Author Topic: What's the worst/dumbest thing a PO did to your bike?  (Read 69529 times)
Offline Bailgang
  • Scott
  • Indiana
Re: What's the worst/dumbest thing a PO did to your bike?
« Reply #175 on: April 03, 2012, 02:11:19 AM »
PO obviously had no clue how to install hand grips on the bars so he used hose clamps to keep the grips on. Also PO must have lost the keys because factory ignition switch had been butchered to remove its tumblers in the hopes that it would work with any key, that didn't work so a toggle switch that was just hanging off the harness was used instead.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline LesterPiglet
  • 1977 CB550F2
« Reply #176 on: April 03, 2012, 03:18:08 AM »
I had a CD175 the PO had attached rear crash bars to. Of course the mounting points were top and bottom shock mounts.  ::)
Offline cb650
« Reply #177 on: April 03, 2012, 03:48:51 AM »
Cool a hard tail!!     ;D
Offline grcamna2
« Reply #178 on: April 03, 2012, 05:36:46 AM »
Someone in another thread has a 750F with the tach cable JB Welded into/onto the cam cover. Undoubtedly to fix a leak.
You know what they say,.."JB Weld will fix Anything" !.....
75' CB400F/'bunch o' parts'
Offline Grey
« Reply #179 on: April 03, 2012, 06:33:25 AM »
The PO had flipped the bike endo 3 times at the end of the first year he bought it. Only had 4250 miles on it. Seeing I was able to get all parts at cost. (Honda shop sponsor for racing) I rebuilt the bike and did my own paint scheme and had only $1800 in it when they were still worth $3000+. It now has a tad over 60k on it. It's been a great bike! 83 Interceptor.
Offline thrutheframe
« Reply #180 on: April 03, 2012, 07:39:21 AM »
  When I got my 750 K4 the PO told me he couldn't get the front brake to bleed down.  I opened the master cylinder and he had the fluid IN the diaphragm.  That wouldn't seem so bad to me if the guy didn't own a successful auto repair shop specializing in Hondas and Toyotas!
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #181 on: April 03, 2012, 09:03:57 AM »
Brilliant!!! :)
« Reply #182 on: April 03, 2012, 10:24:42 AM »
Brilliant!!! :)
I'd call him a glaring example of a PO.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline CBNJ74
  • Sweep the leg!
« Reply #183 on: April 03, 2012, 01:34:48 PM »
Chopped the bottoms off a set of perfectly good fork ears and extended the front forks 4"
I have the tubes if anyone is interested. They're in pretty good shape and were in perfect working order when I bought the bike.
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
Offline dhall57
« Reply #184 on: April 03, 2012, 04:35:48 PM »
This is not my bike but in fits perfectly into this thread. Can you believe this :o :o : ??? ??? ??? Poor and neglected 750K6. I ask the owner why in the @#&$ did he mount the battery on the luggage rack and tie it down with bungee cords. Don't you know how unsafe that is. As serious as a heart attack he said the motorcycle battery was to expensive so he found this used lawn and garden battery for free and cut the factory harness and spliced other cables to it so they would reach back to the rack. This as to be the dumbest and the most lame brain thing I've ever seen.
« Last Edit: April 03, 2012, 04:40:09 PM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline cb650
« Reply #185 on: April 03, 2012, 04:40:35 PM »
Why not a gas tank there too?   ::)
« Last Edit: April 03, 2012, 07:18:21 PM by cb650 »
  • 1977 CB550F2
« Reply #186 on: April 03, 2012, 04:49:32 PM »
The luggage rack isn't even attached properly, it's on a hinge. I'd be interested to see the results of some heavy braking.
Offline CycleRanger
  • No comment about being an
« Reply #187 on: April 03, 2012, 06:09:22 PM »
Wow, indeed that's in a class all its own!  :o
I'm not sure I'd believe it without the pictures!
Offline WarwickE36
« Reply #188 on: April 03, 2012, 06:31:19 PM »
he was clearly just trying to make the bike easier to wheelie  :-\
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline grcamna2
« Reply #189 on: April 03, 2012, 07:28:46 PM »
That would do it  ;D...kind of unbelievable Stuff here...
Offline KC_Northstar
« Reply #190 on: April 03, 2012, 07:49:21 PM »
My PMO (previous moron owner) Must have read Hondamans book about the mod to the stock air box.
You know, drilling holes in the baffle on K1 and later bikes. Only this twit drilled holes in the bottom
center of the air box allowing air to bypass the filter. I am currently rebuilding the worn out engine that
ran for thousands of miles on unfiltered air.   He also ported the carbs!  He actually ground out the throats
of the carbs to help them pass more air --  destroying the venturi of the carbs and turning them in to
aluminum recycleables.
KC
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline rangerboy2788
« Reply #191 on: April 03, 2012, 08:07:33 PM »
I dont know how to copy other peoples pics in this thread but that "orange" 750 with the battery on the rack looks just like my 550 when i brought it home! battery on the back and all!!!
Offline grcamna2
« Reply #192 on: April 03, 2012, 09:03:36 PM »
It would seem that they're's a twin to that "other" one w/ the battery on the back ?? awh man...I wonder if they thought it would be easier to charge while the bike had a non-functioning charging system...? or maybe they were using the battery up there to jump start other cycles w/ bad charging systems ???  ::)  ::)  :D
« Reply #193 on: April 04, 2012, 05:49:14 AM »
But why he limited himself to such small battery with all the space on the rack?  How about 1000 cranking amps.
Offline Godffery
  • Godffery's Garage
« Reply #194 on: April 04, 2012, 06:33:46 AM »
This is an excellent example of how NOT to run your wiring threw your handle bar!
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #195 on: April 04, 2012, 11:31:28 AM »
Why would you do the work to push the wires through there and then ruin it like that?!? LOL!!! :)
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #196 on: April 04, 2012, 05:15:55 PM »
The PO gave me a cb500 for nothing.  It was a parts basket bike without a title.  It has been the love of my life and I have brought it back to road worthy and learned a lot about how to work with CBs. Now my major ride.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline Godffery
  • Godffery's Garage
« Reply #197 on: April 04, 2012, 07:02:54 PM »
Notice anything else Wack about that thing..?
Offline grcamna2
« Reply #198 on: April 04, 2012, 07:11:26 PM »
Godffery,
    Is this you're Honda ? I imagine you've had to do lot's of fixing on it.
Offline Godffery
  • Godffery's Garage
« Reply #199 on: April 05, 2012, 02:16:31 AM »
No, I just happend to run across it.
Check out that fine job mounting the handle bars.
