Author Topic: CR special cables  (Read 2784 times)
Offline motocyconomad
CR special cables
« on: December 11, 2009, 08:27:21 PM »
Could any wisemen running or knowing the 29mm CR special carbs tell me what type cables are best. It seems I will need to have pro motion or someone make some as my stock cables are too long (housings and cables) seems like the cable needs to be shorter within the housing. Anyway, anyone who has dealt with this and has any wisdom...thanks!
Offline lordmoonpie
    • Moonpie
Re: CR special cables
« Reply #1 on: December 12, 2009, 05:06:02 AM »
If you don't wnat to go for custom cables, use the stock Kawasaki KLE 650 thorttle cables. As a pair they bolt straight into the Keihins and are the right length (or they are on my bikes!). You may need to change the throttle too though or modify it as the Kwak cable end screws are quite fat...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #2 on: December 12, 2009, 05:31:17 AM »
The stock Honda cables work well with the CR's
  • Moderator
« Reply #3 on: December 14, 2009, 07:22:43 AM »
I'll second what he said, whoever he is ::)  I got a set from... http://www.allensperformance.co.uk/
Sam ;)
« Reply #4 on: December 14, 2009, 01:00:30 PM »
thanks guys ;D
