believe* the 400 has a primary tensioner and as such its primary would last longer.
I'd change it just because I wouldn't want to tear it down again later, but if there's very little slack then don't worry about it.
'75 CB550F
Offline Tnutz
« Reply #4 on: November 20, 2009, 08:00:22 PM »
Checking mine this weekend by dropping the pan.  Honda sure dropped the ball on the 500 and 550 with that.... ???
2004 Ducati 999 mono posto.
-Full Termignoni exhaust
-Lots 'o' carbon fibre
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline schwebel
« Reply #5 on: November 20, 2009, 08:17:03 PM »
Do it, mine has the infamous CB400f primary howl. The engine has about 20k on it. It drives me nuts sometimes, but I am trying to hold off a little longer on my rebuild.
Offline Tnutz
« Reply #6 on: November 21, 2009, 04:48:52 PM »
checked mine, there is slack. but not alot.  Cases all feel smooth and no debris in the oil pan.   :D  but if i end up tearing into this motor again soon i'll do it anyways.
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
