Author Topic: New Bike and Im Worried  (Read 921 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« on: December 05, 2009, 12:33:09 PM »
Well I just bought a 1975 CB 550 when I got it, it was completely abused. I finally got it up and running but it idles very very rough and sounds pretty terrible. It also has smoke coming from the exhaust. I took the carbs off right after running it and there was smoke coming from the #1 cylinder on the carb and exhaust side. I'm very worried that this bike is just hangin on by a thread and that it will soon lock up.
1) Before I put anymore money into it what can I do to make sure that my engine isnt toast? I'm not for sure if its a critical issue that is about to seize the engine or if its just something out of tune.
2) Consider the most abandoned neglected CB550 you've ever seen. What should my next steps be to getting it roaring and ripping down the highway?
Thanks!
Its hard to be wrong when you know nothing!
Offline scunny
  • don't call me expert
Re: New Bike and Im Worried
« Reply #1 on: December 05, 2009, 12:44:57 PM »
give it a full tune up, and clean those carbs
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline fmctm1sw
« Reply #2 on: December 05, 2009, 01:09:33 PM »
What was the compression?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #3 on: December 05, 2009, 01:22:23 PM »
Compression test, and/or a leak-down test is a pretty good indicator of current mechanical health.
What color was the "smoke".
Blue - oil
Black - soot (unburned hydrocarbons in suspension)
White - liquid vapor (water usually, but can be atomized fuel.)
Were all the head pipes hot (evenly) when you had it running?
What do the spark plug deposits look like?
were all the tune up items addressed?
How well can *you* run with one lead shoe?
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #4 on: December 05, 2009, 05:51:22 PM »
Definitely do a FULL tune-up.
New points and condensers, new plugs and caps (and trim down the wires 1/4 inch or so to get fresh copper, adjust valves, adjust cam chain, CLEAN CARBS, then RECLEAN CARBS, and finally CLEAN CARBS AGAIN.
I cleaned the carbs 3 times before I got them perfect. pull all the jets out, run some copper wire through them to ensure nothing is clogging them. Set the floats (12mm I believe on the 550) ensure the float needles work properly. Buy a couple cans of carb cleaner and go to town on them!
you don't need a carb soak unless they're REALLY bad.
After all that's done, you're ready to sync the carbs.
If you have access to a compression tester, go ahead and check the compression...either way you will have to adjust the valves.
If the bike has under 50K i wouldn't worry too much about the internals, these motors run forever!
If you don't know how to do any of the above tune-up procedures, search...there is a lot out there. Download the manual and read.
Mine was in a similar situation when I got it. It was able to get it running on two cylinders, and it sounded like there was loose metal in the engine. After adjusting the cam chain and doing ALL the procedures, it runs like new.
Good luck
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline Johnie
« Reply #5 on: December 05, 2009, 09:20:14 PM »
What makes you say "completely abused?" These bikes can take a lot of abuse, minus running real low on oil. These bikes can site for years and years and many of us still bring them back to life with a routine clean up and tune up. Don't give up on her man. Just needs some TLC.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline the technological J
  • deliciouso!
« Reply #6 on: December 05, 2009, 09:22:52 PM »
check ur oil too! throw some in the intake itt will assure some oil is lubing it.... and it will burn out( and smoke a little)
94 ST1100..Gone
72 750 K2 Stay tuned!
