Author Topic: Building of a CB500 classic racer  (Read 204163 times)
0 Members and 9 Guests are viewing this topic.
  • Moderator
Re: Building of a CB500 classic racer
« Reply #675 on: May 23, 2012, 01:26:20 pm »
Well done Rene and Yrjo, it had to happen, all the hard work and disapointments paid off in the end, it was just a matter of time. 8) 8) 8) 8) 8) 8) 8)
Was John Cronshaw in that race on a Gold Star or was it just one of his bikes?
Sam. ;)
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
« Reply #676 on: May 24, 2012, 12:48:02 pm »
Sam. ;)
Thanks Sam,
No it's not John Cronshaw but two very fast Dutch riders on a ABSAF (dutch BSA)
You meet the nicest people on a Honda
Offline Howell
« Reply #677 on: May 30, 2012, 11:52:34 am »
Bad luck last two races:
At Whitsun  we had two races , Yrjo was 5th on the startgrid.
Race 1:
During the warmup lap the bike wouldn't shift well into third and fifth gear.
With a bad shifting bike Yrjo finished on 5th place.
After the race I split the engine to see what was wrong , I found a gearshiftfork which was a littke bit bend, so I replaced it.
Next day in the warming up practice everything worked well.
Race 2:
Yrjo made a good start and was on third place during 4 laps, but then he was passed and was on fouth place , till in the penultimate lap the clutchcable broke.
Yrjo told afterwards that he was fast enough to keep third place till he got problems with the third gear again.
So no finish this race.
I have to split the engine again and  check the gearbox .
« Last Edit: May 30, 2012, 11:55:22 am by Howell »
Offline turboguzzi
« Reply #678 on: May 31, 2012, 10:28:41 pm »
renee .....
are you using K1-K2 cases and gearbox? would go for K3 that has already the "550" box (if they were sold in NL) or even complete 550 cases and box if allowed.
guess your dogs must be undercut right?
Offline classic bike tuner
  • http://www.cmrch.nl/
    • cmrch.nl/
« Reply #679 on: June 01, 2012, 02:07:46 am »
we using the type  wich has the forks around the drum  [550 is not allowed]
using a 350 2cil gearbox  modified
gerrit
Offline turboguzzi
« Reply #680 on: June 01, 2012, 06:51:45 am »
dont know about holland but in italy there was such thing as a CB500K3 which had the 550 improved box....
http://www.cmsnl.com/honda-cb500k3-four-european-direct-sales_model14676/partslist/E16.html#results
so not allowed either?
Offline Lostboy Steve
« Reply #681 on: June 01, 2012, 10:11:11 am »
I know I'm a little late here, but how do those drums perform? I LOVE the way they look. Also I'm completely digging the leovinci can.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Howell
« Reply #682 on: June 01, 2012, 11:59:32 am »
gerrit
That's the answer.
« Last Edit: June 01, 2012, 12:02:54 pm by Howell »
    • cmrch.nl/
« Reply #683 on: June 01, 2012, 01:30:20 pm »
i once had a 500k3 for repair  its was imported from germany
actually its a 550 with 500 barrel and 500 stamped on the bloknr
Offline turboguzzi
« Reply #684 on: June 04, 2012, 02:33:47 am »
gerrit
That's the answer.
hi rene
not sure what are you showing us in the pictures.... that the problem was the undercut? or the reason you cant use a k3 box...?
Offline Howell
« Reply #685 on: June 04, 2012, 06:31:24 am »
gerrit
That's the answer.
hi rene
I was showing the 350K undercut gearbox w're using.
The problem was again a bend gear shift fork and some gears were slightly damaged.
We replaced the complete transmission with another 350K one , cheap to find on Ebay.
We used till now the outerclutch basket from a 650 with 61 teeth and a primary shaft with 26 teeth.
Now we have changed that for a 550 basket and primary shaft.(63-24)
We think the gearshift problems are caused by a to fast running of the transmission.
Next race we will find out if this works better.
Does a 550 transmission fit in 500 cases ?
Offline turboguzzi
« Reply #686 on: June 04, 2012, 07:27:47 am »
rene, the simple answer would be that it doesnt fit... but i think that bwaller managed to make it work, with a lot of work!
« Reply #687 on: June 04, 2012, 07:32:17 am »
I don't have both clusters in my hand, but imagine the 550 cluster would fit. The 550 uses a separate shaft for two of the shifter forks, only one fork on the drum. The shift mechanism behind the clutch is different as well.
But don't let that stop you Rene, where there's a will, there's a way! I hung the shift fork shaft on brackets from the upper case for my 6spd. The shifting mechanism surely could be made to work. Off the top of my head I don't remember if the lugs on the 550 cases are actually different from the 500 anyway.
Offline Howell
« Reply #688 on: June 24, 2012, 01:44:08 pm »
Again podium for Yrjo in Dahlemer Binz Germany.
First race : second place.
Second race very wet condtions 5 th place, Colin Stockdale on the podium ,third place.
« Reply #689 on: June 24, 2012, 02:28:36 pm »
Good news guys, seems like Yrjo likes this new chassis package.
Did you ever have time to look at the 550 gear clusters in the 500 cases?
  • Moderator
« Reply #690 on: June 24, 2012, 02:55:12 pm »
Well done Rene and Yrjo and well done Stockers on the hurried rebuilt bike. 8) 8) 8) keeping the SOHC4 flag flying. ;)
Sam. ;)
Offline Howell
« Reply #691 on: June 25, 2012, 01:03:52 pm »
It seems indeed now that we have the good package and next race we try the new Conti Attack CR racing tyres.
I have n't a 550 gear cluster but out tuner says it wont'fit.
    • cmrch.nl/
« Reply #692 on: June 25, 2012, 01:53:13 pm »
the gears and shafts fit the forks wont fit
need to remove the oil pump
im not shure if the 500 clutch wil fit
gerrit
Offline turboguzzi
« Reply #693 on: June 25, 2012, 02:29:24 pm »
congrats again!!
Offline Howell
« Reply #694 on: July 28, 2012, 02:05:06 pm »
Very bad crash from Yrjo at the Classic races in Chimay Belgium last sunday:
Yrjo made a terrible crash , Colin Stockdale (IOMTT9) saw it happen.
On second place behind Steve Elliot in the third lap he touched a strawbale in a very fast right corner ( fullspeed in 4th gear) with his right leg and then he couldn't hold the bike and then made a frontal crash on the left side of the track in a tyre wall.
He broke his right hip,his left flintbone and his ankle wich is an open fracture.
The fractures are all very complicated,he is directly operated in the Chimay hospital.
Thursday he is tansported to the university hospital in Anwerpen for further examination.
Yrjo is still in the hospital in Belgium - Antwerpen , first he was at the local hospital in Chimay were the races were.
His ankle and hip are very serious fractures,
There is a big chance he will stay handicapped.
We hope that he will transported to Holland next week , where he can work on his recovery in a rehabilitation center.
When he may leave the bed , he has to sit for three month in an wheelchair and then work on his rehalibitation.
He is fit and strong , so we hope that his recovery turns out  the good way.
Racing is forever finished for us both , I will never go trough this again.
regards René
The bike is very heavy damaged , the frame is broken behind the stearing head.
Here some pictures , first pic when everything was still ok , on 2d place on the starting grid.
« Last Edit: July 28, 2012, 11:23:17 pm by Howell »
Offline turboguzzi
« Reply #695 on: July 28, 2012, 02:32:01 pm »
That's really really bad to hear,
Yrjo, i am holding my fingers crossed for you, wishing that you can go back to be as much normal as possible, as soon as possible.
I am suffering now the effects of a road crash related fracture/infection that went bad in my left foot which is limiting me from running and such, so can only imagine what is it to be in your condition.
Be strong, we are all glad that you are with us in the first place after such a big one
TG
« Reply #696 on: July 28, 2012, 03:00:00 pm »
Oh man I'm sorry to hear this news too.  Nothing but good thoughts for you Yrjo.
You're right though Rene, he's a young strong guy in great shape so hopefully this will help him in his recovery.
I hope you get him home to Holland soon, good luck. Please keep us up to date Rene.
Offline Doctor_D
« Reply #697 on: July 28, 2012, 05:00:33 pm »
I don't know what to say other than my thoughts are with you and your family.
Take care,
David
1978 CX500
1971 Norton Commando
« Reply #698 on: July 28, 2012, 06:59:11 pm »
+1
« Reply #699 on: July 28, 2012, 07:05:39 pm »
Very sad news, Rene. Let us know if there is anything we can do to help.
