Author Topic: 76 CB550 main bearing  (Read 1170 times)
Offline Elkie
« on: December 07, 2009, 11:07:48 AM »
So I'm reassembling my engine, and decided I'd see about ordering a new bearing, because the old one seemed a little worn. The code on the bearing is 6205, when I look at the parts list to get a part number I only see 6305 listed and some 6322. Its number 71 on the transmission/kick starter parts page. I guess my question is what part should I get?
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
Re: 76 CB550 main bearing
« Reply #1 on: December 07, 2009, 01:46:45 PM »
i can't help much other than letting you know that if you multiply the last 2 digits of a ball element roller bearing, you'll find it's ID in mm.  6205 and 6305 ball bearings will have a 25mm bore.  the 62xx series are light duty and 63xx are medium duty.  OD and thickness can/will vary between series.  if it was me, i'd replace what you pulled out.           .0002
bobp
searching for a dr350se
Offline Elkie
« Reply #2 on: December 07, 2009, 09:25:10 PM »
Thank you that's helpful information. Just got home from work, and looked at the parts list, it shows the other bearing on the primary shaft as being the 6205, which I just looked on my shaft, and is the 6322.  My first assumption was that the two had been mixed up previously by someone else, until I checked a spare primary I have which matched. It would appear the parts are mixed up on the parts list.
