Author Topic: Frame mod cb 750  (Read 78618 times)
Re: Frame mod cb 750
« Reply #100 on: November 06, 2013, 09:20:49 AM »
Be mindful that what works on Mikes frame may not be adequate for anyone else........considering that little pussy engine he has.  ;D  ;D
« Reply #101 on: November 06, 2013, 09:25:39 AM »
My thoughts exactly. Tee Hee.   ;)
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
« Reply #102 on: November 06, 2013, 09:40:02 AM »
I'm looking for a no-weld method because of cost and not wanting to pull the motor to weld it.  I had my top-end done and now have an indication of a head leak.  As I understand it, any re-build requires a re-torque of the head after 500 miles.  Pulling the engine, again, is almost too much to ask.  IF, in the day, guys cut them out and left it that way, you would think a reasonable "fix" could solve it unless you race or are big on wheelies.  Terry suggested sliders that were of a larger id and split to close the joints.  What if the sliders are also a thicker, stronger material.  Wouldn't that do the job.  KrautKoffin pointed out that there wasn't much interest to build anything because money would not cover parts and labor.  I, for one, would be willing to pay a reasonable price for someone like Frank, or ....., to design and manufacture sliders and plates to do the job.  They know what they're doing.  I don't.
I'd be willing to pay 50 to $75, or whatever, plus freight, for 4 sliders and 2 plates. No reason anyone making something shouldn't make an adequate profit.
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Offline KrautKoffin
« Reply #103 on: November 06, 2013, 10:01:46 AM »
You can call me Jordan, and I totally agree. The less times I have to pull a motor the happier and the more I'll spend on this kit.
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
« Reply #104 on: November 06, 2013, 10:19:16 AM »
Hi Ed:
The Gordon Kit was selling for $250 IIRC, plus labor. The Carpy Kit is probably closer to what you're looking for.
http://www.cb750cafe.com/products-page/frame-adapter-kit/
Make no mistake, I fully agree, stronger is better in all respect. But...
I probably have the most mileage experience running a kit of any design. Least wise no one else has piped up with more. I assure anyone who is concerned that strength is not an issue. If you ride harder and faster than I did in those days, well maybe, you'd notice.
If you get a chance to swing by, I'll show you how it works. Big Jay at APE sold thousands, maybe tens of thousands of the kit I have. He did not report any failures nor have I ever heard of a frame failure, with or without a kit.  Your situ is a perfect example though. You can easily cut the tubes out, retork the head, and install the kit. To do a really neat job, you may have to remove some electrics, reposition the ignition key to the handlebar, remove the carbs, nuisance things like that to make room for the Sawzall.
I bot my K1 from Honda-Triumph of Indy. Have you been in Indy long enough to remember them? 46th and Keystone. Owned by Bill Romer, who never rode a motorcycle in his life. The mechanics got him on one of the Honda 3 wheel ATCs, new at the time and he promptly plowed into the back of his Cadillac. Good Times.
I worked there at the time as well. He didn't want to warranty my leaky head gasket, a big problem with new bikes back then. The mechanic took pity on me and for a 6 pack, pulled my engine, retorked it, reinstalled it, in drag strip type time. And I was fixed. Back in the day when two of us could lift an engine and toss it around.
Offline Phoenix
« Reply #105 on: November 06, 2013, 03:09:53 PM »
Ron and Jordan, etal
My only problem with the current non-weld methods are that I would just as soon keep my triangle and add sliders and plates.  It was also mentioned that the current sliders have to almost be knocked on with a hammer.  I'd like to be able to get just (2) plates with (4) sliders that slide.  To me that would be the perfect fix.
Ed Spengeman
Indy
Offline KrautKoffin
« Reply #106 on: November 06, 2013, 04:20:49 PM »
Well you and I are in the same boat. I'm in the market for a kit too, I just don't want to give carpy my money :)
74 cb550
Offline Rookster
« Reply #107 on: November 06, 2013, 05:40:30 PM »
You can make your own kit.  The frame rails are 1" OD.  You need steel tube that has an ID of 1.00x".  The plates you can make from flat stock that they sell at Home Depot.  I'm not sure of the wall thickness on the sliders in the Carpy/Ape style kits but you can order 4130 steel tube with an ID of 1.010" or 1.009" from McMaster Carr.  There are a couple of different options but your sliders should be 3-4" in length each.  Cut, drill, bolt and your good to go.
Scott
Offline CB750R
  • 77 CB750F
« Reply #108 on: November 06, 2013, 05:55:24 PM »
If you bust out some kits let me know Frank, I think I can make the drive from Vernon to pick a set up!
« Reply #109 on: November 06, 2013, 09:41:29 PM »
Vernon!! Hey get over to BCclassic motorcycles, join up and get to our coffee meetings.
Yeah I better start on these pronto.....
Offline CB750R
  • 77 CB750F
« Reply #110 on: November 06, 2013, 10:04:04 PM »
Thanks for the heads up, I'm currently waiting approval!
« Reply #111 on: November 06, 2013, 11:25:52 PM »
Yep, hurry up Frank and make your frame kits, or I will, and I'll patent 'em and sue your arse if you copy mine! ;D
« Reply #112 on: November 07, 2013, 05:10:07 AM »
Hey......I resemble that remark. ;D
« Reply #113 on: November 07, 2013, 06:28:02 AM »
Whew, I got off lucky. I was worried I might have sacrificed my sponsorship deal for the sake of a joke!
Offline KrautKoffin
« Reply #114 on: November 12, 2013, 10:36:31 AM »
So, who is making these kits? I'm pulling my motor in a few days and would like to only have to dick with this one time.
74 cb550
« Reply #115 on: November 13, 2013, 11:30:08 PM »
Yeah Frank, what's going on, have you got some kits done yet?  ;D
« Reply #116 on: November 14, 2013, 06:53:11 AM »
They are about 1/2 done..
 A couple prototypes, then I can make more.
Offline BPellerine
« Reply #117 on: November 14, 2013, 03:05:11 PM »
we are waiting!haha bill
1978 CB 750K ard and webers
another anfob
Offline KrautKoffin
« Reply #118 on: November 14, 2013, 04:14:33 PM »
Frank,
Have I told you lately that I love you?
74 cb550
« Reply #119 on: November 15, 2013, 02:43:12 PM »
Geez that really is the voice of desperation, don't let them down Franky! ;D
Offline calj737
  • I refuse...
« Reply #120 on: November 15, 2013, 03:04:50 PM »
Rookster you really ought to go the other way round. Sure, cut the tube, but slide a new tube with a matching ODto the original ID. Use a thicker walled new tube. Allow enough length to slide the tube out and remove. Drill through the end of the original tube beyond the cut, through the new tube, and pin the tube in place. Then clamp a new sleeve over the joint for easy removal while restricting the pin.
This adds strength internally and won't allow any crushing of the factory tube ends.
This may not be the only way to do it, but it's based on an internal plug approach with new external fastening joining original and new tube lengths together.
« Reply #121 on: November 15, 2013, 03:14:39 PM »
The problem with that idea (and most of us have had it before) is that the OEM tubing's weld seam protruding inside the tube will not allow you to use an internal slider unless you can somehow grind it out, (difficult, at best) and of course, even if you could, how do you move the internal sliders once they're inside the OEM frame tube? Telekinesis? ;D
Offline calj737
  • I refuse...
« Reply #122 on: November 16, 2013, 06:09:23 AM »
I wouldn't rely on recommending Telekinesis for any group other Aussies...
Seriously though, my buddy who is a fabricator did this exact method for his friends bike. I was around working on mine so I didn't take pics... But, the original tubes were left long enough toward the rear that when the new internal tubes were slid rearward, it was possibly to extract the internal by pulling forward and "outward". The pins were used to prevent torque/twist.
I will say, since it was not for a bike like mine (550 and 500) that i didn't have the problem to address, I didn't focus on all the details. But I did ask the principles behind why that "approach" to which he answered the strength and rigidity portion of the reply.
If you're knowledge exceeds my observation, please accept my apology and I stand corrected if this is not possible on the OP's frame. My reply was targeted at "installing the new tube outside of the original cut ends" which WILL crush those ends and potentially fail unless a Gordon's style kit is used.
Offline Rookster
« Reply #123 on: November 16, 2013, 08:35:10 AM »
How?
There is no clamping force applied to the sliders or the frame tubes. The sliders are a loose interference fit.  What force will crush the frame tubes?
There are 2 things at work here:
1. There is a belief that those frame tubes serve either no purpose or are an integral part of strengthening the backbone/steering head.  If they serve no real world purpose they can be cut and discarded.  Many CB750s have suffered this fate.  If they are an integral part of the frame then the only proper solution is a welded in rigidly bolted replacement like the Gordon style kit.  If you aren't sure if they are useless or crucial maybe a kit like the old APE kit that involved sliders and bolts may be what you need.  None of us have done any real scientific tests on the rigidity of the fame/steering head with or without those tubes so we rely on our opinions and beliefs.
2. I am interested in the old APE style kit and wanted to make my own because the ones for sale seem overpriced.  I also wanted to understand a little more about the length and fitment of the sliders.  I did some very quick research about loose interference fits and talked to MCRider because he uses an old APE kit.  My instructions were a way to build an APE style kit for about $30.  No more/no less.
Scott
Offline KrautKoffin
« Reply #124 on: November 16, 2013, 10:38:19 AM »
Scott
Scott, put me down for two kits.
- Jordan
74 cb550
