Author Topic: Project Anna-CB500  (Read 47160 times)
Offline Bluegreen
Project Anna-CB500
« Reply #100 on: July 19, 2012, 10:47:39 PM »
Lesters!! I've only been around a few blocks on them but feel vastly different than the stock wheels, I was quite surprised. The difference between 1.85 and 2.15.
Re: Project Anna-CB500
« Reply #101 on: July 20, 2012, 04:58:31 AM »
Those lesters look great blue.... ;)
Offline Bluegreen
« Reply #102 on: July 28, 2012, 10:07:06 PM »
I posted this on the main board , but I know some pretty knowledgeable people have posted in this thread so I figured I'd give it a go here as well... ;D
Hello all, once again asking for some collective wisdom from the mighty sohc.net.
So here is the problem, as I am coming to a stop, the moment before the bike comes to a complete stop there is a shimmy/slight chatter coming from the front end. At high speed no problems, just that moment before stopping.
I recently swapped my stock wheels for Lesters and the problem started after the swap. I guess my thoughts are either a brake issue ( I have dual discs and maybe one of them is slightly misaligned now, or a pad is loose after the swap) or axl/bearing problem? The bearings did seem A OK. Maybe somebody out there has had this issue before and can say "oh yeah, this is your problem, I had the same thing"
The bike is the one in my avatar, '72 CB500.
Any help/thoughts/suggestions would be awesome! Thanks !!
PS Thanks RR!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #103 on: July 28, 2012, 11:07:15 PM »
Just read this thread.. and its amazing. Hope you get that wobble taken care of. I had that problem once but it was bad stem bearings.... But as far as your bike im not sure. Anyways good luck and greatbike
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #104 on: July 29, 2012, 04:35:57 AM »
Can't blame loose spokes.  ::) It's actually some kind of metallic chatter, not just a wiggle? Normally a misaligned disc would show itself at higher speed through lever feedback. I suppose if a pad or plastic washer (if you use them) wasn't seated correctly it could produce something wierd. Otherwise I've seen a slow wiggle produced when the tire isn't seated around the bead evenly, but no chatter there.
You probably should have replaced the bearings for your piece of mind and is one of the first things that came to mind.
Those Lesters look good man.
Offline Bluegreen
« Reply #105 on: July 29, 2012, 01:30:46 PM »
Yeah, I forgot to add that if I come to a stop with back brake only, no funny business. I am going to put new bearings in these wheels when I get new tires put on, not doing it in the first place was probably a mistake. I just get so excited you know ?!?!
Offline onlyfinol
« Reply #106 on: July 29, 2012, 02:53:27 PM »
Nice build ! I am working in my CB500 as well very similar to what yours used to look like. Could you please let me know what rear sets did you get, or where to get them ?I will appreciated !
Regards,
JFinol
Offline Bluegreen
« Reply #107 on: July 29, 2012, 11:27:01 PM »
So it turns out it was bad rotors. Drilling them myself has been the source of a few problems. I threw another set on that weren't drilled/glazed. Chatter gone.
@onlyfinol Thanks!! This is where I got my rearsets from http://www.fastfromthepast.com/servlet/the-112/Rearsets--Fixed-Rubber/Detail
« Reply #108 on: July 30, 2012, 05:47:59 AM »
Bluegreen I recently bought a flexhone for rotors because the rotors on my racebike were badly glazed. I still had one thick spot on one rotor and these hones work very well. It takes a little effort to set them up correctly to follow their instructions but I like the results. The hones are not meant to remove much material, but they do a nice job deglazing and will work on "high spots" on the disc surface.
Bead blasting is a good way to deglaze as well.
Offline onlyfinol
« Reply #109 on: July 30, 2012, 11:40:59 AM »
Thanks for the link !
[/quote]
Offline Mcwilliams570
« Reply #110 on: August 11, 2012, 06:26:16 AM »
Great looking bike. Do you have a link on where you got that fairing from. I have been looking at the MV Agusta fairing but cant seem to find the one that you have.
Thanks Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Bluegreen
« Reply #111 on: August 13, 2012, 09:16:51 PM »
Thanks Matt
Thanks!
Mine is MV Agusta as well.
This is the guy who made my fairing, he is awesome to deal with. From the time I ordered I had the fairing at my door in under two weeks from Holland at a very reasonable price.http://www.harrievanderkruijs.nl/interest.htm
Offline Mo
« Reply #112 on: August 13, 2012, 10:26:07 PM »
Love the paint job on the bike. Can you post a step by step on how you did it?
Offline onlyfinol
« Reply #113 on: August 15, 2012, 07:52:51 PM »
Does he speak English? how could you mange to read anything in his web?? :-\
Offline Bluegreen
Project Anna-CB500
« Reply #114 on: August 15, 2012, 08:58:14 PM »
I didn't lay the paint on, my dads talented friend did that, but I did the rest.
Step 1. Fill in all the pinholes.
Step 2. Primer/sealer
Step 3. Lay on the blue.
Step 5. Spend weeks agonizing over the stripe angle while the fairing is on the bike. Remove fairing take it 6 hours away from the motorcycle and make a really good guess as to where the stripes are situated.
Step 6. Tape off stripes.
Step 7. Spray on yellow
Step 8. Realize you forgot the stripe on the front between the headlights, curse, tape it off and spray yellow again.
Step 9. Marvel at how it looks like the Swedish flag...
Step 10. Spray clear
Step 11. I used 1/4" masking tape along the edge of the fairing and stripe as a guide for the pinstriping.
Step 12. Brush paint the inside black.
Offline Bluegreen
Project Anna-CB500
« Reply #115 on: August 15, 2012, 09:00:10 PM »
Yup, his English is way better than my Dutch :) I just sent him an email and asked a few questions. The guy ruled, from the first email to the fairing sitting in my living room was something like 2 weeks.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #116 on: August 15, 2012, 09:25:14 PM »
Looks fantastic.
Would love to see it close up.
Cheers
FJ
Offline Bluegreen
« Reply #117 on: August 15, 2012, 11:04:50 PM »
Looks fantastic.
Cheers
FJ
Thanks! Sounds cool. PM sent
Offline fastbroshi
  • Puppet
« Reply #118 on: August 16, 2012, 12:19:18 AM »
You can take a website that's portrayed in a foreign language and put the address in Google's page translator to get it to show in English.
Just call me Timmaaaaay!!!
Offline onlyfinol
« Reply #119 on: August 17, 2012, 09:30:06 PM »
Wow, that is efficiently fast !
Was it expensive, if you don't mind to ask you?
Offline Bluegreen
Project Anna-CB500
« Reply #120 on: August 26, 2012, 03:16:41 PM »
No, not expensive at all. $250-260 cdn as I recall, and that was with shipping from Holland.
Offline Bluegreen
Project Anna-CB500
« Reply #121 on: August 26, 2012, 03:17:44 PM »
Apparently I should have included rubber in my mounting system....
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #122 on: August 26, 2012, 08:53:43 PM »
Awe, that sucks.
Casualty of our Squamish rip no doubt.
Offline Bluegreen
Project Anna-CB500
« Reply #123 on: August 26, 2012, 09:59:06 PM »
Awe, that sucks.
Ha! Yeah it no doubt contributed. It was a good rip though!! We should go for another one soon, I've got zip ties.
The final straw was that stretch from Pemberton to Whistler today.
It's all right, the new cooler shipped already and I've got a plan :)
« Last Edit: August 26, 2012, 10:03:58 PM by Bluegreen »
Offline onlyfinol
« Reply #124 on: August 27, 2012, 08:01:31 PM »
Can't beat that ! Thanks
