Author Topic: alternative wheels to fit a 77 cb550 ANY HELP  (Read 3090 times)
CBFAN2
« on: December 23, 2009, 12:06:15 PM »
Hi new to this forum ,just bought a 77  cb550k3 uk spec .Hopping to build a cafe racer from the parts iv got .One big problem is the spoked wheels are rusted bad ,and replacing these with new wheels ,looks like blowing a big hole straight away in my budget.Have seen a 550 cafe race with alloy wheels on the internet.
Any ideas what wheels will fit.! ???
« Last Edit: December 24, 2009, 11:37:05 AM by CBFAN2 »
CBFAN2
Re: alternative wheels to fit a 77 cb550 ANY HELP
« Reply #1 on: December 24, 2009, 11:39:09 AM »
Surly someone has a idea what alternative wheels will fit? ???
Offline Alan F.
« Reply #2 on: December 24, 2009, 04:06:10 PM »
The easy answer would be that CB750, CB500, CB550 and even the CB450 should be the same or an easily adaptable alternative (the renowned dohc parallel twin CB450 that is...likely the CL450 too)
If you're interested in adapting modern alloy wheels, check the link in my signature line. I have compiled a good list of resources for such swaps.  A few of the parameters you'll need to be aware of are: tire size and it's relation to wheel size, axle and wheel bearing sizes, how to approach finding the right sprocket and how to achieve correct chain line, as well as what you'll do for brakes!  it cal all be done with modern components and if you choose carefully you can do it with a minnimum of custom pieces.  Cost can be considerable, but again if one chooses wisely costs can be held low.
Swapping out the forks as well as the front wheel will eliminate quite a bit of re-engineering as far as braking systems go.
Cheers and good luck, PM me with questions if you like.
-Alan
Offline lone*X
« Reply #3 on: December 24, 2009, 06:45:45 PM »
The first few years of the GL1000, 75-77 I believe, had 40 spoke alloy rims, as well as the early 750A's.  You will have to lace them to your 550 hubs.  Quite a few members have used them on the 550's.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
