Author Topic: Turns signals not blinking  (Read 2737 times)
Offline Sandbag
« on: December 24, 2009, 10:32:46 AM »
On my winter project 78 CB750K the turn signals will come on steady & I hear a buzzing sound but no blinkie  ???  While removing the battery tray to repaint I pulled all the electrical off & noticed someone has install a 2 terminal flasher & the green wire is left unhooked.
02 VF750C Magna, 02 CBR1100XX Super Blackbird, 03 XR650L, 78 CB750k "Winter Project"
Re: Turns signals not blinking
« Reply #1 on: December 24, 2009, 10:38:16 AM »
One common cause of a blinker steady on condition is the lack of a ground.
Offline Spanner 1
« Reply #2 on: December 24, 2009, 11:42:53 AM »
Normal....... the stock flasher relay is 2 wire that ground is not used in the stock blinker circuit. Have you looked at the bulb wattages?...also a slightly drained battery will not 'fire' the thermal ( stock ) relay, but should flash o.k. with a running bike. A lot of guys replace the old stocker with an electronic relay that flashes at a steady rate regardless of low or fully charged battery. Any AutoParts store should have one.....good luck, Merry Christmas!
Offline Hush
« Reply #3 on: December 24, 2009, 12:03:16 PM »
Yep all of what Spanner said and try earthing that green wire while the indicators are on, does it flash now?
Offline Johnie
« Reply #4 on: December 24, 2009, 12:10:47 PM »
A low battery could cause this too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline celebutante
    • my website, yay
« Reply #5 on: December 24, 2009, 03:36:12 PM »
Not sure about '78, but earlier 750's have an extra green unused ground. And I believe they all use only a two-wire blinker. Make sure all your bulbs are good. You may have a short someplace....
Offline Sandbag
« Reply #6 on: December 25, 2009, 08:53:37 PM »
I think Ya'll hit the nail on the head.  The battery is toast.  I was trying to charge the battery & after 12 hrs I tried all the lights horn ect.  But the battery would not take a charge, so with the head light & tail light on the charger probable didn't have enough juice to work the blinkers.  Trouble shooting is so much easier when you just ask.  ;D   Also at some point in time it looks like corrosion got the better of the main (15 amp) fuse holder & there was a terminal failure (pun intended) some one by passed the fuse holder & harness, & installed an inline 15 amp fuse using wire nuts (like you would see in your house) obviously I'm not going to leave this like this.  Are there original style fuse boxes available, or a common used alternative?  The other 2 positions look to be serviceable but not in great condition.
Offline Spanner 1
« Reply #7 on: December 25, 2009, 08:57:43 PM »
Glad you had success with the prob.... lots of guys have replaced the 3 stock fuse-holder with car type 'blade' fuses...do a search....
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #8 on: December 25, 2009, 09:21:10 PM »
"I hear a buzzing sound"
do you also have a signal buzzer still on the bike?   78?` May want to look around, because it may be hooped or need cleaning as well.
i know the old switch makes a noise too.......... ;)
