Author Topic: 76 CB550 (goodbye Harley Hello honda)  (Read 3799 times)
jake8092
« on: November 29, 2009, 05:41:43 AM »
So...I sold my Harley about a year ago.  All of my buddies went on a Toy Run a month ago and this guy felt pretty left out So I decided to build a little Cafe bike.  i wanted something that not many people see around here so I picked up a cb500T on CL and about a week later a CB550 (500T...I know but it was $100 so I couldnt resist) I'll post pictures and stats as I go. I started in late October, progress was going really well until we started a large automation project for spirit aero which has eaten up 12-15 hrs a day for the past 3 weeks  >:(.
Thanks for lookin!
-jake
« Last Edit: November 29, 2009, 05:45:03 AM by jake8092 »
Offline Alan F.
Re: 76 CB550 (goodbye Harley Hello honda)
« Reply #1 on: November 29, 2009, 04:00:55 PM »
Welcome!
Offline MJL
  • Don't listen to me, I'm no
« Reply #2 on: December 01, 2009, 12:29:21 AM »
Jump on it, the water's fine!
Offline Hush
« Reply #3 on: December 01, 2009, 12:33:43 AM »
Welcome to our little corner of Hell Jake, ask and it shall be given.....or we will argue until we come up with a concensus answer that is both PC and workable. ;D
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #4 on: December 04, 2009, 07:59:04 PM »
i LIKE the dohc twins, i have about 1/2 of a 500t in my back yard
Mark Twain - Notebook, 1894
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #5 on: December 04, 2009, 08:01:05 PM »
Welcome Jake!  What is your role in this automation project? Hardware/software design?  What system? BACnet? LON?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Hush
« Reply #6 on: December 04, 2009, 08:59:28 PM »
Just done the Toy run, I know the feeling. ;D
jake8092
« Reply #7 on: January 18, 2010, 01:06:48 PM »
Hey guys!
Sorry I haven’t checked back in a bit, between work and the ole lady I haven’t had much time elsewhere.  I’ve made a little progress machining up the front hub/radial brake set-up to fit and just ordered some mirror black powder and front spokes last week.
Oh, and I decided after realizing that I needed to rebuild the carbs on the 500T that I’d put it on hold for a bit.  Carb kits are outfreakinrageous for that thing! Later that week I found a descent running/condition 76 550/4 so I tore it down instead, I still want to build the 500T because I love the way those old twins sound!
This project @ work is a trip! We are installing a total of 9 ABB robots to replace painters in hexavalent-chrome spraying environments.  We are general engineering on the project involved in everything from the airflow in the spray both to plumbing the fluid handling side and overseeing all programming and controls work. It’s a very very unique part ID system because a 25’long x 15’high aluminum frame is what the parts are attached to as they move down a conveying system.  I say this as the part fixture can have anything from a seat rail to an outer skin suspended inside, all of the parts to be sprayed are stitched/laced/mounted with aluminum wire.  Part placement is never identical! Our ID system has 3 major components Sonar, a simple Light Curtain and camera ID.  The way it works is that the part passes through two opposing towers gets pinged with sonar to tell the robot a gun to target distance, light curtain for start/stop & height/part placement, and last but not least two cameras.
The trick to all of this is that some of these parts are masked, the camera identifies the color differential therefore the robot will not spray the un-masked portion of the part. The cameras also ID crevasses, leading edges…
Well that’s about as simple as it can be explained, there’s a lot more going on than this but it gives you an idea of what we are up to!
I’ll post some pictures of the bike asap!
Thanks guys
Jake
Offline kslrr
« Reply #8 on: January 18, 2010, 08:55:56 PM »
That sounds cool!!!!  Way more complicated than Integrating HVAC, Fire/Life/Safety, Security and Med Gas Monitoring Systems.  That's some of what I do.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
jake8092
« Reply #9 on: January 19, 2010, 07:56:13 AM »
haha, It's easier than you think. Besides all we are doing is pointing a spray gun and throwing out some paint!
This job is massive...I'm talking like 7 million bucks massive. One rail system (2 inverted robots travel on 40' rails) has almost 300 pages of code! Thats not counting the ABB or Conveying programs they are completely seperate.lol
We do a lot of that stuff, some guys have cool things like Mills and tig welders but I have my own personal finishing lab so it's kinda cool, check it out! www.sprayequipment.com and that's us!
jake8092
« Reply #10 on: February 14, 2010, 11:16:53 AM »
Re-sized most of my pictures lets see if I can get some up loaded!!
jake8092
« Reply #11 on: February 14, 2010, 11:22:53 AM »
Hey Hey! Alright, I finally got the pictures small enough to upload! It only took me about 2 days to get everything stripped down and I bead blasted the frame, Today I finally got my spokes in and am ready to lace up my front wheel!! I can see why it's suck a pain stoking wheels because I think the hardest part is locating the right spokes!!!
jake8092
« Reply #12 on: February 14, 2010, 11:28:57 AM »
I picked up some powder at powderbythepound.com If you need any powder these guys are pretty reasonable and have a fair selection; Ive had pretty good luck with their stuff.  I got a few pounds of wet look black to coat my wheel and hub, I machined out a spacer to adapt my brake rotor and 04 gsxr600 front end, ill put some pics up of that in a few weeks.
That wet look black looks sweet, Im happy with it!!
jake8092
« Reply #13 on: February 14, 2010, 11:40:49 AM »
My $100 Special.  This will be the next build, Im thinkin low backbone bobber with some drag bars of sorts. Who knows what I can do about the carbs on this guy? I tore into them wanting to rebuild them and at least get it running but the diaphrams on the sides are shot shot shot!! The want like 85 bucks each for new ones!! that's a hard bullet to swallow, what are my options??
