Author Topic: Anyone know of a cheap fix for cracked valve stem seals??  (Read 17748 times)
Offline manjisann
« on: December 09, 2009, 01:18:30 PM »
So my 94 Pontiac Sunbird has decided to take up smoking as a way of telling me it's time to retire the old girl. With the bluebook value being about a grand and 185k or so on the clock, getting the seals fixed isn't really a very appealing option (it'd be about 1500 ;( ) My tags are up in February.
Heres the question for all you smart mechanics out there (I know a few of you are very good with cars):
Is there anything that I can stick in the oil that will prevent it from squeezing through the cracks so I can pass emissions one last time. I know it's pretty much time to retire the old girl to the junk yard, but if I could get a few more months out of her I'd be able to  save some cash and buy a better (as in not smoking  ;) ) car.
I'm pretty sure I'm out of luck here, but thought I'd just as, as you never know whats out there.
Thanks,
Brandon
1980 CB650 Custom
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Anyone know of a cheap fix for cracked valve stem seals??
« Reply #1 on: December 09, 2009, 01:26:25 PM »
Well, there are some oil treatments that claim that they fix leaks.  What they do is cause the seals to swell up.  This is only temporary because I think it also then causes premature wear.  Also, adding something that increases the viscosity like Lucas Oil Treatment might also be a temporary solution.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: December 09, 2009, 01:43:58 PM »
do it yourself. shouldnt be that hard of a job. i did the ones in my saturn when it had 175k on it
Mark Twain - Notebook, 1894
« Reply #3 on: December 09, 2009, 01:47:44 PM »
Get yourself to SLC  UT and give him a hand then. :D :D :D
Sam. ;)
« Reply #4 on: December 09, 2009, 01:48:34 PM »
Answer....I would but it's to far. :D :D :D :D :D :D
Sam. ;)
Offline simon#42
  • liverpool
« Reply #5 on: December 09, 2009, 01:52:13 PM »
you can get valve spring compressors that just work on the spring . mine is made by snap on but there are probably plenty of other makes , if you use one of these you can change the stem seals without taking the head off saving loads of time and money . if you dont fancy doing it yourself it might be worth asking a local garage about doing it this way
simon
Offline bucky katt
    • facebook
« Reply #6 on: December 09, 2009, 03:31:12 PM »
Sam. ;)
if i could afford the gas i'd do it in a heartbeat
i need a break from my family  :D
Offline Inigo Montoya
« Reply #7 on: December 09, 2009, 03:45:54 PM »
I have used a product called Restore in the past. It was on a little old nissan stanza and it did help control oil burning and such. A can can be found at walmart(at least here) and will set you back about $6 or so. Put it in fresh oil and see what happens. Might work just long enough.
« Reply #8 on: December 09, 2009, 04:20:20 PM »
simon
Yup "external valve spring compressor". Works real good.
Offline manjisann
« Reply #9 on: December 09, 2009, 04:49:04 PM »
I'll have to look into that. I only need it to last long enough to pass emissions.
I'd really rather not tear the block apart as it's cold here and my ambition and such goes down in proportion to the temperature  ;D
I was looking on our local want ads and it looks like I can maybe get a beater car for a grand, if it lasts me a year that will be good enough. Decisions Decisions  ???
Thanks all for the suggestions, And Bucky Thanks for the offer to come do it for me, but I just couldn't concience taking you away from your family  ;D
Brandon
1980 CB650 Custom
Offline bucky katt
    • facebook
« Reply #10 on: December 09, 2009, 05:13:07 PM »
but i WANT to be away from my family  ;D :D
Brandon
« Reply #11 on: December 09, 2009, 07:19:51 PM »
Well stop making excuses Jeff. :D :D :D
Sam. ;)
Offline bucky katt
    • facebook
« Reply #12 on: December 09, 2009, 09:00:26 PM »
well in that case, i'm on the way Brandon!
« Reply #13 on: December 09, 2009, 10:38:44 PM »
Cracked or hardened? My Acura had the thermostat stick which created a blown head gasket. Mechanic said the seals were fine AFTER THE FACT. Wish I'd pushed him on it before hand. I had to start checking my oil level between changes after 16 years! That sucks. I switched to high mileage oil for $10 more and it cut the consumption. My assumption is hardened seals.
Offline manjisann
« Reply #14 on: December 10, 2009, 03:14:06 PM »
Jerry, I'm not sure if it's cracked or hardened. I've had this car for about 10 yrs. I've been using valvoline high mileage in it (I'm not trying to start an oil debate, just laying out the facts.) A few months back I come out of work, my wife is in the car idling waiting to pick me up, and there is smoke coming out of the tailpipe. It's not a ton, but it was definately noticeable. The bizarre thing is after a while it stops smoking so much at idle, so I started thinking that whatever the bugger was wrong had somehow magically fixed itself. I took it to the IM place (thats all they do, so I can't imagine they'll lie to me) and they say that when they stuck her on the Dyno and gassed it, the whole bay was smoked out.
I know that a sticky valve will go away once it's warmed up, but the car kinda smokes all the time, which is what leads me to believe it's cracked valve seals. At this point I really don't have much to lose, so I'll probably try some of the Restore stuff and see if that helps. If anyone else has any reasonable suggestions, I'm interested.
Thanks,
Brandon
1980 CB650 Custom
Offline cb650
« Reply #15 on: December 10, 2009, 03:32:46 PM »
If the rest of the car is decent and you like it just do it.   I pulled the head on a old escort just to change a valve.  Valve was $10  and head gasket was 25 or so.  Took time and cussing but drove the piss out of it for a couple years.
« Reply #16 on: December 11, 2009, 08:38:06 AM »
I think they should mention you need "the rope trick" or air to hold the valve closed, while performing this task.
 You know I met some cool old Mormon dudes with a vintage Sinclair station, still working near "The Temple" Both guys were around 65 or 70 and had both worked there over 30 years each.. nice guys.. Bet they could do that job & read a newspaper at the same time.
 One of their names was GAYLE, I think..
 We had to pretend we were maybe Mormon and cleaned up our language while we were there, they let us take photographs...station has been there since the 20, pic of the original station inside.. its still there, they just added a few bays.. orig part about 20x20ft.. :o
 Oldest original station I have seen downtown in a  very long time..
« Reply #17 on: December 11, 2009, 08:42:35 AM »
 SNIP
Assuming you're talking about removing the springs without pulling the head? I did it on my CB750 by setting the pistons at TDC. The valve only dropped a fraction. Piece of cake.
Offline ColinMc
  • There aint no pickle like a super pickle...
« Reply #18 on: December 11, 2009, 10:02:46 AM »
I think you'd be surprised what the Lucas oil additive can do...despite all the bad info about foaming and all that crap. It did wonders in my Chevy Lumina right up until the day it was in a demolition derby lol. I had the same problem you are describing. I just substituted a quart of lucas each oil change and it wasn't perfect but it wasn't a mosquito smoker anymore.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline simon#42
  • liverpool
« Reply #19 on: December 11, 2009, 10:39:36 AM »
 SNIP
yes thats what i do , get the piston to dead top center and the valve wont drop far
Offline manjisann
« Reply #20 on: December 11, 2009, 03:18:35 PM »
Colin and all those with the rope trick, are you saying that the valve stem seals can be changed without removing the head, just the cam and the springs? I'm just wondering. Seeing as how it won't pass emissions anyhow, I'm not sure I'd be out a whole ton by trying that. I'm planning on selling it to a junk yard if I can't figure out a way to finesse her past emissions.
Now if I could just warm up the weather, 20F is just too cold to work up much ambition.
Brandon
1980 CB650 Custom
« Reply #21 on: December 11, 2009, 08:49:39 PM »
Brandon
That is correcto mundo. The stem seals are on the top side of the head. If you can get the cam off and the springs, with the external compressor, you should be able to replace the stem seals no problem.
I know it can be done on a CB750 piece of cake. No first hand experience witha Saturn, but if its a SOHC with rocker arms....
« Reply #22 on: December 11, 2009, 08:57:44 PM »
Here's a link to what the tool is and looks like. Scroll down to KD2078
http://www.mytoolstore.com/kd/kdengi13.html
Offline manjisann
« Reply #23 on: December 12, 2009, 04:54:34 AM »
Neat tool MCRider!! Once I've pulled the seal, how do I get the new one in? All the seal drivers I've seen were rods, but if valve is still there, I can't see how that would be done.
Thanks,
Brandon
1980 CB650 Custom
Offline bucky katt
    • facebook
« Reply #24 on: December 12, 2009, 05:35:07 AM »
the new seal should just slide right down over the valve, in some vehicles theres a small cut into the guide that the seal kind of clips into. make sure before putting the new seal in that there are no burrs that might damage the new seal going on.
