Author Topic: CB750A Street ET bracket drag bike. A year to build it.  (Read 620849 times)
  • Moderator
Re: CB750A Street ET bracket drag bike. A year to build it.
« Reply #450 on: February 09, 2011, 07:55:23 AM »
Sir J, I know you are two hours in front of the UK, but don't you think it is a little early to be rat arsed. :D
Sam. ::) ;)
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #451 on: February 09, 2011, 08:54:30 AM »
Sam. ::) ;)
Don't tell my wife, I know you two are facebook friends  ::)
  • Moderator
« Reply #452 on: February 09, 2011, 08:58:45 AM »
Paula has nice eyes, It's a shame that's all you can see in her picture. (face that is) ;D ;D ;D
Sam ;)
  • Moderator
« Reply #453 on: February 09, 2011, 03:34:08 PM »
Skype me Billy, need my bed. ;)
Sam. ;)
Offline jweeks
« Reply #454 on: February 09, 2011, 04:23:53 PM »
Bill,
     Yes, got it done yesterday. More important question - when do the carbs go on?
                                          JW  ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #455 on: February 09, 2011, 07:50:48 PM »
Jon,soon,had to clean a little. ;)
Not bad,just old gas residue.
Will be back on Sat. or Sun. Needs some new hardware,idle screw,etc. ;D
We're getting there.Big Jim has billet arm finished. 8)
More tomorrow.Bill
BentON Racing Website
BentON Racing Facebook
Offline jweeks
« Reply #456 on: February 10, 2011, 01:27:52 AM »
Bill,
     Perhaps a little in the bottom of the bowls only. Nice shot of the rewelded carb mounts. Lots of little areas of rework to make them work. Want to hear how easy they go on  ;D ;D ;D. Sam's already calling for holy help. Suspect you will also on the first attempt. Carbs should be very close. Might want a little more gas on the main jet, but let's hear it bark first. Anyone who thinks that they can get carbs perfect for a modified motor on the first shot should be the person that Sam's trying to talk to.  ;) Remember what I posted earlier for mounting. The manifolds aren't too flexible. Warmer is better (but below melting points!) They last longer than the stock ones. Don't remember if I got all the clamps; I tried to. Should be a happy motor!
        JW
    • BentON Racing
« Reply #457 on: February 10, 2011, 03:24:09 AM »
K. ;D ;D ;D ;D.Jon,thanks,hope you feeling better.Bill
    • BentON Racing
« Reply #458 on: February 12, 2011, 07:03:47 PM »
Sam,Jon,maybe this'll make you feel better.They go on in the morning! ;)Gentle persuasion! ;D
Haven't been able to work on it all week.Big Jim coming back by tomorrow.Hope to fire up next Sat. :o
We/ll see how this week goes.Bill
Little better.
Wish us luck! ;) ;D
Lots of progress we hope tomorrow.Bill
Offline jweeks
« Reply #459 on: February 12, 2011, 08:18:50 PM »
Bill,
     It shouldn't require choke for too long. If it's still on after around 30 seconds, the plugs are getting rich. (The only thing in this build that is  ;)) An idle stop for ~1200/1300 rpm should be as low as you set it. You need enough rpm at idle for it to want to creep forward. It will happily idle lower but you'll need the creep to stage the bike. A lower idle may rock the bike backwards as you come off of the gas and apply the brake. You want this motor to always want to go forward. It will prevent rookie mistakes in staging the bike. The increased advance from the points plate replacement adjustment for this larger displacement motor will also increase the idle. Intake manifold leaks can be easily found with something under pressure that increases or decreases combustion. If you seat the tubes evenly, they never will leak. Even if a clamp is a little loose, the tubes usually stay sealed. Make sure that nothing near the intake side can be sucked in. (tape, twine, wire ties, wires, etc.) Don't forget the return spring from the linkage to some point on the motor to overcome the tendency to high idle without it. Are you using a quarter turn throttle? For racing this bike, the throttle is mostly run as an on/off switch. The only time that you use part throttle is on the return road. It will be kept under ~1,800 rpm on the return road to avoid attention returning to the pits. A quick throttle may spook a road racer a little, but it works best for quickly opening the carbs as the tree starts counting down. Loading the converter for over 1.5 seconds just heats the oil and slows down the bike. Even if you don't get the maximum rpm under load that the bike is capable of, you will have far better consistency. Test and tune will open your eyes on what you've created. Clamps on fuel line ends are also usually required at tech inspection. You have to use a little overlength gas line to feed the carbs. They can vibrate around some and even pull off a tightly clamped feed line at the worst possible time. ( Yes, I've lost a final when the feed line came off in the burnout box. The clamp was still on so tight that I couldn't reattach the line until I increased the diameter of that clamp back in the pits.!) That's where the fuel shutoff valve came in handy. The down side of that is that you can start, run, stage, and make it halfway down the track with the fuel valve shut off. The fuel bowls will use up almost every drop before you get the warning that somebody forgot to turn the fuel on. (Another reason that I'm not trying to be a crew chief. That person will be blamed for almost all those fun lessons on how to lose - even without an opponent! ;D) It's getting time to hear that motor! A short video clip with sound will cause international spring fever!
        JW
  • Moderator
« Reply #460 on: February 13, 2011, 02:26:15 AM »
 :D :D :D :D Hey young Jonny, you're going to get blamed for whatever goes wrong ;D you're the MAN. :D ;)
Well done Billy and Jim, you're doing a stirling job. 8) 8) 8)
On a brighter note guys, the teams polo shirts are with the guy that's doing the embroidery. 8)
I had hell of a job finding a tent to fit Jimmy. I found Mohamed on Bury market but he said he had lost the patern for the last tent he made for you. Anyway Jimmy, he sends his regards and just took a gues at the size, same goes for Frank and Keith. ;D ;D ;D I think I have you all covered. ::)
Billy, try to call me on Skype around mid day or afternoon your time, it's Sunday and I have all day to myself. ;)
Sam. ;)
    • BentON Racing
« Reply #461 on: February 13, 2011, 01:07:48 PM »
Sam,Big Jim says 3x.Look carbs about to go on.
Big holes,Michael!
Carb installation tool! ;D
Carbs on....................Took 2 minutes,ok 20 minutes ,ok 2hrs,2 people and special carb tool 2x4, ;) ;D
Carbs on and billet brake arm.Good work Jim!
Big Jim @ work! :o 8)
Left side.
Chainguard almost there. 8)Bill
  • Moderator
« Reply #462 on: February 13, 2011, 03:16:56 PM »
Fantastic job Billy, perhaps you know now why you were the chosen one. 8) 8) 8) ;)
Big thanks to Jimmy also, got a little surprise coming for you. ::)
It's getting close to count down time and I'd like to thank ALL involved, you're the best. 8) 8)
Sam. :'( emotional.
« Reply #463 on: February 13, 2011, 04:08:14 PM »
You boys almost have a bike!  ;D
    • BentON Racing
« Reply #464 on: February 13, 2011, 05:54:21 PM »
 :) ;D
Jerry,yes,we do. 8)
More Pics
Makes you wanna go racing! ;D
The view we hope the comp.sees.
The left side.
Special Carb Tools! :)We hope to crank next Sat. or Sun.Bill
  • Moderator
« Reply #465 on: February 14, 2011, 05:02:32 AM »
Mike, do you recall what the model was of the Earls oil cooler ?
Sam. ;)
Offline dragracer
  • CB750F Dragbike
« Reply #466 on: February 14, 2011, 08:14:46 AM »
Nothing makes you more excited on a fresh build than installation of a shiny sidewinder and a set of carbs. You can just feel whats around the bend 8)!!!!
Great job Mr. Mechanic.
  • Moderator
« Reply #467 on: February 14, 2011, 08:36:29 AM »
Problem is Frank, the bend is thousands of miles away :D :D :D I feel lost and left out. :(
Got you and Keith a team shirt for all your help and advise, had to guess at your size as being around the same as me (L) Keith looks to be tall so got him XL. ???
Sam. ;)
Offline voodooracer
« Reply #468 on: February 16, 2011, 04:31:02 AM »
 Ahh, you shouldn't have, Sam. Thanks for the shirt. This project is really coming together. Kudos to all contributors, that is one fine hunk of motorcycle! Can't wait to see it, smell it, hear it at the track!
  • Moderator
« Reply #469 on: February 16, 2011, 04:39:50 AM »
That was good timimg Keith, the embroiderer has just phoned to let me knw they are ready. 8)
Three weeks and counting. :D
Sam. ;)
Offline dragracer
  • CB750F Dragbike
« Reply #470 on: February 17, 2011, 12:45:26 AM »
I appreciate the jesture Sam. I will wear mine proudly.
  • Moderator
« Reply #471 on: February 17, 2011, 01:45:11 AM »
Frank, when you are stuck thousands of miles away you feel kinda helpless. When all ya mates are busting their balls to make it all happen, it's the least I could do to show MY appreciation.
Sam. ;)
    • BentON Racing
« Reply #472 on: February 17, 2011, 04:55:21 AM »
Sam. ;)Oh,we could really feel your moral support from acoss the pond when Jim and I installed those carbs!!!
Yeah,Jon was laughing in the background.They don't need those clamps,they SNAP into place!! ;) ;D
Almost finished wiring last night,except for rest of Dyna 2000.Tonight,hopefully.Sat. or Sun. IC! 8)Bill
Sam,it will be fun. ;D
Offline dragracer
  • CB750F Dragbike
« Reply #473 on: February 17, 2011, 08:43:21 AM »
Sam. ;)
I wish i was close enough to lend a hand in assembling the bike but it seems your mechanic is moving along quite well all by himself.
  • Moderator
« Reply #474 on: February 17, 2011, 08:56:42 AM »
It's funny Frank, all the people that I have met from this forum, I met them on line before meeting them in person. You are the exception despite living thousands of miles away.
For members reading this, I met Frank when we were both racing at Piedmont NC in 2008.
I was racing member Dusterdudes CBR600F3 and we were walking round the pits with Rob (rocking-M)
when we came across this very nice CB750F drag bike belonging to Frank. After that we kept in contact through Dragbike.com and eventually, Frank joined us in here. Here's to a few beersin a few weeks time. ;)
Sam. ;)
« Last Edit: February 18, 2011, 06:45:46 AM by SamCB750A »
