Author Topic: 1976 CB750F  (Read 1855 times)
Offline jdubb1977
1976 CB750F
« on: November 27, 2009, 04:11:46 PM »
Just posted this in the cb750F thread, but thought it might go here as well.  I bought my 1976 CB750F last April, and have been slowly but surely getting it together.  Bought it running fairly well, with some little glitches and safety hazards courtesy of the PO.  It was more or less stock, minus the Lester mags and Kerker pipe, and some daytona bars.
The first image is pretty much how I got it, with the addition of some new side covers and clip-ons.
The next 3 images are it's current state.  I kept my handlebar clamps and cut my old bars down to just fit.  I used some plugs from a bicycle for the ends, and now I have a place for my insurance and registration.  ;)  Still some work to do (wire up the brake/tail light, attach rear blinkers, etc.), but I'm happy for my first go 'round on something like this!
mattomoto
Re: 1976 CB750F
« Reply #1 on: November 27, 2009, 05:32:44 PM »
Nice work jdubb-  what seat pan did you use?  I like the idea with the document tube.
Matto
Offline CycleRanger
  • No comment about being an
Re: 1976 CB750F
« Reply #2 on: November 27, 2009, 06:03:10 PM »
Tastefully done!
Offline jdubb1977
Re: 1976 CB750F
« Reply #3 on: November 27, 2009, 10:57:20 PM »
@matto: the seat itself is from Carpy up in LA.  I used the seatpan from Airtech, and made a few little mods to make it fit.
Offline imamotohead
  • Nuthin a little duct tape won't fix!?!
Re: 1976 CB750F
« Reply #4 on: December 01, 2009, 08:55:52 PM »
Very nice F Cafe jdubb!  I'm working on a '75 F and have the same Carpy seat.  i was wondering how you mounted yours.  If you have photos of the mounts that would be great!   ;D
Here today, gone tomorrow.  Make the most of today!
Re: 1976 CB750F
« Reply #5 on: December 02, 2009, 05:17:08 AM »
Very nice - like those wheels.
Offline jdubb1977
Re: 1976 CB750F
« Reply #6 on: December 02, 2009, 10:52:48 AM »
@imamotohead:  i used the seatpan from airtech.  they're about 15min away, so it was easy to take the carpy seat over (they didn't like that!), & try out their form to make sure it would fit.  i dremeled off the wrap around portions of the pan so it was flat and would sit flat on the seat and backrest.  pretty easy work.  i had to grind off the old seat mount, both helmet hangers, and the old seat lock to get the seat to sit flush on the frame.  makes for a bit bumpier ride, but not really bad at all.
as far as the actual mounting goes, i took some advice from other forum members.  i put the pan on the seat, put them both on the bike, and lined everything up.  you know that flat cross plate just behind the battery box?  that's my mounting point.  i marked my holes on the bottom of it, drilled it out, marked the holes on the seat, drilled them, and finally marked the holes on the pan and drilled it.  took some ss bolts w/ some good sized washers and epoxy'd them to the pan so they wouldn't move.  had the pan upholstered, and mounted it all up.  it's a little thicker and softer than i'd like, but i was impatient and didn't want to wait for firmer foam.  feels like i'm sitting on a pillow  :)  the nice thing is that if i want to reupholster the seatpan, i can just pull it off and not worry about doing anything w/ the expensive carpy seat.  hope that helps!
