Author Topic: okay....now what?  (Read 2263 times)
traveler
okay....now what?
« on: December 13, 2009, 12:15:47 PM »
Okay....now what?
(Regarding dual front disc brakes)
Since my bike is a '77 model 550K, and therefore both fork sliders are the same, what caliper is used for the left side to match the factory right side one?  It looks as though the GL1000 master cylinder is the way to go, and the brake lines and T are pretty straight forward....rotor is straightforward, and the speed sensor has to be modded....only thing left to figure out is the caliper.....
Please help!
~Joe
Re: okay....now what?
« Reply #1 on: December 13, 2009, 02:56:13 PM »
Okay....now what?
Please help!
~Joe
You take a stocker apart, swap the halves on the center bracket, and screw it back together.
That's how the CB750 works, I think its the same for the 550s
traveler
« Reply #2 on: December 13, 2009, 07:41:18 PM »
Okay...thanks.
(what do I swap it with????)
is a GL 1000 Master Cylinder necessary?
~Joe
« Reply #3 on: December 13, 2009, 11:15:03 PM »
Okay...thanks.
~Joe
You swap it with itself. The half of the caliper that was on the inside of its bracket moves to the outside, the outside moves to the inside. Put the bolts back in. Voila, a caliper for the other side.
traveler
« Reply #4 on: December 14, 2009, 05:29:22 AM »
Got it.
How about the master cylinder?
Thanks.
~Joe
Offline Bonafide
« Reply #5 on: December 14, 2009, 05:59:43 AM »
Got it.
Thanks.
~Joe
I used a Nissin (5/8 bore) on both of mine. Works fantastic. Here's a pic for illustration.
« Reply #6 on: December 14, 2009, 06:01:28 AM »
Got it.
Thanks.
~Joe
You may want to see how your stock one feels first. But in theory you would need to upgrade to a MC that's pushing more fluid, as you have more fluid to be pushed. I've heard good reviews of the GL MC. But any from a dual disc bike may be an improvement.
Over the years, I just got some from a salvage yard with no ID and they worked fine.
traveler
« Reply #7 on: December 14, 2009, 10:11:06 AM »
Thanks much.  Need to go shopping now....:D
Might need to find a 650 head and cylinders as well for future.... :-\
(Having visions of overbored 650 slugs and a ported 650 head, with CR Carbs and 4-1 someday MAYBE)
~Joe
