I'd get the old liner out. I had to do the same to mine and it was a pain in the arse.
What worked best for me was some aircraft paint stripper. ** Make VERY SURE that the tank is vented if you use the stripper - it WILL build pressure if not vented.
After the aircraft stripper, I used an old bicycle chain and shook the crap out of it over and over. I then used some "The Works" toilet bowl cleaner to get rid of the rust. After all
that, I found that I didn't even need to re-line it.
Long story short, the better shape that the inside of the tank is before you coat it, the better chance the liner will work.
