Author Topic: CB750 K0 Carb Choke Question with Pictures  (Read 3045 times)
Offline Simpson
  • I ain't no
  • Aged to perfection
« on: January 01, 2010, 01:40:49 PM »
Adjusting my K0 carb choke today I noticed some don't retract all the way up. Will this create an issue?
How do you adjust it out, I can't seem to fix it?
« Last Edit: January 01, 2010, 02:11:51 PM by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
Re: CB750 Carb Question with Pictures
« Reply #1 on: January 01, 2010, 01:41:37 PM »
More pics
1970 CB750 K0
1975 CL/CB 360 Mix
Offline 750goes
  • it will live
Re: CB750 Carb Choke Question with Pictures
« Reply #2 on: January 01, 2010, 01:47:55 PM »
Where the choke linkages are held together - you may need to make a single turn on one of them to get it to retract fully - a bit like a turnbuckle---- but it probably won't make very much difference that you would notice IMO.
Offline Simpson
  • I ain't no
Re: CB750 K0 Carb Choke Question with Pictures
« Reply #3 on: January 01, 2010, 03:16:06 PM »
When you adjust them to close fully, you can't adjust them open fully.
Maybe it doesn't matter they can't open fully.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Johnie
« Reply #4 on: January 01, 2010, 05:06:15 PM »
You want to be sure they close fully when you need the choke on. That little bit you show open is not a problem. Just be sure you can close them all the way on start up.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Simpson
  • I ain't no
« Reply #5 on: January 01, 2010, 05:57:40 PM »
That's what I suspected. Actually I just put them back in the bike as you described. Thanks Johnie!
1970 CB750 K0
1975 CL/CB 360 Mix
