Author Topic: CB550K Cush Drive removal tool~HELP!  (Read 1448 times)
traveler
« on: December 31, 2009, 11:43:03 PM »
I hope someone can help!
When I read about dissassembly of the rear wheel, it states that a special "Cush Drive removal tool" is used on lef thanded threads.
Okay...so whre do I get this tool...or better yet, how do I disassemble and later re-assemble without buying a tool I use one time?
Worst case, I take it to the service department at the dealer....if they even know how to do it!
Also, do they make sealed bearings I can put in the rear wheel, so I don't have to deal with repacking?
Thanks,
~Joe
« Last Edit: January 08, 2010, 08:29:30 AM by traveler »
Re: CB550K Cush Drive removal tool~HELP!
« Reply #1 on: January 02, 2010, 08:42:38 PM »
You can make a retainer removal tool, but make it substantial as these can be difficult sometimes. Lightly drill the punch marks & remember left hand thread.
An older dealer probably has the original tool, and probably better looking than this one!
traveler
« Reply #2 on: January 02, 2010, 09:48:13 PM »
....I had a feeling I was going to have to make a tool....DAMN! >:(
~Joe
traveler
« Reply #3 on: January 08, 2010, 08:30:20 AM »
The rounded corners on that nut tell a story of agony and reefing to get it loose!
~Joe
« Reply #4 on: January 08, 2010, 05:26:50 PM »
Yes there was one 550 retainer that would not come off. I used an air wrench and tried everything under the sun on it.  Could get it to move but was a lost cause.
Most are easy to get along with, but every once in a while.....
That's why I suggest if you build a tool, make it beefy.  ;)
