Author Topic: What's the worst/dumbest thing a PO did to your bike?  (Read 67039 times)
Offline grepper
  • Busted Knuckles
Re: What's the worst/dumbest thing a PO did to your bike?
« Reply #250 on: November 21, 2012, 09:21:29 AM »
On a CB650 I found an old T-Shirt stuffed under the tank...  guess because the tank rubbers were worn out.
« Reply #251 on: November 21, 2012, 09:41:40 AM »
Hose clamps to install the mounting bracket for a vetter fairing... unless thats a common practice idk... i thought it looked sketchy
Actually that is the common practice of installing the Vetter bracket,or at least the many I have taken off.
Offline MoMo
  • Ride like you're invisible
« Reply #252 on: November 21, 2012, 11:13:28 AM »
he could have at least used a SS zip tie FFS   ::)
or a coat hanger...Larry
« Reply #253 on: November 21, 2012, 11:17:17 AM »
Yes a coat hanger would be far more..elegant.
Offline 550Z
« Reply #254 on: November 21, 2012, 03:00:49 PM »
the po for my bike put chopper forks on the front end which looked terrible, and he took the bike and covered it in 2 quarts of oil to prevent it from rusting!! it was outside for a week!!!! then he sold it to me!!
oldbob
« Reply #255 on: November 21, 2012, 05:53:41 PM »
That is how Vetter did it. In August of 1973, I picked up (long story) a new Windjammer at the factory in Illinois, and I installed it on my Suzuki GT550 before leaving.
Bob
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #256 on: December 13, 2012, 04:50:50 AM »
winna - winna - chicken - dinnah!
could it be?  omg.
taking the rear wheel off for refurb last night, i found that the PO had used a valve stem to hold the brake arm to the brake panel.  first clue was little flat nut, then the air valve.   :o
he'd cut the valve stem out of a tube, and stuffed the rubber part into the recess on the backside of the brake panel.  everything else has looked fine so far, but now ...................
« Last Edit: December 13, 2012, 03:12:15 PM by steam-powered man »
searching for a dr350se
Offline mjstone
  • I'm definitly not a
« Reply #257 on: December 13, 2012, 10:11:02 AM »
Bob
It is how they are intended to be mounted!  To be fair about it, there is 8 clamps holding the the fairing bracket to the frame.  Very solid mounting.  Craig Vetter is a genius.  The support to hold the trunk lid open is a coil spring used as a rod.  The wind catches it and nothing brakes.  Closing the lid just folds the spring over.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Jay Ace
« Reply #258 on: December 13, 2012, 07:29:09 PM »
Cut original pipes, cut original MINT fenders (front and back), stripped and filled gas tank then covered in #$%* paint job, stripped (from over tightening) valve adjustment port covers, missing fuse box, ape hangers and who knows what else ...
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #259 on: December 13, 2012, 08:04:58 PM »
Think of a master link, the type with the removable clip used on final drive chains.  You know what I'm talking about, two pins welded to a side plate, push the pins thru the ends of the chain, add another side plate, hold it all together with a spring  clip.  Easy Peasy.
Now, imagine if you instead assembled it this way... Side plate with pins followed by the second side plate, push the pins thru the chain ends, hold it all together with the clip.
That's right, he/she has BOTH of the side plates one ONE side!  That poor little spring clip doing its best to hold the other side by itself!  The extra thick side gauging the case while your at it too!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #260 on: December 14, 2012, 04:08:43 AM »
My recent project also has quite a laundry list of things "not to do". So much so, that I would say the worst thing the P.O. did to my bike was the act of buying it in the first place....  :o
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline dummy
« Reply #261 on: December 14, 2012, 11:28:45 AM »
on my 75 when the #2 plug wire broke on the en that attaches to the plug he used a sheetrock screw to re attach it. but the dumbet was removing the airbox, leaving the carbs open, and letting it sit for 14 years. my motor looks awesome on the inside.
Offline CycleRanger
  • No comment about being an
« Reply #262 on: December 14, 2012, 12:39:49 PM »
could it be?  omg.
I'm having a hard time visualizing that..
Jay Ace
« Reply #263 on: December 14, 2012, 07:39:18 PM »
Front brake light was not coming on so I looked and saw this:
One wire was cut and it was just dangling like that. Not taped off or anything  :o
« Reply #264 on: December 15, 2012, 06:38:27 AM »
pic for mr ranger:
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #265 on: December 15, 2012, 06:43:20 AM »
confessions of a dirty dirty PO.
Hello boys, my name is Joe.....and I have done some bad, bad things.
I was the PO that used black ducktape to cover the seat on that CB550.
 I used the entire kit of Caswell tank sealer on that Dunstall tank (frigging thing weighs around 10lbs empty)
I was the guy that used cardboard and Bondo to fix that rocker panel on the 75 Dodge Dart Swinger.
I was the guy that tried to weld the rust on that International ScoutII, only to give up and use aluminum tape and bedliner to fill the hole.
sorry
Offline MoMo
« Reply #266 on: December 15, 2012, 06:45:31 AM »
pic for mr ranger:
Maybe he was trying out a new theory of cushioned breaking( I meant breaking rather than braking as there is a high possibility of breaking all your bones with that brilliant repair)...Larry
Offline CycleRanger
« Reply #267 on: December 15, 2012, 07:00:30 AM »
pic for mr ranger:
Ha ha! That's actually kinda clever, in a way. Somebody put some thought into that!
« Reply #268 on: December 15, 2012, 08:03:36 AM »
Offline MoMo
« Reply #269 on: December 15, 2012, 08:11:11 AM »
This thread reminds me of this website.....
http://failblog.cheezburger.com/thereifixedit/tag/motorcycle/page/4
That's a good one, seen many of the photos but not all in one site.  Amazing ingenuity ::)...Larry
« Reply #270 on: December 15, 2012, 08:18:10 AM »
 Jay that wire is likely not cut, they break sometimes.
.The. Schrader valve in the back brake is scary, not much shear strength in brass. The original should have a shoulder , so that threads are not in shear.
Jay Ace
« Reply #271 on: December 15, 2012, 08:27:46 AM »
I neglected to mention that whoever noticed it before me, took the time to push it out of the way behind the tank. They knew it was like that. Right circumstances that could have cause a big fire.
« Reply #272 on: December 15, 2012, 08:44:20 AM »
I just taped mine back together to make it look connected..cold weathercriding is hard on them, Not sure it could start a fire..easily..
Jay Ace
« Reply #273 on: December 15, 2012, 04:32:32 PM »
That bare wire touched the frame and threw a giant spark ... right under the tank.
« Reply #274 on: December 15, 2012, 06:53:08 PM »
A giant spark from a brake light wire? If that's the case, you've got a major electrical fault mate...........  ::)
