I installed one of those "F" model cooler-adapters on a 1974 CB750 "K" model with the factory stock exhaust pipes. Direct bolt-on without any fitment or clearance issues. However, you do need to use the longer "F" oil filter bolt and spacer. The "K" model oil filter, spring and washer will work just fine.
