Author Topic: Frankenstein Elvis shift knob installed  (Read 7537 times)
Offline Tim in Ohio
  • So I got that goin' for me, which is nice.
« on: December 26, 2009, 10:28:21 AM »
I​ have​ a​ 1989​ P.O.S.​ Dodge​ Spirit​ that​ I​ am​ going​ to​ have​ some​ fun​ Kustomizing.​  First​ step​ is​ changing​ the​ stock​ shifter​ knob​ out​ in​ favor​ of​ a​ kustom​ Jimmy​ Flintstone​ 'Frankee​ Stien'​ shifter​ knob:
These​ knobs​ come​ unpainted,​ and​ require​ some​ effort​ to​ install,​ because​ they​​ are​ not​ tapped​ with​ threads​ for​ attaching​ to​ the​ shifter.​  In​ my​ case,​ the​ problem​ is​ further​ compounded​ by​ the​ fact​ that​ my​ car​ has​ an​ automatic​ transmission​ with​ "positive​ lockout"​ in​ Park​ and​ Neutral,​ meaning​ that​ in​ order​ to​ shift​ in​ or​ out​ of​ Park​ or​ Neutral,​ a​ button​ on​ the​ stock​ shift​ knob​ must​ be​ depressed.​  Clearly​ Frankee​ has​ no​ button...​ so​ some​ ingenuity​ is​ required.
« Last Edit: February 14, 2010, 02:41:10 PM by Tim in Ohio »
1973 Honda CB350  Four
Check out my CB350F resto project...  watch a complete moron build a bike in front of your very eyes!: http://forums.sohc4.net/index.php?topic=38903.0
Offline Tim in Ohio
Re: Installing a Kustom shift knob on my 1989 Dodge Spirit
« Reply #1 on: December 26, 2009, 10:34:40 AM »
My​ stock​ shift​ knob/gear​ shift​ setup:
Gearshift​ with​ stock​ knob​ removed:
The​ "button"​ mechanism​ is​ actually​ attached​ to​ a​ long,​ slender​ plastic​ rod​ that​ extends​ down​ inside​ the​ hollow​ shaft​ of​ the​ gearshift.​  The​ bottom​ of​ the​ rod​ has​ an​ upside​ down​ "u"​ shaped​ piece​ that​ engages​ the​ "positive​ lockout"​ switch​ down​ below​ the​ PRNDL​ console:
About​ halfway​ down​ the​ slender​ plastic​ rod​ is​ a​ sphere​ shaped​ knurl​ that​ is​ approx​ 9mm​ in​ diameter...​ just​ the​ right​ size​ to​ slip​ down​ into​ the​ inner​ shaft​ of​ the​ gearshift.​  This​ little​ knurl​ keeps​ the​ "u"​ shaped​ end​ piece​ centered​ in​ the​ shaft​ so​ it​ will​ be​ in​ the​ right​ position​ to​ engage​ the​ "positive​ lockout"​ switch​ and​ allow​ shifting​ into​ Park​ or​ Neutral:
Offline Tim in Ohio
« Reply #2 on: December 26, 2009, 10:39:24 AM »
Here​ is​ a​ shot​ down​ inside​ the​ shaft.​  You​ can​ barely​ makeout​ the​ little​ wire​ deep​ inside​ that​ serves​ as​ the​ "positive​ lockout"​ switch​ mechanism.​  This​ is​ what​ the​ "u"​ shape​ engages​ when​ the​ button​ is​ depressed:
In​ order​ to​ install​ the​ Frankee​ knob​ and​ have​ it​ work​ properly​ and​ look​ good,​ I​ will​ need​ to​ solve​ a couple of​ problems:
A)​ I need​ to​ have​ an​ 'extension​ sleeve'​ fabricated​ to​ fasten​ to​ the​ existing​ base​ of​ the​ shifter​ (the​ part​ left​ after​ the​ stock​ knob​ was​ removed.)​  OR-​ I​ suppose​ that​ I​ could​ purchase​ an​ aftermarket​ shifter​ for​ Auto​ transmissions​ from​ someplace​ like​ Lokar...​ I've​ never​ installed​ one​ of​ those,​ so​ not​ sure​ if​ that​ would​ be​ a​ quick/easy​ solution...​ OR​ a​ tricky​ operation.​  If​ you've​ installed​ one...​ please​ pipe​ in​ with​ your​ opinion!
B)​  If​ I​ go​ the​ 'extension​ sleeve'​ fabrication​ route...​ I'll​ need​ to​ somehow​ figure​ out​ how​ to​ incorporate​ the​ inner​ rod​ shown​ above​ in​ order​ to​ engage​ the​ "positive​ lockout"​ switch​ when​ needed.​  Obviously,​ with​ the​ design​ of​ the​ Frankee​ head,​ a​ "button"​ is​ out...​ so​ prolly​ need​ to​ somehow​ work​ it​ so​ that​ the​ Frankee​ Head​ is​ threaded​ directly​ onto​ the​ extension​ sleeve​ and​ that​ whole​ extension​ assembly​ is​ somehow​ pushed​ down​ in​ order​ to​ engage​ the​ positive​ lockout​ switch.​   Have​ I​ lost​ you​ yet?​
« Last Edit: December 26, 2009, 11:21:49 AM by Tim in Ohio »
Offline Tim in Ohio
« Reply #3 on: December 26, 2009, 10:47:22 AM »
Dimensions​ of​ the​ shifter:
inner​ shaft​  1/2":
 "Extension​ sleeve"​ would​ would​ want​ to​ have​ an​ OD​ to​ match​ the​ existing​ shifter​ base:​  5/8"
I guess based on those dimensions we would be looking at a piece of steel tube with an OD of 5/8" and a thickness of 1/8".
Since the Frankee head is not tapped yet...  the threading on the end of the steel tube could prolly be about any standard thread per inch count/diameter/pitch.
I​ have​ a​ friend​ at​ work​ whose​ husband​ is​ an​ expert​ machinist...​ hoping​ to​ get​ his​ ideas​ on​ what​ to​ do​ with​ this​ tricky​ little​ project.​  Justin...​ whattaya​ think?
Also,​ if​ I​ get​ it​ fabricated,​ I​ understand​ that​ a​ choice​ would​ need​ to​ be​ made​ regarding​ what​ type​ of​ metal:  beats​ me...​ I​ heard​ there​ is​ something​ called​ "#$%*tymetal"...​ if​ there​ has​ ever​ been​ a​ car​ that​ would​ be​ appropriate​ for​ trimming​ in​ "#$%*tymetal"​ this​ is​ prolly​ it...​   ;)
« Last Edit: December 26, 2009, 11:27:41 AM by Tim in Ohio »
Offline Tim in Ohio
« Reply #4 on: December 26, 2009, 10:49:35 AM »
I'm betting some of my old motorcycle building buddies could also be helpful with ideas...  whattaya think Spikey?  Scunny?  :)
Offline scunny
  • don't call me expert
« Reply #5 on: December 28, 2009, 10:48:46 AM »
how about installing the lockout on the dash. I presume it is just a lever on the gearbox ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline ColinMc
  • There aint no pickle like a super pickle...
« Reply #6 on: December 28, 2009, 10:58:13 AM »
Could you make it so you just push down on the shift knob itself in order to shift...so the whole knob itself is the lockout switch?
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline Tim in Ohio
« Reply #7 on: December 28, 2009, 11:18:27 AM »
Hey Scunny.  Thanks for stopping by.   Yeah, I think what you are saying is possible.  It would require me to remove the console, and dig a little deeper into the guts than I was hoping for, but hey... I've jumped in over my head before... remember?  ;)
Colin Mc:  Thanks for your input.  What you are suggesting is kinda what I had in mind.   Maybe attach a long rod to the knob and rig up some sort of retaining hardware on top of the shifter that would limit the travel of how deep the knob could be depressed as well as hold it in place so as to not fall off the shifter when I'm just rolling along.   Hey... come to think of it...  pretty much just do exactly what the stock one did, but look cooler!   :)
Offline Tim in Ohio
« Reply #8 on: January 03, 2010, 02:05:56 PM »
Shift knob conversion still on the drawing board...   in the meantime here are some pics of my Kustomizing project.   Decoupaging door panels and dash, etc with images of pin-up girls, frankenstein, tiki-stuff, zombie head, hot rod/Kustom Kulture type stuff.
Passenger door in progress:
Offline Zaipai
    • My Home page
« Reply #9 on: January 03, 2010, 03:58:20 PM »
Wow that sure is different. I guess I hold off on a thumbs up or down until I see the final results.
Its my Avatar..
75 CB550F  |
Offline Tim in Ohio
« Reply #10 on: January 03, 2010, 04:15:06 PM »
Thanks Zaipai.  I think 'different' is a fair statement  :D
Listen, I KNOW this isn't for everyone.   My wife thinks I'm crazy for doing this.   Before the car was given to me, I think the highest offer my grandma had for it was $300!  So, no real worries about 'ruining' it.   Not to mention.  Have you checked out out the interior of an '80s car lately?  I'm choosing fun, funky and unique over the 1980s blah look.  Remember Ted's tux from 'Something About Mary'?  "The guy said it's tan and taupe..."   :o
« Last Edit: January 03, 2010, 07:52:45 PM by Tim in Ohio »
Offline Zaipai
    • My Home page
« Reply #11 on: January 03, 2010, 04:24:56 PM »
Listen, I KNOW this isn't for everyone.   My wife thinks I'm crazy for doing this.   Before the car was given to me, I think the highest offer my grandma had for it was $300!  So, no real worries about 'ruining' it.   Not to mention.  Have you checkout out the interior of an '80s car lately?  I'm choosing fun, funky and unique over the 1980s blah look.  Remember Ted's tux from 'Something About Mary'?  "The guy said it's tan and taupe..."   :o
Very valid points.. Some of the sickest (in a good way) cars I have ever seen have been ones where the owner thought out of the box.. so go nuts, but keep the pic's coming..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Tim in Ohio
Re: Funky Kustom 1989 Dodge Spirit
« Reply #12 on: January 09, 2010, 03:58:10 PM »
OK.  Fresh off the drawing board... here is my rough design concept for how to deal with the shifter fabrication:
Drop in with your two cents.  There are two issues not addressed by the design:
1) The whole thing just sits on top of the existing base with nothing holding it in place.  If you were to grab the shifter and pull upwards... the whole thing would come right off!   Do you have any ideas how to deal with that?
2) Similar to above, there really isn't anything that would keep the whole shifter assembly from spinning around on the existing base.  I thought maybe I could deal with this by superglueing or welding some sort of little ridge to the inside of the tube that would be positioned in that "groove" in the top part of the existing base.
What do you think?
Offline Zaipai
    • My Home page
« Reply #13 on: January 09, 2010, 04:12:15 PM »
This maybe a dumb idea, but can you drill a hole all the way thru and use a carter pin to hold it all together and also keep it from spinning?
Its my Avatar..
75 CB550F  |
Offline Tim in Ohio
« Reply #14 on: January 20, 2010, 06:39:06 AM »
New Discoveries!   I decided to put my fears aside and 'dig in' a little deeper on the shifter.  Turns out that the PRND12 panel is nothing more than a trim piece that pulls right out if you have the guts to start yanking on it!   Also-  that "wider" part of the shaft that I was calling the "base" is nothing more than a plastic sleeve that also pulls off.  So my tube will NOT have to be big enough to go over the "base" just big enough to slide over the .503 in shaft.   I have attached a pic and video clip below to show how the "Positive Lockout" feature works.  Just like in the Wizard of Oz, when you look behind the curtain, and see the little old man... it ain't all that impressive.   Turns out that "Positive Lockout" is a piece of plastic that is shaped to hang up in some notches and prevent the shifter from moving.  When you push down, a spring is compressed and the plastic piece moves out of the way.  Also, I should have realized this before... that compression spring that is already there makes it unnecessary to add any springs to the design of the kustom shaft that i am getting fabricated!  It will automatically push everything back up, just as it currently pushes the existing button back up with the stock setup.
« Last Edit: January 20, 2010, 06:41:42 AM by Tim in Ohio »
Offline ColinMc
« Reply #15 on: January 20, 2010, 06:47:19 AM »
What about disabling that mechanism...so you don't have to push down on anything? Or would the shifter not stop in each of the notches at all then?
Offline Alan F.
« Reply #16 on: January 20, 2010, 06:30:02 PM »
a good tip is to find a similar model car in a junkyard, you can disassemble anything you want and just walk away, you'll learn quite a bit that way.
-A
Offline Tim in Ohio
« Reply #17 on: January 21, 2010, 05:52:29 PM »
Good thinking Alan.  I'll have to try that in the future.
Colin- I don't want to disable the lockout.  I'd hate to be driving along at speed and have some sort of freak thing happen where the shifter gets bumped and thrown into reverse...  sounds like instant transmission self destruct.
Offline Tim in Ohio
Frankenstein Elvis Shifter Knob
« Reply #18 on: February 14, 2010, 02:40:32 PM »
Finally got the Frankenstein Elvis shifter knob installed.  It works and looks great! (i think  ;D):
Offline Achmed
Re: Frankenstein Elvis shift knob installed
« Reply #19 on: February 14, 2010, 05:07:56 PM »
Nice documenting of the project. Even if we don't want a Frankenstein knob, we can enjoy the ride! Thanks
Offline Zaipai
    • My Home page
« Reply #20 on: February 14, 2010, 07:06:28 PM »
Nice work. It looks freaking awesome!!!
Its my Avatar..
75 CB550F  |
« Reply #21 on: February 14, 2010, 09:50:58 PM »
I dare ya to take Grandma for lunch... ;D
 ya probably owe her anyway...
