Author Topic: Garbage Rebuild  (Read 38601 times)
torchmonkey
Re: Garbage Rebuild
« Reply #100 on: February 06, 2010, 10:21:27 AM »
I pruchased Yamaha Bond to seal the cases (I know, sacrelige), do I need to use anything on any of the gaskets or just dry?
Offline theofam
  • I'm cold, give me a
  • Suffering from MDD - Mechanical Deficit Disorder
Re: Garbage Rebuild
« Reply #101 on: February 06, 2010, 12:11:27 PM »
I don't know if you've seen this link yet, but there are some great manuals online.  Look in this one, and check out Fig 89.  I think it has some of your o-rings you're looking to identify.  You can probably search the pdf for "o-ring" and come up with most of what you're looking for.
http://data.sohc4.net/SM500/HSM500550_2.pdf
torchmonkey
Re: Garbage Rebuild
« Reply #102 on: February 06, 2010, 12:42:56 PM »
Thanks, how's that blaster workin'?
Offline theofam
Re: Garbage Rebuild
« Reply #103 on: February 06, 2010, 04:18:47 PM »
Good so far.  I've only done one carb bowl.  This coming week I've got rebuilding the carbs as my # objective.  In what order did you clean up yours?  Blast first, soak in simple green?  Lemme know.  Any time I can save would be much appreciated.
torchmonkey
Re: Garbage Rebuild
« Reply #104 on: February 07, 2010, 04:29:20 PM »
I cleadned all the major crud off the bodies and bowls inside and out rinsed them in vinegar, then ultrasonically cleaned everything in Simple Green Heavy duty (the purple stuff @ Home Depot). I would not reccomend using this stuff on anything  steel though, wierd things will happen to the finish.
Offline theofam
Re: Garbage Rebuild
« Reply #105 on: February 11, 2010, 04:43:26 PM »
I don't have an ultrasonic cleaning system, but I did soak everything overnight in the purple Simple Green.  It did a good job knocking off the grime, then I soda blasted the carbs, and neutralized the soda in vinegar water.  They're looking pretty good!  Hope to assemble the carbs tomorrow to check another minor project off my list.
I realized, after sending you the link to the manual, that I'm a total tool.  Sorry for sending you a 550 manual when you're building a 750!
torchmonkey
Re: Garbage Rebuild
« Reply #106 on: February 16, 2010, 02:45:16 PM »
OK, I need (2) "392" pistons to complete my engine build, any leads would be greatly appreciated.
lunchandmurder
Re: Garbage Rebuild
« Reply #107 on: February 24, 2010, 09:24:40 PM »
with the motor painted doesn't over heating concern you being that its an air cool motor?
torchmonkey
Re: Garbage Rebuild
« Reply #108 on: February 25, 2010, 05:09:22 AM »
Seriously?
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: Garbage Rebuild
« Reply #109 on: February 25, 2010, 05:26:24 AM »
I think he's kidding.
Re: Garbage Rebuild
« Reply #110 on: February 25, 2010, 05:42:07 AM »
I remember back in the day very serious conversations about heat and painting a motor. WHich of course is a little silly as the factory painted them. It really got "heated" when talking about painting black as black would hold the heat in.
Never any proof one way or the other and the factory was doing it so WTF.
  • Like a well oiled
    • Undead Asphalt
Re: Garbage Rebuild
« Reply #111 on: February 25, 2010, 06:11:08 AM »
I think the protection from the elements outweighs any alleged heat difference
torchmonkey
Re: Garbage Rebuild
« Reply #112 on: February 25, 2010, 06:14:38 AM »
I would hope he's kidding.
Offline The_Crippler
  • Work in progress.
Re: Garbage Rebuild
« Reply #113 on: February 25, 2010, 06:28:27 AM »
"Back in the day"?   ;)  You still see that one come up with a vengeance every now and again.
lunchandmurder
Re: Garbage Rebuild
« Reply #114 on: February 25, 2010, 06:53:27 AM »
i dont think it will cause a problem, its a common argument with myself and some buddies just getting your opinions and arguments to help me in my battle against them. lol
Offline mystic_1
  • 1970 CB750K
Re: Garbage Rebuild
« Reply #115 on: February 25, 2010, 07:45:42 AM »
Consider this, many motorcycle engines (HD comes to mind) are powder coated nowadays.  Powdercoat being thicker than paint, I figure that if that's OK than paint is OK too.
mystic_1
- John Augustus Shedd
Re: Garbage Rebuild
« Reply #116 on: February 25, 2010, 07:54:33 AM »
Yeah, well when we can no longer brag about current achievements, etc. we revert to reminiscing.   ;D
"Back in the day" for me is the 70s, the era of the SOHC4, and I was there.
In the 70s it was becoming the thing to paint engines black, so the conversations came up. I can remember motorcycle magazines with technical articles about it, etc. Like so many things, a non-issue to me.
The factories would often pick up on what the customizers were doing and incorporate them into factory models. Hence the black factory engines late in the 70s.
There were black cylinders on Triumphs and such in the 60s, but they were cast iron, so not apples to apples.
I say paint (or powdercoat-Mystic) whatever you want. If you ride it enough afterwards to indicate overheating good for you.
Re: Garbage Rebuild
« Reply #117 on: February 25, 2010, 07:57:16 AM »
You are aware that YamaBond has been known to react with the special Honda aluminum alloys? A very serious situation so be careful.
JK   ;)
  • Work in progress.
Re: Garbage Rebuild
« Reply #118 on: February 25, 2010, 08:30:11 AM »
In the 70s it was ...
Yes...and I just meant that I still see that argument played out the same way today.  It never seems to go away.
torchmonkey
Re: Garbage Rebuild
« Reply #119 on: February 25, 2010, 07:06:57 PM »
Currently rebuilding my wheels, they're ready to be laced etc.. I was gonna press the bearings back in in the morning. Do the balls face out or is it the plastic piece that faces out? I thought I was being very thorough but this is one thing I did not take photos of. Note to self: do not slack on the documentation!!!
torchmonkey
Re: Garbage Rebuild
« Reply #120 on: February 25, 2010, 07:18:42 PM »
About the Yamabond... when I showed up @ the shop they actually gave me hondabond to my surprise, so no disintegrating cases here, I hope!!! I'm more nervous about putting the cases back together than I was about splitting them?! I've actually done 3 dry runs just to make sure the transmission works correctly.
I'm gonna slow down o this project and do it RIGHT. Stopped by my neighbor's the other night to borrow a chainsaw and he offered me his Suzuki GS1100 for FREE, so, that is the bike I'll be riding until the CB750F is done properly (to my liking, that is). Looks like an early '80s model, I think, hey who cares, it's free!!! I'l post pics when this crazy storm passes and we can push it into my studio.
  • Like a well oiled
    • Undead Asphalt
Re: Garbage Rebuild
« Reply #121 on: February 25, 2010, 07:43:34 PM »
plastic seal face goes out.
  • Like a well oiled
    • Undead Asphalt
Re: Garbage Rebuild
« Reply #122 on: February 25, 2010, 07:44:22 PM »
that was a joke :D
Offline greasy j
  • lanesplitting
  • non serviam
Re: Garbage Rebuild
« Reply #123 on: February 26, 2010, 01:15:58 AM »
I think the upper left mystery gasket is for the points/E.I. cover. I'm takin my engine apart now, and keep noticing those lil o rings everywhere. they are tricky to label, eh?
torchmonkey
Re: Garbage Rebuild
« Reply #124 on: February 28, 2010, 07:11:32 PM »
My neighbor GAVE me this today, totally not my style but, you can't go wrong with free. I can somehow make it look good, I think.
