Author Topic: Frame mod cb 750  (Read 93415 times)
Offline timbo750
Re: Frame mod cb 750
« Reply #250 on: March 02, 2014, 02:01:13 PM »
Nic, glad you mentioned this. I cut ny frame on the weekend and noticed the frame moved slightly with the rear cuts also. I was not going to do anything about it as I was only cutting pre powder coating, but now I will definitely try to fit first and will cut and weld the lower if I need to.
Project 1 CB750 - http//forums.sohc4.net/index.php?topic=126864
Nic
« Reply #251 on: March 02, 2014, 02:05:50 PM »
I wouldn't weld up the triangle on yours until I had the bike together, ie, with engine in and wheels on so that all the stresses that will be on the frame are before you fit the H section. So I reckon cut the bottom triangle and get The H section powder coated as two pieces and weld it back together later.
« Last Edit: March 02, 2014, 02:33:35 PM by Nic »
Offline chewbacca5000
  • I polish covers!
« Reply #252 on: March 02, 2014, 03:53:52 PM »
These things are freaking awesome you rock star!  Another thing to ad to my MC wish list.  Nicely done.  Now when are you going to make a kit so swap out entire engines at a will?
« Reply #253 on: March 02, 2014, 07:33:53 PM »
The oval or out of round tubing, was certainly a surprise, had not considered that. Please tell what year /month, that frame is.
 Best to measure the tubing before hand. Powdercoat will need to be partially sanded off.. The triangle brace in the middle, would have to pull the tubing on some frames, a lot of pieces coming together, and that is probably welded after everything else.
 Thanks for the detailed. Info, and report.
« Reply #254 on: March 02, 2014, 11:26:07 PM »
The ovalness was not that much, needed some additional grinding compared with front. The clamps fits like machinery parts. My bike was imported to Sweden October 1976, frame no 25795xx.
One very interesting detail here. My frame was also a little bit out at rear. I thought the frame had built in stress forces after a minor crash back in the days. Easy to bend by hand and fit the clamps.
My procedure:
I started to measure and drill the 2 holes on each side on the triangular bracing. Test mounted the brackets and tightened the screws.
(I had to shorten the upper part of the brackets about 3mm when I had done holes for grounding my ignition that interfered with the lower hole for the bracket.)
Removed the brackets and cut the bracing in the middle of the 2 holes. Then cut frame pipes. Front cut first, then rear. I used hose clamps just for sure as guide for the tiger saw. I had a cloth covering the engine and KN filters plus a piece of alu to protect the bike for the blade. (Harness,, carbs etc must not get hit by a blade going wild)
About the bolts... I bought a cheap allen tool, inch
http://www.biltema.se/ProductImages/10/large/10-1020_l.jpg
Clamp bolts are close to the allen mm heads
I use a screw driver like this: http://img.directindustry.com/images_di/photo-g/screwdriver-type-ball-end-allen-keys-88203-6477155.jpg
Inch allen tool for final torque
« Last Edit: March 03, 2014, 03:01:03 AM by PeWe »
« Reply #255 on: March 03, 2014, 03:25:26 AM »
I took my gear selector cover and alt cover off to do cam timing. It wasn't too much effort. I left the alt wiring connected and just suspended the cover to the frame with some wire. Only a small amount of oil came from the gear selector cover. My engine won't even turn over by the points nut so I did it via the alt.
I'll try to do the cam timing without removing the alternator cover.
Degree wheel on ignition side (I'll lift off the Pamco plate and let it rest around the corner, give it more cable)
Move the crank by turning the rear wheel and gear in.
Edit again:
I'll use my small degree wheel again since it fits perfectly as I hoped after adjusting the center hole up to 14,5mm or so. There is not much more space for a bigger wheel anyway. (Brake pedal)
One more thing: Next timing session is to check how the cam was timed before removal. Piston stop is NOT possible when valves are moving! Bent valves..must be a result in my theory Piston stop is to be used before the sprocket is bolted on the cam/rocker arms mounted.
I have to turn crank to T mark on 1:4, zero the degree wheel and lock the nut. Then measure the cam.  Remove cam, do the planned job and time cam again but ~3 degrees advanced compared with before.
All easy done thanks to the frame mod kit. ::)
« Last Edit: March 04, 2014, 10:32:01 AM by PeWe »
Offline timbo750
« Reply #256 on: March 03, 2014, 11:47:59 AM »
Nic, thanks for the advice. I tried lining it all up by hand and noticed both the rear frame tubes (bits still attached) move outwards and not very much. this suggests to me that I actually want to move the frame tubes inwards not the removed tubes outwards and I know I can achieve this when it all go back together. Hopefully the will be of to the powder coater today.
« Reply #257 on: March 06, 2014, 11:23:33 AM »
First time removing valve cover, engine still in frame and almost everything on.
The hole in the triangle bracing is useful for dial gauge. Found that when thinking about where to place the magneto foot not needed.
Time cam need running around the bike, measure valves on 1, degree wheel on ignition side. Just veirfy when IN/EX open/close. Remove everything on head, replace long cyl studs inside valve cover one by one, use newer higher 10.9 grade nuts, check that all 4 o-rings are fresh under cam towers with rocker arms that I'll replace too. So convenient to not take out the engine.
« Reply #258 on: March 08, 2014, 12:08:36 PM »
I had to test the frame mod!
Head off today ;D
Lenghts of front frame cuts OK, did not obstruct the removal of head nuts.
Started to replace all HD studs that were over torqued due to bad torque wrench. I had to tighten 35-36Nm to move torqued nuts (26ft lbs) with my new wrench. Kibblewhite cyl studs going in. New had calibration report at 35Nm as proof. I'll torque head with 28-29Nm 20.65-21.4 ft lbs.
Offline BPellerine
« Reply #259 on: March 08, 2014, 04:02:00 PM »
must feel good to be able to do that without removing the engine!and the kit is easy to use!bill
1978 CB 750K ard and webers
another anfob
« Reply #260 on: March 08, 2014, 11:46:23 PM »
Yes indeed.
This was the main reason of doing the frame mod. I had a rework to do. Check small o-rings under cam towers that were OK and replace studs when I snapped one that I replaced. Got 2:nd thought about replacing all when I read about one guy that did the same and one more stud snapped when driving that ruined the engine. Time the cam again was another thing. Advance it.
Testing other cams will be easy and fun.
« Reply #261 on: March 09, 2014, 09:08:27 PM »
 For the tool guys out there, a rigid brand 1" mini tube cutter will cut the tubes nicely, perfectly round and no filings.  A 3 wheel cutter would work also, most larger tubing cutters won't swing the full circle.
Offline 750K
« Reply #262 on: March 09, 2014, 09:15:42 PM »
Good to know Don R, I had already considered a tube cutter. Have one that's seen lots of use over the years, they work great.
77 Cb750, 78 Kz1000
« Reply #263 on: April 10, 2014, 03:56:31 PM »
Got a few kits left if anyone needs one..
Offline timbo750
« Reply #264 on: April 10, 2014, 09:51:56 PM »
Just got the frame back from the powder coaters and will post photos with the frame kit installed on.
Project 1 CB750 - http://forums.sohc4.net/index.php?topic=126864
Offline Bailgang
  • Scott
  • Indiana
« Reply #265 on: April 25, 2014, 05:57:28 PM »
I finally got around to installing Franks frame mod on my F2 this morning, I followed Don R's tip on using a 1"mini cutter to cut the frame tubes and all went well and everything fit perfectly. Not only does the kit allow you to do top end work without removing the engine from the frame but it makes getting the engine in the frame in the first place sooooo much easier. My youngest son stopped by later this afternoon to help me swing the newly rebuilt engine back in and it went in the frame with ease thanks to the frame kit.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #266 on: August 27, 2014, 03:40:43 PM »
One concern people have had is not wanting to cut an early frame.
 With  the weldless aluminum frame kit, there is two cuts on the long tubes and one on each side of the brace. ..no further material cut off the tubing.
 Therefore, at this point, welding the frame back to stock is quick and simple. Once you start cutting off sections of tubing, good luck trying to go back to stock..
 Another concern is weight, why add extra weight to your frame.
Offline 750K
« Reply #267 on: August 31, 2014, 10:23:02 AM »
Hey Frank, did you ever get around to making that left side double motor mount? Just remembered it, been sidetracked with other things than motorcycles this summer and forgot all about it.
77 Cb750, 78 Kz1000
« Reply #268 on: August 31, 2014, 10:29:34 AM »
Pm sent.
« Reply #269 on: August 31, 2014, 11:58:08 PM »
Just a tip oval tube can be rounded with a crescent wrench, just adjust it to the correct diamater and rotate it around the oval tube, it will squeeze where it needs to, adjust as needed. It's a feel thing, so take your time.
Offline VB-SLE
« Reply #270 on: September 08, 2014, 01:08:04 AM »
I would like to grab a kit please, how much would the total cost be including postage to Australia?
« Last Edit: September 08, 2014, 06:12:57 AM by VB-SLE »
« Reply #271 on: September 08, 2014, 08:17:15 AM »
Will get total price for you later today, thanks.
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #272 on: September 08, 2014, 02:13:15 PM »
Frank, I would like one of your frame kits. Please advise total price to Australia - post code 4807. How is payment made? PayPal? Thanks, Pat
Regards
Pat from Australia
Offline VB-SLE
« Reply #273 on: September 08, 2014, 04:57:20 PM »
Thanks, post code is 5710.
Offline welard
  • is this the dude from Highlander?? Oh sht, it is..
« Reply #274 on: September 10, 2014, 09:49:18 PM »
Hi Frank
Do you have any more of the frame kits left? If so could you kindly let me know how much and the shipping costs to Sydney, Australia.
Cheers
Pete
