Author Topic: CB750A Street ET bracket drag bike. A year to build it.  (Read 635681 times)
Offline Jim F
  • go baby go
Re: CB750A Street ET bracket drag bike. A year to build it.
« Reply #4700 on: February 05, 2015, 06:46:10 PM »
Love the new avatar Jim! How'd the dyno wind up? You done?
It's never done
Replaced the regulator/rectifier
Changed oil/filters
Re-jetted mid range and bottom
End, and made adjustments on the
Clutch
Need to re-route the breather hose
Phoned Brian Livingood today and should be
Ready for round two on the dyno next week
And I just bought this and my old receivers won't fit
And yes I like my new truck
« Last Edit: February 05, 2015, 06:53:32 PM by Jim F »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #4701 on: February 05, 2015, 07:54:57 PM »
Nice truck!! LS3 under the hood? Maybe you should show up with Bill on Wednesday.  ;) Brian has a sweet setup.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #4702 on: February 05, 2015, 07:58:56 PM »
Nice Jim,  I gotta call Brian and book time tomorrow,  Bill
BentON Racing Website
BentON Racing Facebook
Offline Jim F
  • go baby go
« Reply #4703 on: February 06, 2015, 03:22:12 AM »
Duramax deisel 4x4 2500
« Reply #4704 on: February 06, 2015, 04:36:07 AM »
4X4......you plan on 3 feet of snow brother? ;D
Offline Jim F
  • go baby go
« Reply #4705 on: February 07, 2015, 05:05:23 AM »
Just to come up and get you
Out of the snow
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #4706 on: February 07, 2015, 05:48:08 AM »
wow, i like your new truck too 8)
Offline jweeks
« Reply #4707 on: February 15, 2015, 12:50:10 PM »
     Having braved a break in the snow, I talked with Mike R. a week ago. One topic was on stock Hondamatic fibers in the clutch pack. When you load the motor against the rear brake to drag race a Hondamatic, the fibers in the low gear clutch pack take a lot of stress. The results are that you get a lot of loose fibers in your oil. Frequent oil changes help to minimize the amount of fibers floating around. If they hang around too long, you can see wear on the skirts of the pistons. Racing 1/8th mile, I always have changed the oil every three meets. If I were to go quarter mile racing, the frequency would be more frequent.
     I'm now using the Honda civic car clutch packs in my drag hondamatics. Do they work better than the bike factory packs? Ask me again after a few events this summer. (If it ever comes ...  ::))
« Reply #4708 on: February 15, 2015, 02:21:09 PM »
Jon,
Hope to ask you in person  ;D ;)
Offline bear
  • Leeton in Australia
« Reply #4709 on: February 15, 2015, 02:27:18 PM »
Can't get that truck down here Jim, but I did manage to get hold of one of those big diesel motors.
So I jammed it into my Landcruiser.  ;D
Brian
« Last Edit: February 15, 2015, 02:28:50 PM by bear »
Offline Jim F
  • go baby go
« Reply #4710 on: February 15, 2015, 08:22:43 PM »
How on earth did you do that?
Offline bear
« Reply #4711 on: February 16, 2015, 02:58:46 PM »
I was stuck in a wheelchair with to much time on my hands. ;D
Could have used your help with the engine mounts though.
Brian
Offline Jim F
  • go baby go
« Reply #4712 on: February 16, 2015, 07:02:58 PM »
To bad I am not next door or even down the street
Offline ThomasD883
« Reply #4713 on: February 17, 2015, 01:57:39 PM »
Is that a Chevy  Duramax what 6.6l i think? I work Cummins by trade and would stick a 5.9 or 6.7L B-engine in a Toyota Landcruiser if price and rust played no part. Million mile motors, but from what I have heard the Chevy V-8 Diesel is fairly robust 'cept for a few years where the injector seals would give and fill the crankcase with fuel. Worked with a Asphalt paver that got his warrantied at 200k miles for the third time  :o
Diesel deeds, done dirt cheap
    • BentON Racing
« Reply #4714 on: September 01, 2015, 08:48:15 PM »
It's time for Samauto II. So I'm going to add to this thread. It's where it all started for me! Thank you Sam Green!K.
Replaced throttle with 1/4 turn Tommaselli,  new grips and relocated in my face the air tank pressure gauge.Fitting CBX750 Australian carbs now, Using 77/78K boots. Needs a Sam Green approved tach, different front M/C. Different tires front and rear.Starter motor and pieces. Cleaned off stickers and numbers on body work today. Like what I'm seeing, mucho potential! Bill Goutta replace lh switch assembly also.
« Last Edit: September 01, 2015, 10:20:41 PM by Bill/BentON Racing »
Offline hotdog
« Reply #4715 on: September 01, 2015, 09:19:25 PM »
Billy boy - move choke lever from centre to outside l/h side. No cable and easily flipped by hand when needed....
Like so -
Instagram - Lumpy Cam Motorcycles
FB - Lumpy Cam Motorcycles
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
    • BentON Racing
« Reply #4716 on: September 01, 2015, 10:21:39 PM »
Dale, thanks,  Bill
  • Moderator
« Reply #4717 on: September 02, 2015, 03:05:36 AM »
Like I said before, let's have a 10 second Auto to shut these two up.  ;D ;D ;D ;D ;D ;D ;D
« Reply #4718 on: September 02, 2015, 09:56:15 AM »
Hey Sammie, never heard, did you get your license back? Sounds like you are returning to the same old buzzard we know.
  • Moderator
« Reply #4719 on: September 02, 2015, 11:51:56 AM »
I'm still the same old buzzard that you Don't know Jerry, still waiting on the licence mate.
The time is up for when they said I should have it. Not sure why. ?????
Sam. ;)
« Reply #4720 on: September 02, 2015, 11:56:19 AM »
Government!
  • Moderator
« Reply #4721 on: September 02, 2015, 01:02:18 PM »
Probably Jerry mate, it's called RED TAPE in the UK.
« Reply #4722 on: September 02, 2015, 04:09:51 PM »
Thats funny Sam..?  Its called "#$%* bureaucrats" here in Australia.... ;)
Offline dusterdude
« Reply #4723 on: September 02, 2015, 04:13:02 PM »
Hang in there sammy
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
  • Moderator
« Reply #4724 on: September 03, 2015, 02:15:58 AM »
"#$%* isn't even a word in the UK Mick, hahahaha.
