Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Settled in back home and all is as well as it could be but having problems with my body clock.If that's the only problem, I should be ok. Sam.
No drinking, smoking and I can't even drive my car for a good while.
Stick with it Sammy you'll come good, your a tough old bugger.The way I look at it, you and I might be dragging our arse's a little but it's better than the alternative. Have they done one of those neuro-phsiyc tests on you yet?Cheers, Brian
Quote from: bear on July 30, 2014, 04:03:20 pmStick with it Sammy you'll come good, your a tough old bugger.The way I look at it, you and I might be dragging our arse's a little but it's better than the alternative. Have they done one of those neuro-phsiyc tests on you yet?Cheers, BrianStart the tests next week Brian, it's just such a bind not being able to do anything.Sam.
sam let me know if you fancy some company , will bring cakes !
