Author Topic: couple of questions  (Read 800 times)
Offline Captaindonutbikes
couple of questions
« on: December 13, 2009, 03:41:16 pm »
Hello all;
On David silver,
green and brown bearing shells, explanation please? i know what,where how but no comprendi the colour spec  ??? ???
Oil drain bolt and washer, are the these the two drain points at the front of the engine? look like tappet covers only smaller and made of very soft ally with a sealing o ring. the ones on mine did not survive the removal and i shall need some new ones.
cheers in advance
 ;D ;D ;D ;D ;D ;D ;D ;D
Offline OldSchool_IsCool
  • Really feeling like an
Re: couple of questions
« Reply #1 on: December 13, 2009, 04:01:50 pm »
Hey Capt.
It would help if we knew which bike ur working on.  But I suspect that the plugs you removed are the oil gallery plugs and not the oil pan drain plug.  Sounds like you need to replace the gallery plugs  them look for the drain plug on the front leading edge of the oil pan.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #2 on: December 14, 2009, 02:33:04 am »
its a 550 k3.  Steve in the UK already gave the part name, but thanks
about those those bearing shells?
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #3 on: December 14, 2009, 03:25:32 am »
Honda color codes the bearing shells by color.  Each color will give a certain clearance with the crank and rods.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
