Author Topic: 71 CB750 and 75 cb550f upper tree  (Read 1206 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« on: December 11, 2009, 06:28:39 AM »
are they interchangeable?
71 750
75 cb550
they look about the same from stem to fork and leg to leg, the gauge mounts look the same.
but there's a hump in the 550 around the stem.
maybe it's the same as the hill on the 750....
« Last Edit: December 11, 2009, 06:41:56 AM by Industrial Cafe »
Re: 71 CB750 and 75 cb550f upper tree
« Reply #1 on: December 11, 2009, 08:04:48 AM »
That polushed one looks like 73 -76 750.
 500 fits as far as I know, that flat area under the stem nut may require a shim, make sure nut is tensioned against the tree.
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: December 11, 2009, 08:12:48 AM »
yeah I think you're right.
  but it was on my 71 and I can't remember the exact year bike I got it from.
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #3 on: December 11, 2009, 08:28:13 AM »
The offset is not the same.
So far this is the measurements that I have:
CB750K 69-76 = 60mm
CB750F ?       =  50mm
CB750K 77-78 =  50mm (not comfirmed)
CB550 K ?      =  45mm (not sure of year but it was a K model)
CB350F 72-74 = 60mm
CB400F 75-77 = 60mm
Fork spacing on the 750 trees I have measured are 182mm. I have only measured one 550K and that is also 182mm. the 350/400F are 172mm.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: December 11, 2009, 08:45:44 AM »
you're right on the 77-78k, I have an upper tree off a 77 and it's 50mm offset.
77 CB750k tree-
hmm, what about the 550F?
« Last Edit: December 11, 2009, 08:51:56 AM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #5 on: December 12, 2009, 08:10:22 AM »
anybody have a 550f, a straight edge, and a tape measure?
I can figure out inches to MM if you don't have it.
« Reply #6 on: December 12, 2009, 08:16:52 AM »
Sorry for steering you wrong.. pun intended..
 The 550 has less offset, I checked one yesterday, i aplogize for the mistake..
 now if a 550 has the same offset as a 77/78 750, then you can swap the 550 tree to get lower bars on the 750!
  • Like a well oiled
    • Undead Asphalt
« Reply #7 on: December 12, 2009, 09:28:45 AM »
cool, thanks everyone!
Offline Zaipai
    • My Home page
« Reply #8 on: December 12, 2009, 09:53:53 AM »
Wow its like reading a foreign language.. What is the offset and how would I measure it? If anyone wants to take on that "howto".. ;)
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #9 on: December 12, 2009, 10:07:49 AM »
from the center of the stem nut to the center of the fork nut.
it measures out to 2.362 inches (60mm)
I'll mock up a 73-76 tree and take a picture.
  • Like a well oiled
    • Undead Asphalt
« Reply #10 on: December 12, 2009, 10:09:51 AM »
