Author Topic: 500/550 clutch cables  (Read 1618 times)
« on: December 18, 2009, 01:40:04 AM »
can some one verify if the clutch cables are the same on the 500,and the 550s,i want to put my rebuilt 500 top end onto a good 550 bottom end,i have the engine mounting bracket for the 550 with the loop for the cable,i havent pulled it apart yet or done a dry run with the cable to see if itll make the distance,i want to do it in one go and not chase up a cable halfway through.,my parts list has the 500 one as 22870-323-020.
Offline Deltarider
Re: 500/550 clutch cables
« Reply #1 on: December 18, 2009, 01:57:40 AM »
Part number 22870-323-020 is for some areas. For Europe it's 22870-323-621.
For models CB550F, CB550F1, CB550F2 and CB550K3 it's 22870-374-000 for your area.
CB500K2-ED Excel black
« Reply #2 on: December 18, 2009, 06:22:08 AM »
The Honda part numbers differ but the aftermarket catalogues i have access to in UK say the same cable fits both (and the 750). lengths might be slightly different, I would try it and see as soon as engine bottom is in then if not you have time to get one whilst rebuilding
« Reply #3 on: December 18, 2009, 01:18:47 PM »
thanks,ill try rerouting it and find out eh!!
Offline Deltarider
« Reply #4 on: December 18, 2009, 02:04:42 PM »
I remember having seen clutch cable with different parts number have like 10 cm length difference (97 cm and 107 cm I believe). I suppose this relates to the low/high handlebars in the various areas.
« Reply #5 on: December 19, 2009, 12:41:44 AM »
thanks delta,i have quite short and low bars,as in the master cylinder hides half the tacho,the cable might reach,,what did i do to my bike today?,i reassembled the 550 bottom end,im going to use the 500 drive chain cover because i have it so polished!!the 550 one looks good but man,,those gouges!!,so itll look like it has two clutch activation systems,confuse a few ill bet?ive got two weeks off work shortly,i can tinker all or want (or need).cheers all.
