Author Topic: so i've got my back wheel off...  (Read 986 times)
Offline domer
« on: December 25, 2009, 09:31:35 PM »
for paint and polish mostly, but since its off is there anything i should check for? chain is new, wheel bearings are new, tires are new, sprocket is good... anything else i should be looking for??? thanks! oh ya 73 cb500
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: so i've got my back wheel off...
« Reply #1 on: December 25, 2009, 10:20:26 PM »
check the brake shoes and the drum condition.
I've had the stopping material separate from the aluminum backer on one end of the shoe.
Offline gane
  • Gane
« Reply #2 on: December 26, 2009, 11:36:26 AM »
Rim for true, spokes for frozen/ uniform tightness, rust build-up/pitting. center spacer for presence & tauntness, cush drive to hub spacer for presence. shoes for lining/cracks. brake cam for clean/lube/wear.brake panel for proper bolt/washers/nut cotter. stay arm for same.
