Author Topic: Building of a CB500 classic racer  (Read 209007 times)
Offline turboguzzi
Re: Building a CB500 classic racer
« Reply #100 on: February 14, 2010, 03:17:43 AM »
looking good rene
what is that exhaust pipe? look like a "flat" collector".....
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
« Reply #101 on: February 14, 2010, 03:39:39 AM »
looking good rene
It's indeed a flat collector.
« Last Edit: February 14, 2010, 03:42:13 AM by Howell »
You meet the nicest people on a Honda
Offline Howell
« Reply #102 on: February 14, 2010, 10:52:55 AM »
Surprise from our tuner , the engine is in da house  :)
« Last Edit: February 14, 2010, 12:00:42 PM by Howell »
« Reply #103 on: February 14, 2010, 11:37:49 AM »
Sweet. Man I've got butterflies.  ::)
Offline turboguzzi
« Reply #104 on: February 14, 2010, 10:08:43 PM »
wow, looks like it will be running soon!
beautiful!
just a few comments from my experience:
* most people racing 500's here, me included, use an external line to feed oil directly to the head, really recommend this. less oil leaks!
* I have the feeling that your inlet tracts are very long, I got very good torque with long inlet but it hurted a bit the top end, will be interesting to see how it works for you.
* I think your rider will appreciate fork brace? it will help a lot your rigidity,  ;)
are you planning a dyno run?
Cheers
TG
Offline Howell
« Reply #105 on: February 14, 2010, 10:36:04 PM »
beautiful!
Cheers
TG
Hi TG,
Yes indeed the inlet tracts are long , but we go on the Dyno and will see the result , it 's easy to shorten them.
Our friend with the no.46 Honda has two raceseasons experience without an external oil line without any problem and also don't use a forkbrace.
So our engine is the same way build up.
Do you have a picture of that oil line how it is installed , I am curious about it.
It depends of the circuittest if we must use a fork brace.
« Last Edit: February 14, 2010, 10:40:42 PM by Howell »
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #106 on: February 14, 2010, 11:06:03 PM »
beautiful!
Cheers
TG
Hi TG,
here's how i ran mine:
i tapped one of the main gallery plugs for the feed. the head has alu plugs where the oil passages were line bored.. these are easy to remove, and you only need to tap the resulting hole. i used a banjo fitting to get a clean angle away from the head.. don't know what others have used. blocking the stock passageways is easy as well. i used set screws with red loctite to hold them in. i also filled the inside (pressure side) of the stock oil jet with RTV sealant in case any oil makes it past the bottom set screw.
you need to remember to restrict the lines or you will lose pressure to the bottom end.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Howell
« Reply #107 on: February 14, 2010, 11:20:20 PM »
beautiful!
Cheers
TG
Hi TG,
Very nice done, but is it absolutely necessary .
Offline paulages
  • 1976 cb735
« Reply #108 on: February 14, 2010, 11:25:11 PM »
Don't get any leaks? Not neccesary... most leaks on these come from here though. It's the only pressurized point in the barrels.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline lordmoonpie
    • Moonpie
« Reply #109 on: February 15, 2010, 01:16:33 AM »
Do you get any top end oil starvation issues like the CB450 TG, if you don't do this? Very similar type modification on the CB450 for racing to ensure lots of oil gets up to the cam area or wear rates increase and race seizures are quite common.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Howell
« Reply #110 on: February 15, 2010, 02:23:39 AM »
In two raceseasons no leaks by the bike of my friend (no.46) and we use the oilpump of a CB650 and the oilpan (500cc more oil) also a oilcooler and an external oilfilter.
So more oil and pressure and cooler , practice will learn.
« Last Edit: February 15, 2010, 02:47:18 AM by Howell »
Offline turboguzzi
« Reply #111 on: February 15, 2010, 02:23:48 AM »
there are a few good reasons why to do it:
* No oil passing through the head gasket means you can use a copper gasket (better for heat transfer)
* no need to deal with those stupid o-rings
* oil going up to the head doesn't pick up more heat while passing trough the hot cylinder block - arrives cooler to the cam?
Sure, nothing is absolutely necessary, you can win races without it too....  ;)
if your engine is closed now you will have to wait for a rebuild though, you have to plug the oil galleries in the crankcase form the inside
Cheers
TG
Offline paulages
  • 1976 cb735
« Reply #112 on: February 15, 2010, 09:18:31 AM »
Cheers
TG
i plugged mine at the bottom of the passagway in the cylinder block...  ok, maybe not ideal because a leak could still spring at the base gaske, but it's worked for me.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline kos
    • m3racing.com
« Reply #113 on: February 15, 2010, 01:33:13 PM »
Beautiful looking engine! Can I ask what manifolds did you use to connect CR Specials into head? Custom built or sourced from another bike and modified?
KOS
220...221, whatever it takes.
Offline Howell
« Reply #114 on: February 15, 2010, 10:12:28 PM »
KOS
The alu manifolds are custom build and the rubber ones (29mm) are originally for the Honda minibikes , brand is Takegawa.
We had to make also new mount adaptors for the carbs because they are for the CB750 and as you can see they are longer then the original.
  • Moderator
« Reply #115 on: February 15, 2010, 10:36:20 PM »
You're up early Rene, can't sleep?  :D :D
Sam. ;)
Offline Howell
« Reply #116 on: February 16, 2010, 02:57:33 AM »
Sam. ;)
Hi Sam,
I sleep very well , but I start to " work " early at 06:30 (dutch time) at the office (ING Bank) but there is nothing to do at the moment at our department.(financial crisis you know)
Instead of working I read several forums on worktime.
On the 1 march my job at the office is done and I will be home from that date , because of a reorganization,  no more working just hobbying.
I get a very big amount of redemption money from my employer (ING Bank) also many colleges , enough for living till my pension at 65.
From that time I will not be so early on the internet.
I have received the money already and it is stored in my shed , no more banking. ;D
« Last Edit: February 16, 2010, 03:12:31 AM by Howell »
« Reply #117 on: February 16, 2010, 03:30:57 AM »
Oh nice Rene, congratulations, let us know how the full time hobbying goes!
I don't need to tell you there will be more space in that shed once you start racing that 500.  ;)
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #118 on: February 16, 2010, 04:13:31 AM »
Did they pay you in US$ then??
 ;D
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Howell
« Reply #119 on: February 16, 2010, 04:35:28 AM »
From the 1 march I have already a new boss , my wife.
She has already many projects for me , such as doing the household ,cooking , shopping , repainting the house inside etc.
The interest of that amount must be enough for racing  ;)
  • Moderator
« Reply #120 on: February 16, 2010, 06:56:11 AM »
Sam. ;)
Hi Sam,
All those notes are the old Zimbabwean $ ;D ;D ;D ;D  worth about £3.  :D :D :D :D :D
Sam. ;)
Offline Howell
« Reply #121 on: February 16, 2010, 12:59:26 PM »
Sam. ;)
Hi Sam,
Sam. ;)
#$%*, I will have a good look at it.
They told me that it are euro's , so my own employer ING bank cheated me. :-[
Now I know why we have a financial crisis and I have also now a financial crisis. ;)
Offline westondc
  • Wes Mantooth
« Reply #122 on: February 16, 2010, 01:48:28 PM »
oh now this is a cool build that I will be keeping tabs on!
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline Howell
« Reply #123 on: February 17, 2010, 02:01:45 AM »
Yesterday I received the power supply from Hongkong bought on Ebay for the electronic ignition.
Includes  two Lipo batterys and a charger.
Much less weight than a normal battery.(346g)
The power of one Lipo battery is 14,8 V and 4 Amp enough for our ignition and coils.
We gonna use two of them while one is in use the other can be charged.
« Last Edit: February 17, 2010, 02:08:54 AM by Howell »
    • TVAM
« Reply #124 on: February 17, 2010, 08:12:12 AM »
OK. The pink and blue ones could be € but the big pile of greenbacks is surely $$$
SOHC4 Member #2393
2015 Tiger 800 XRT
