Author Topic: 1978 CB750K AKA winter project  (Read 3031 times)
Offline Sandbag
« on: December 23, 2009, 04:06:24 PM »
Ok this is my CB as she rolled into the garage
The start of the project drain the varnish.  (oh the guy I git it from "drained" the tank"
Carbs Off
The front break was not releasing so I took the caliper apart cleaned the rust & corrosion out it appears to be working better still need to flush the fluid & install new pads.
02 VF750C Magna, 02 CBR1100XX Super Blackbird, 03 XR650L, 78 CB750k "Winter Project"
Offline Sandbag
Re: 1978 CB750K AKA winter project
« Reply #1 on: December 23, 2009, 04:13:02 PM »
I have been looking into tank sealers this is the one I am thinking about.
http://www.rustymetalpaint.com/Gas-Tank-Sealers_c_13.html
For the carb work I have talked to these guys & the seem to know what they are doing but I open for suggestions
http://www.cyclexchange.net/Carb%20System%20Comp%20Page.htm
traveler
« Reply #2 on: December 23, 2009, 04:19:08 PM »
What a neat bike! ;D
~Joe
Offline BeSeeingYou
« Reply #3 on: December 23, 2009, 09:16:16 PM »
Replace the piston seal in the caliper and make sure you clean out the groove that it sits in.  One reason the pads stick. The seals are cheap. They act to retract the pad and lose elasticity with age.
Offline Sandbag
« Reply #4 on: December 24, 2009, 10:06:39 AM »
Has someone posted a how to on this?
Offline Sandbag
« Reply #5 on: December 24, 2009, 10:09:45 AM »
The rear is now in pieces ???
Getting cleaned
Fresh coat of paint
And I think I need a new drill  :'(
Offline BeSeeingYou
« Reply #6 on: December 24, 2009, 11:20:28 AM »
It is the large O ring in the caliper.  Use a small screw driver or dental pick to pick it out.  Then use the same thing to clean the groove as junk builds up and causes the pads to stick.  Use care and don't go hog wild digging in there, no need to use force. ;)  The seal will probably look ok and probably does not leak but replace it anyway for the reason I mentioned earlier.
Offline Toxic
« Reply #7 on: December 24, 2009, 12:33:33 PM »
The seal is still available from Honda.  i paid 6 bucks for mine.
+1 on cleaning the groove out.  Make sure it is spotless.  I found Simple Green and a BRASS wire wheel on the Dremel did a great job of cleaning it out without damaging the groove.
traveler
« Reply #8 on: December 24, 2009, 01:12:36 PM »
I agree...even if the seal looks fine, it's already apart, so you might as well do it right....may never have to do it again.
Best time to restore the finish on the outside is now, before you put it back together, IMHO. ;)
~Joe
« Last Edit: December 24, 2009, 01:37:42 PM by traveler »
Offline Sandbag
« Reply #9 on: December 27, 2009, 10:07:27 AM »
I pulled the rear lower engine / foot peg bolt & is bent significantly.  I had to use a hammer to partially straighten the bolt / rod just to get it out.  I would like to replace it if I can find a suitable replacement if I can't straighten it.
Freshly painted battery box
Freshly painted swingarm
Offline Sandbag
« Reply #10 on: February 23, 2010, 09:45:30 AM »
Although my postings have not progressed my project has.  I decided to disassemble the seat clean the rust, weld the cracks, & repaint.  The seat looks good even though I almost lost my house... you see I had a portable propane heater running in my basement & unbeknown to me the vale on the gas tank was leaking.  I smell a strange smell & look down to see a 6-8" flame shooting out of the cylinder valve.  I did manage to get the fire out & THROUGH the cylinder outside  >:(.  I sent the carbs to be cleaned & that turned out to be an ordeal. But I eventually cleaned the carbs, cleaned & sealed the tank using the KBS system (NICE) & the bike is back together.  It even runs  :o. although not very well, when the ground dries enough i will take it to my local wrench & let him adjust the carbs.  I will post pics later.
Offline KB02
« Reply #11 on: February 24, 2010, 05:43:39 AM »
Can't wait to see the pics!
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
