Author Topic: another petcock question.  (Read 920 times)
Offline Tnutz
« on: December 05, 2009, 07:39:04 AM »
my petcock on my 76 550 is getting a little damp all the time....I know the tank was replaced by the last owner so i don't know if this is what it had stock, the petcock is the thread on kind with 2 outlet barbs.  i want to buy an aftermarket replacement from z1, does anyone know the threading on the dual outlet petcock?  (my head is swimming from looking through all the petcock threads)
2004 Ducati 999 mono posto.
-Full Termignoni exhaust
-Lots 'o' carbon fibre
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline City Boy
Re: another petcock question.
« Reply #1 on: December 05, 2009, 08:45:22 AM »
Have you determined whether the petcock itself is leaking or is it the tank/cock seal?
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline Tnutz
« Reply #2 on: December 05, 2009, 01:07:39 PM »
petcock forsure.  it's not bad yet, but i am awaiting the day when it decides to quit... :-[  so i would like to fix it before. ;D
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline City Boy
« Reply #3 on: December 06, 2009, 03:39:43 AM »
Hi.Can your petcock be disassembled?If so you may be able to get new rubber internals.
'83 1100F
Offline Johnie
« Reply #4 on: December 06, 2009, 07:08:45 AM »
I would stay OEM rather than aftermarket. But these can be easily rebuilt. At least they are on my 750's. Only 3 gaskets to change. I change the one where the tank and petcock meet, the one under the bowl and the one under the on/off lever. Could it be damp because the bowl on the bottom is loose?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: December 06, 2009, 08:17:04 AM »
On the early 750 petcock and other similar designs that are held on with two screws, you also need to replace the fiber sealing washers under the screw heads, otherwise fuel can leak past the valve into the sediment bowl.  This would not cause an external leak at the petcock but allows fuel to flow when the petcock is off.
mystic_1
- John Augustus Shedd
Offline Johnie
« Reply #6 on: December 06, 2009, 09:41:55 AM »
mystic_1
Ah good call mystic. I forgot about those. Those sealing washers mystic is talking about are pretty expensive at the dealer. But you may want to check your local hardware store which is where I get mine. I think they are a fiber type washer. I guess they should be gasoline proof, but I am not sure if mine are and have been fine for 3 years.
Oshkosh, WI  USA
