Author Topic: Removing Rust on Headers (Stupid Question)  (Read 1992 times)
Offline Montgomery
    • 100 Low Life: Tales from Reid Hillview Airport
« on: December 29, 2009, 07:54:03 PM »
Hey All-
Kind of dumb question here. There's a ton of rust on the headers of my '71 CB500. I figured I'd go at them with a wire wheel on a bench grinder initially. I've read the clearcoating vs. polishing debates on the forum for aluminum parts, but what are the options for steel? Is there hi-temp clearcoat, to keep the headers from rusting again, or is the only option to have them chromed?
1971 CB500
Offline dewjantim
Re: Removing Rust on Headers (Stupid Question)
« Reply #1 on: December 29, 2009, 08:23:28 PM »
A lot of the rust will clean up with a wire wheel. Mine were quite rusty and I used a drill with a light bristle wire wheel which cleaned them up like new. The chrome has that brushed look to it which I really like. To keep them looking nice, wipe them down with a little WD40 about once a week. If you don't go this route you might try either sanding then polishing the pipes and clear high-temp powder-coating or simply sand or particle blast the pipes and have them powdercoated with high-temp chrome powder-coat. Either way it would be cheaper than re-chroming..... :) :) :)...
Offline GammaFlat
« Reply #2 on: December 29, 2009, 09:15:32 PM »
Crumple up some tin foil.  Rub it on your "affected area".  It works nice.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Hinomaru
« Reply #3 on: December 29, 2009, 10:03:04 PM »
Hey All-
Consider having your headers high heat ceramic coated inside and out as it's a long lasting and durable finish. Perhaps there is someone in your area that provides this service? If not, these are the top three companies that I'm aware of with a good reputation:
http://www.performancecoatings.com/headercoatings.html
http://www.jet-hot.com/headercoatings.html
http://www.hpcoatings.com.au/pages/hipercoat.htm
Offline Montgomery
« Reply #4 on: December 29, 2009, 11:18:22 PM »
Thank you for all the responses!
Does the tinfoil really keep the rust from re-forming, or is it just a method to remove it?
If I'm honest, the exhaust is complete crap, so I'm not sure about spending the money to have it powdercoated. Being a recent college grad and trying to save money to become a commercial pilot means I am extraordinarily cheap. Buuuuut, powdercoating is certainly cheaper than a whole new exhaust.
1971 CB500
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: December 30, 2009, 12:05:39 AM »
Get rid of the rust and then just spray the headers with some black grill paint.  Touch it up as needed, and save your money for a set that's worth spending it on.
Offline mgbgt89
« Reply #6 on: December 30, 2009, 07:07:15 AM »
My header looked like crap on my 350.. I tried the aluminum foil on it and it was amazing how well it works.. I didn't even know there was chrome still under the rust. My arm felt like it was going to fall off after i was done, but it looks 20 times better than it did.
Offline domer
« Reply #7 on: December 30, 2009, 08:24:27 AM »
little bit of sandpaper, and rattle can it... my kerker was chrome at some point in its life. when i got it the header was a rusty brown and the can  was missing half the paint. i think someone tried to paint it black at some point but it wasnt black anymore... i used krylon's bbq paint. has a nice semi-gloss to it (rustoleum is flat) but the first 3-4 inches of header coming out the block turned flat. holds up fairly well for rattle can, and touchs up easy when needed...
Offline Montgomery
« Reply #8 on: December 30, 2009, 09:16:51 AM »
Hmmm, the BBQ paint is more my budget!
Anybody have any pictures of what the stock 4-4 exhaust looks like painted?
1971 CB500
CB750Winger
« Reply #9 on: December 30, 2009, 09:35:29 AM »
  I have a black 4 - 1 header along with a chrome 4 - 2. I painted my black 4 - 1 with grill paint from Lowe's and looks like new. I just hit it with steel wool to prep it and a couple cans of grill paint for around $6, pretty cheap fix. I'll second the wire wheel for chrome. Alum foil works too.
