Author Topic: Replacing plug caps on coil wire?  (Read 1274 times)
ron72401
« on: December 28, 2005, 10:55:40 AM »
Hey Folks,
Need your help and advise. My plug caps for cylinders 2 and 3 are trash and need to be replaced. I searched the local auto parts stores for something that would work with no luck. Can anyone advise me about where I can get replacement caps so I don't have to replace the entire coil setup?
Thanks a bunch for the reply.
Later
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
Re: Replacing plug caps on coil wire?
« Reply #1 on: December 28, 2005, 11:00:11 AM »
What your year....make and model???
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #2 on: December 28, 2005, 12:19:56 PM »
http://www.crc2onlinecatalog.com/Index_Main_Frame.htm
Look under "Electrical" - "Coils" - "Coil Accessories".  They're ~$3-4 each (NGK brand) depending on which ones you need.  There's a long list of vendors in the FAQ section, this is just one of them.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
ron72401
« Reply #3 on: December 28, 2005, 12:53:44 PM »
Ohiocaferacer;
It is a 78 CB750.
« Reply #4 on: December 28, 2005, 12:55:12 PM »
The plug ends screw in. It is best to nip off a bit of the tip of the wire befroe screwin in the new caps. Just a bit so the screw goes into cleaner copper.
Offline dusterdude
« Reply #5 on: December 28, 2005, 01:20:28 PM »
my local dealer had them,i think they were about 5 bucks each
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
ron72401
« Reply #6 on: December 28, 2005, 06:26:11 PM »
Dusterdude;
What is the phone number to the local dealer you mentioned. I'll see if he has any left in stock.
thanks
Offline Lumbee
    • My pics...
« Reply #7 on: December 28, 2005, 06:33:06 PM »
...u'r local MC shop should have them...
"I'm not a welder, but I play one on HondaChopper.com"
theunrulychef
« Reply #8 on: December 29, 2005, 07:20:39 AM »
At my local Honda stealership, I got 4 NGK caps for about $12.  Just make sure you get the correct Ohm resistance (mine were 5 ohm, or kila-ohm - I forget).
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #9 on: December 29, 2005, 07:28:30 AM »
Yep,the local Honda dealer sells them for $3.25 apiece.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
