Author Topic: Lightening stock 750 K forks !  (Read 4012 times)
« on: November 26, 2009, 08:03:16 PM »
Dont know if anyone realizes, but if you turned off 4mm of aluminum on the OD of a K3 and later leg it would still be as thick as a 72 or earlier   :o.. a bit of weight there..may help..
 Take a wild guess how thick a Ceriani roadrace fork leg is at the turned down areas, I was  :o  SHOCKED.. :o when I measured it..
Offline lordmoonpie
    • Moonpie
Re: Lightening stock 750 K forks !
« Reply #1 on: November 27, 2009, 03:21:35 AM »
I'd guess thinner as in thinner = lighter = better for racing but did they go the other way and beef it up for the stresses of the track?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Ricky_Racer
« Reply #2 on: November 27, 2009, 08:54:11 AM »
Just a quick question, then.... With it's somewhat lighter weight and lower tube bushing, is the earlier fork considered superior to the K3-6?  RR
« Reply #3 on: November 27, 2009, 09:06:18 AM »
That what I am starting to wonder, which is considered to have better handling?
 I am asking, because I have figured out a way to rebuild the early fork legs, using new style tubes & damper rods..
Offline turboguzzi
« Reply #4 on: November 28, 2009, 07:04:41 AM »
a bit unsure here, but arent ceriani legs forged = more consistent material qualities = no internal defects = can be thinner?
am a weight saver myself but there are certain areas that I wouldnt touch.
 in order not to create any stress raisers, you'd need very nice fillets all around. considering the big caliper boss, it will be more of  CNC job rather than mounting it on a lathe.
there's so much weight to remove from the front wheel and calipers, would leave that as a really last resort
TG
Offline voxonda
« Reply #5 on: November 28, 2009, 07:38:13 AM »
TG
+1 (especially the last bit), front wheel and calipers, easier and much safer!
« Reply #6 on: November 28, 2009, 08:01:43 AM »
 They may be forged, or cut from billet.. I am pretty sure they are made from 7075 Aluminum considering how thin they are.
 I was mentioning the stock forks could be trimmed simply to make later ones, closer to the thickness, of the early stock ones. Its all unsprung weight..
« Reply #7 on: December 01, 2009, 07:43:43 AM »
 The thinned areas on the Ceriani road race or GP fork are...
 3mm thick.. 120 or so thou.. :o....     .120
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: December 01, 2009, 04:05:26 PM »
mystic_1
- John Augustus Shedd
« Reply #9 on: December 01, 2009, 05:59:41 PM »
I could not count on my fingers how many of those forks, ended up on fuel bikes   :o.. a lot of them double engine Harleys.. :o   :o   :o
Offline turboguzzi
« Reply #10 on: December 01, 2009, 09:53:30 PM »
sounds good, just not sure how bumpy 1/4 mi strips are  ;)
Offline Old Scrambler
« Reply #11 on: December 05, 2009, 06:15:10 PM »
AND NO CORNERS OR Ssssss
Good discussion for me to consider.......I have a few sets of early and late forks........also, would be curious about a comparison with Betor forks........They sure worked magic for Bultaco!
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Zaipai
    • My Home page
« Reply #12 on: December 05, 2009, 06:28:23 PM »
mystic_1
I am with you Mystic_1 its all over my head.. All I know for sure is they are talking front forks.. ;)
Its my Avatar..
75 CB550F  |
« Reply #13 on: December 06, 2009, 09:21:58 AM »
The reason I mentioned the double engine bikes, is..
 not that they have a rough ride..
 its the wheelies, if it hooks up, and comes down hard (wheelie bars not always set right & not all bikes have them)
 or like Ray Prices bike where the front wheel, didnt touch down till 90 or 100 mph..
 to put it in perspective.. the stock 750 Steel fork tubes are probably thicker than the lower aluminum fork legs of the Ceriani  :o
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: December 06, 2009, 10:51:47 AM »
1/8" wall thickness is crazy, bet you can get away with it because the loading is all compression forces, no (little) lateral forces from cornering etc.
mystic_1
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #15 on: December 06, 2009, 01:04:54 PM »
i may try this with one of the spare sets of forks i have. does anyone have any pics of a set of forks that have been lightened?
Mark Twain - Notebook, 1894
