Author Topic: Wintergreen oil_rubber renew test / peanut oil plastic renew test_pics  (Read 70577 times)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Re: Wintergreen oil_rubber renew test / peanut oil plastic renew test_pics
« Reply #150 on: February 27, 2014, 09:00:22 AM »
Second time today I've needed a sarcasm font... I made it through 4 pages on my phone and didn't see an answer yet.
See Javahut's post, bottom of page 4. He reports 5 years, back in 2010.
HTH,
N.
I have a motorcycle problem.
Offline Bailgang
  • Scott
  • Indiana
« Reply #151 on: February 27, 2014, 02:22:06 PM »
4 years and counting on a set I soaked for my sons K3 750 that started out near rock hard. I soaked them in a mix of wintergreen and xylene, first try had no affect so I got each one nice and hot (not burning hot) with a heat gun then dropped them in and let soak for 24 hrs then let air dry. Pre heating the boots with the heat gun did the trick. New carb boots are still the preferred option in my own opinion but my kid was on a tight budget and the wintergreen trick did work at least for us.
And I do have a bottle of peanut oil to try on the airbox of my F2, I just haven't gotten around to it yet.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #152 on: February 27, 2014, 02:34:49 PM »
Did the peanut oil treatment on one airbox.  Preferred Mothers "Back to Black" treatment.
....and it doesnt attract nesting squirrels  ;D
Offline NobleHops
« Reply #153 on: February 27, 2014, 02:41:22 PM »
Counterpoint: Did peanut oil on all the black plastic trim on my R1200GS and 6 months later it still looks excellent. I will use it first from here on out.
Offline Bailgang
  • Scott
  • Indiana
« Reply #154 on: February 27, 2014, 02:45:36 PM »
Ahha, I didn't think of that.  :o
I guess I should note that anyone considering the wintergreen trick should know that their bike is going to smell something like Wrigley's Spearmint gum for quite a while.
Scott
71 cb350 twin
77 cb750 F2
Offline ncstatecamp
« Reply #155 on: February 28, 2014, 01:42:53 PM »
For my air box I just washer it and hit it with a heat gun. Brought back the nice blackness.
Offline ncstatecamp
« Reply #156 on: March 02, 2014, 01:04:07 PM »
PSA: try not to catch your house in fire. I recommend not heating it....
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« Reply #157 on: September 07, 2014, 12:05:05 AM »
I tested a 750 K0 inlet rubber by soaking  in Tri-Aryl phosphate ester (Reofos 50) at 70 degrees Centigrade (it is a plasticizer for Nitrile Rubber / PVC ). It softened up Ok - that was about 4 months ago. Will have to check its pliability again. It is still in the boot (trunk to non- 'Limeys'  ;D) of my car ! This plasticizer is flame retardant too.
http://www.chemtura.com/bu/v/index.jsp?vgnextoid=40ff7d205ef99110VgnVCM10000053d7010aRCRD&vgnextchannel=b59f921646019110VgnVCM10000053d7010aRCRD&vgnextfmt=default
Have not tried the airbox rubber yet - my analysis was that it was not nitrile rubber but a form of PVC (this is an early K0 about 3000 later than Sandcast with the crappy styrene resin Airbox)  -  airbox replaced with LPM PU one - which is great.
Cheers
Ash D
UPDATE ... Well this treatment was 4 YEARS ago and the CB750K0 inlet rubber part is still as soft and pliable.  as when first treated. It maintains its elasticity too.
seems my original link is dead now.
Here is a new one:-
http://www.specialchem4polymers.com/tds/reofos-95/chemtura/5210/index.aspx
I USED REOFOS 50
Cheers ...AshD
« Last Edit: September 07, 2014, 12:10:27 AM by AshimotoK0 »
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline Hope
  • How did I become an
  • SOHC member since '01
Reviving this thread.
I bought new airbox boots, but the shop lost them. I was thinking about this discussion and I might try to bring my old boots back to life. Bumping this thread might help some other folks as well.
I went ahead and ordered Methyl Salicylate on ebay. I have a problem with the principle of buying the same part twice within a matter of months.
« Last Edit: May 11, 2016, 11:29:44 AM by Hope »
Offline CycleRanger
  • No comment about being an
If the shop lost them why aren't they buying you replacements?
