Author Topic: CB750A Street ET bracket drag bike. A year to build it.  (Read 619053 times)
Offline Bill/BentON Racing
    • BentON Racing
Re: CB750A Street ET bracket drag bike. A year to build it.
« Reply #2950 on: October 11, 2012, 11:26:01 AM »
Frank,please do!!!!! Not 10's this year,but 11's hopefully Sat! ;D Jon,as always,thanks for the input. ;D I think I call you(Frank) tonight.Bill Have the pieces,let's try at least,but I still like foot arrangement,did Chad use a linelock? Frank,think,we'll try to duplicate your arrangement.You ain't getting off that easy!! ;)
BentON Racing Website
BentON Racing Facebook
Offline dragracer
  • CB750F Dragbike
« Reply #2951 on: October 11, 2012, 11:49:42 AM »
My set up uses a stock Kaw rear master cylinder. I welded an arm on my stock brake lever to attach the pneumatic, single acting cylinder. The other end of the cylinder is mounted to a bracket i bolted to my swingarm. Obviously, the longer the lever rotating on the arm, the more pressure you can exert. Maybe you could even consider mounting the cylinder perpindicular to the brake lever and let it push down just as you would do with your foot. Lots of ways to skin this cat and you already have the parts. You could even use the horn button as the momentary switch if its still on the bike. At 140psi, that single acting cylinder will exert more pressure than your foot on the pedal unless you intend to stand up on the pedal with all your weight. Not sure how you would balance the bike like that-lol.
I assume you still have the stock rear master and brake pedal???? Stock works better than aftermarket in my experience.
Look back at those pictures of my set up i posted on this thread a while ago and then give me a shout. I probably deleted those pictures from the camera.
    • BentON Racing
« Reply #2952 on: October 11, 2012, 01:54:05 PM »
Stock parts.......like BRACKETS and such,you forgot Sam attacked the frame!!! ;) ;D I know Sammy,it's a race bike.Rear brake bracketry lost to Grinderman Sam!! ;D Oh,just another challenge! 8) Bill
Offline dragracer
  • CB750F Dragbike
« Reply #2953 on: October 11, 2012, 02:17:52 PM »
Don't forget to remove the MSD/Dyna ignition from the bike before any welding is done.
« Reply #2954 on: October 11, 2012, 02:50:18 PM »
Better put a kickstand bracket on there while you have the tig out.
    • BentON Racing
« Reply #2955 on: October 11, 2012, 07:44:23 PM »
Why would we go and do a thing like that for? ;) Sam,you owe me a double shot! been busy! ;D
Yep,installed!
A beautiful sight! just got thru installing fatter mains,127.5's. Bill
Offline dragracer
  • CB750F Dragbike
« Reply #2956 on: October 12, 2012, 05:36:52 AM »
Bill's been working hard.
Offline POPS 911
« Reply #2957 on: October 12, 2012, 03:58:24 PM »
CHAD INSLEY used a stock foot brake, rolled the carbs open a little, and pulled off = reason he won so many races and rounds was not the bike !!! It was his good eyes on the TREE = .00 - .01 - .02 - .03 and dead on dial in that got this BIG SMILE to the many final rounds at many big money races. I watched him beat CRAIG ADAMS of Ohio at a $10,000 , yes a ten thousand dollar PAUL GAST RACE at Norwalk with a perfect light .00. Craig rode back to the starting line on his bad ass BUSA WITH HIS RUN TICKET IN HAND with a .03 reaction time and 2 numbers off his 8.47 dial in = he ran 8.49 and lost. Chad ran .01 off his number and a perfect light. WINNER EVERTIME on 1320'.
Use a left front handelbar [ Gold Wing clutch unit 81-85 about  $25 on e-bay ] with a 28" SS brake line to the rear disc brake with a shift light to set RPM CREEP will work , SIMPLE.  It worked on a 10mm stroker BUSA [ ALL MOTOR ] 245 HP DYNO with slider, SCREWING THE THROTTLE OUT AT THE LAST BULB and auto shifting running 8.05 ET.  If this system can hold a 245 HP STOKER BUSA on the line or do you think SAM's HONDAMATIC has more power on the line than this BUSA ?????
POPS BK911
    • BentON Racing
« Reply #2958 on: October 12, 2012, 06:31:21 PM »
Pops,we'll see what we end up with.Thanks.we will know a little more tomorrow,getting ready to load it and Calendar Girl for the Nostalgia Drags @ Commerce tomorrow!!! ;).I'm trying for consistency with Samauto,Calendar Girl,I want an 11.xx slip!! ;D Gotta go load up!! 8) Bill
Offline Jim F
  • go baby go
« Reply #2959 on: October 12, 2012, 06:39:49 PM »
I will know this Sunday if the last bed in Wilbers room is taken
David Fletcher might ride down with us for the weekend
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
    • BentON Racing
« Reply #2960 on: October 12, 2012, 08:17:51 PM »
That would be way cool.Probably see Dave tomorrow! We are LOCKED AND LOADED! 8) Samauto fired rt up,it's ready,I think? ;) Calendar Girl has new(ok 27 yr old DynaS),one that works,sounds completely different! ::)Jim,I've already fueled them both! ;D Hope to get some good data,times and pics tomorrow.Bill
Offline dragracer
  • CB750F Dragbike
« Reply #2961 on: October 12, 2012, 09:27:40 PM »
Good luck down there Bill and Jim. Whats your prediction on Calender Girls 11.?? ET ????  11.50 maybe?? I can't seem to remember what she ran before.
    • BentON Racing
« Reply #2962 on: October 13, 2012, 03:20:47 AM »
12.252 best so far! 11.92 is my guess! ;) ;D Bill I'm off to check 'em out. ;D
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #2963 on: October 13, 2012, 07:00:04 AM »
Good luck guys. Our season starts again in... oh yeah, six and a half months  ::)
Offline Jim F
  • go baby go
« Reply #2964 on: October 13, 2012, 01:32:49 PM »
I hope so because your not getting to far down the track if you don't
Offline dragracer
  • CB750F Dragbike
« Reply #2965 on: October 13, 2012, 04:24:02 PM »
how about some update from the field??
    • BentON Racing
« Reply #2966 on: October 13, 2012, 08:49:23 PM »
OK,Frank.......................TEAM SAM GREEN IN FINALS OF STREET ET! Yes,TG,I'm shouting!! ;)
That's right,Samauto in the finals! 8)More tomorrow,but heres the 60 ft times for Samauto,in order
2.087,1.960!!!!!,2.047,2.076,1.949,1.931!!!!!,oh found my favorite,I knew there was one more!
Damn,12.262 on a 12.620 dial,Jon taught me that!! ;D,See that mph,did that oh about 3 times!! ::)
1/8,just the ones in the 7's! ;) 7.891,7.972,7.868,7.844,7.912. Was also making rds with Calendar Girl,but couldn't get back to bike in time for rd 3. :( Overall,the most wonderful day.Dave Fletcher won Pro ET,said tell Sam,he inspired me!! He did. ;D Oh until tomorrow, Samauto ran 12.183 in the finals!!!!! ;D 8) Tired Bill  ;D
Offline dragracer
  • CB750F Dragbike
« Reply #2967 on: October 13, 2012, 10:13:55 PM »
Hot diggity dog, you made some round my friend. A great day of racing intend. Congrats to you Jim and Bill, cudos to Mike, Jon and Sam. And did i read you made it to the finals?? We're cookin with gas now folk.
Offline bear
  • Leeton in Australia
« Reply #2968 on: October 13, 2012, 11:59:17 PM »
Nice one Billy.
Very good result. Although I have to admit all those numbers are goblygook to me. ;D
Brian
Offline voodooracer
« Reply #2969 on: October 14, 2012, 03:26:57 AM »
 My, my, my, that's some good racin' right there! Congrats to all! Wish I coulda been there to see it.
 This bodes VERY well for upcoming Valdosta race.
 Again, congrats on all the hard work! Can't wait for details.
Offline jweeks
« Reply #2970 on: October 14, 2012, 04:54:05 AM »
Bill,
     Going up against a 144 mph bike in the other lane, covering him by the finish line, getting on the brakes, and running just over your dial-in? You still got there first in spite of his breakout pass?  PRICELESS!!!!
     By my unscientific calculations, that was a 12.15 to 12.18 pass if you had not used the brakes.  It's very hard to dial in a bike without any history. Now we have a little information to work with. Bill, any density altitude information available for your excellent night?
     Frank, do you see any hope there? The bigger question - What kept the bike on the starting line? What brakes held it there for 1.9 60' times?? Do we have a working system for Valdosta?
     My last meet of the season for points is being rained/snowed out as I write this. Yes, it is snowing north of me right now. I need to get out of this cold weather. How does Georgia sound in November?   Sam, get ready for some fun! ;)
                                                         Jon Weeks
Offline Jim F
  • go baby go
« Reply #2971 on: October 14, 2012, 05:22:20 AM »
we are diffidently going to have a crew and some fun in November
I reserved 2 more rooms
Jim
    • BentON Racing
« Reply #2972 on: October 14, 2012, 07:15:38 AM »
Everyone,thanks! ;D VooDoo,I kept waiting to hear the crackle of Chainsaw! ;) Heres some more from last nite.
but,first,yes Jon,it was PRICELESS,oh but PAID $170.00 for runner-up! ;D The pass I posted was the one that got us in the finals! :o Samauto's second pass:R/T .068,60ft 1.960,330 5.241,1/8 7.891,92.86 mph 1/8,10.213 1000ft,12.219 1/4 2 111.57mph!!!! ;D ;D Quicker than ever and quicker than CG has a slip for!!
It was on this run I knew we were on to something,rememberI did say we were going for consistency on Samauto! So heres some 1/4 mph,s when I ran it w/out backing out! 111.57,111.73,111.57,110.75 on final run! I'll copy time slips and post Jon....No data except Bill's hand,head and azz!(By MYSELF) :(
Jon,yes leave it to you(compliment) to ask the REAL question....HOW?........Next post with slips and the SECRET!!!!! ;) ;D ;D ;D Bill
Offline dragracer
  • CB750F Dragbike
« Reply #2973 on: October 14, 2012, 08:11:21 AM »
My guess is you found out NOT to push the bike too hard against the converter. In other words, you found the spot that the bike liked, the sweet spot.
« Last Edit: October 14, 2012, 08:13:01 AM by dragracer »
    • BentON Racing
« Reply #2974 on: October 14, 2012, 09:14:26 AM »
 ;D ;D ;D ;D ;D ;D I did! Give that man a prize!  ;)Back in a little bit.  Bill
