Author Topic: Yet more spark photos and a coil mod disaster...  (Read 2549 times)
Offline fmctm1sw
« on: December 22, 2009, 05:56:09 PM »
I finally got around to installing the coils on my bike that I modified like the post in the FAQ discusses.  I ended up ruining one coil somehow.  I don't know if the excess heat from trying to solder it ruined it or what but I devised an ingenious (so I thought) plan for modding another spare I had.  I found the loose cylinder head dowels I had laying around made a perfect, if not almost too tight, fit on the coil wire I bought online.  For this coil, I would cut the wire down to about half an inch out of the coil, fit the dowel over it, jam a brad nail into it and plug the wire onto the other end.  On the bench it all went as planned, on the bike it was disaster.  Once on the bike, the (metal) dowel arc'd to the coil mount.  I ended up using the brad nails and electrical taping the wires together as a temporary fix.  The spark I have now is significantly different from when I first photo's the spark in July.  Tomorrow will be the true test to see if it makes any difference starting it.  I'm almost worried about my jetting now.  I fear I "tuned" my jetting to weak spark and now I'll run too lean or something.  Oh well, could be worse I guess...
« Last Edit: December 22, 2009, 06:01:44 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
Re: Yet more spark photos and a coil mod disaster...
« Reply #1 on: December 22, 2009, 06:01:30 PM »
more pictures of what NOT to do...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #2 on: December 22, 2009, 06:02:47 PM »
and done for now...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Tnutz
« Reply #3 on: December 22, 2009, 06:54:51 PM »
why not buy a new set of coils.......70 bones or so for 2  4.5ohm fixed lead ones from mikes xs.....why farmer electrical stuff together...
2004 Ducati 999 mono posto.
-Full Termignoni exhaust
-Lots 'o' carbon fibre
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline Zaipai
    • My Home page
« Reply #4 on: December 22, 2009, 07:05:59 PM »
I applaud your trying it and the end result. I also give you props for posting the mistake pic's.. I like the why it looks on the bike.. Nice work.
Its my Avatar..
75 CB550F  |
