Author Topic: '80 CB650 Custom  (Read 1005 times)
mrfreyguy
'80 CB650 Custom
« on: November 25, 2009, 06:17:37 AM »
Im new here and I have a 1980 CB650 that needs some TLC. It came without the coils, electrical switches, regulators, and carbs. The guy I got it from gave me some carbs from a 1980 Suzuki GS 550L but im geussing these wont work. Everything turns freely and she shifts through gears nicely. Could you guys tell me what parts I ned to get her started??? Also will these carbs work?  http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220515241356&ssPageName=STRK:MEWAX:IT
Offline cb650
Re: '80 CB650 Custom
« Reply #1 on: November 25, 2009, 01:14:57 PM »
Soo's did it by changing the isolators but directly no.    Youll need 79/80 to be easiest.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #2 on: November 25, 2009, 02:25:05 PM »
I have parts for the 79/80 carbs.  I might also have some coils, igniters, and rec/reg and I do have a 2nd set of controls.  Let me know what else you need.
I could setup the carbs for you as well.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline MickeyX
« Reply #3 on: November 25, 2009, 09:38:45 PM »
No, those '82 carbs won't fit your '80 as they are CV carbs with different spacing from the engine. They were only the same on the '79 and '80 models, PD carbs. We, along with mlinder, have contemplated putting on a set of the GS550s to see. It's supposed to be the same spacing and they are much easier to work on, rejet and get parts for. We haven't done it yet. These are still working and I try to not fix stuff that ain't broke.  :D If you try them, please let the rest of the CB650 crowd know. The carb kit pricing and lack of adjustability of the stock ones are worth trying the carbs you have, just to see.
Like cb650 said, you would need to come up with offset isolators for the '82s and that is hit or miss unless you have a bunch of different ones laying around to play with.
That year was the inbetween bike when they were switching stuff over and it has some last year and some next year stuff on it. I know it sucks. We have 2 of them.  ::)
The coils, switches and R/R should be the same for '79-82 and also comparable to some other sizes of bikes of those years. Personally, I would go with an aftermarket R/R from Oregon Motorcycle Parts. Tony Weeks has great products and guarantees them for life. The original R/R needs really high revs just to start to charge your battery. Tony's starts at just above idle. These 650s were on the bitter edge of enough charge to begin with, even new. If you need one anyway, I'd go that way and do it right. It's plug and play and he will talk you through it if you need it. The charging systems are the biggest single gripe of these models. Coils can be had at a decent price on feebay as can the switches but I'm sure there are some on here who could hook you up too and are very knowledgeable on this particular model.
good luck!!  :) :)
mrfreyguy
« Reply #4 on: November 26, 2009, 06:34:48 PM »
Ok so I could try and use the carbs I have. Are the 550's carbs close to the same jetting? kslrr I PM'd you with the stuff I need.
Offline MickeyX
« Reply #5 on: November 26, 2009, 07:05:25 PM »
I'd PM Soos on that one. He's done a lot of carb change outs on his 650.
