Author Topic: What oil do you use in your race bikes?  (Read 5580 times)
Offline JIMLARCH
« on: January 01, 2010, 06:30:37 PM »
I just use Castrol 10w-40 and change it after every race meeting.  What do the rest of you use?
Offline lordmoonpie
    • Moonpie
Re: What oil do you use in your race bikes?
« Reply #1 on: January 02, 2010, 02:47:51 AM »
I can't believe no-one has broken out the comfy chairs, beer and the popcorn on this one yet...  ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline ryder60
« Reply #2 on: January 02, 2010, 02:56:30 PM »
I just use cheap old Canadian Tire 20-50 or 10-40 in combo.  I change it and filter every 2 races which is usually less than one hour total.  It's a stock motor and I don't stress it above its redline.
Offline gene03079
« Reply #3 on: January 02, 2010, 04:53:35 PM »
I use the stuff in the blue bottle. If the motor lasts the whole race I change the oil.
78 CB550 74 CB550  71 SL175  08 Harley Ultra
Honda CL 175 racer  1977 Honda MT125R race bike 65 CB160  69 SL350
« Reply #4 on: January 02, 2010, 05:51:37 PM »
Judging by the condition of your parts Gene you need a genie in the bottle. ;) ;) ;D
Offline voxonda
« Reply #5 on: January 03, 2010, 01:30:01 AM »
When equipped with the dry clutch I intend to go full synthetic Motul.
Rob
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: January 03, 2010, 08:59:57 AM »
Golden Spectro 10/40 or 20/50 and BG EPC (loaded w/zinc dithiophosphate)extreme pressure additive.,Bill
BentON Racing Website
BentON Racing Facebook
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #7 on: January 03, 2010, 10:56:42 AM »
anyone using amsoil?  i have a friend that swears by it in his duc and old honda in his classes...  he's also sponsored by them
« Reply #8 on: January 03, 2010, 11:29:20 AM »
I have had good luck with Pennzoil, but  I usually ran straight weight, harder to get now.
 I never rev really high or run reall hard till it gets warmed up.
 ryder 60, I cant wait to see your cam chain rollers & slider if you are running CT Gold... :o
Offline Steel Dragon Performance
    • Steel Dragon Performance
« Reply #9 on: January 03, 2010, 04:09:02 PM »
Back in the day I use to use Castrol for drag racing and I never had problems with it. We used a little heavier 20w-50 for drag racing.
Offline ryder60
« Reply #10 on: January 06, 2010, 08:38:31 PM »
CT motorcycle oil.
fly_ricky
« Reply #11 on: January 06, 2010, 10:16:14 PM »
Just the regular ol' Castrol designed for car motors? Or do they have a moto-specific blend? My newly aquired cb550 needs to be treated to what works best  ;).
Anyone here run the Rotella T (syn or non-syn?) I run the syn (blue bottle) in my 03 Z1000 (36k) and it works awesome.....and I run that bike pretty hard.
  • Moderator
« Reply #12 on: January 06, 2010, 11:05:55 PM »
You can say that again Murphy ;D ;D ;D nice meeting you Gene ;) how's that little motor coming along ?
Sam. ;)
Offline gene03079
« Reply #13 on: January 10, 2010, 05:53:41 AM »
Hello Sam
Mike is coming along with the head. We did locate some replacement cylinders to go with the pistons we have. For now just waiting on a gasket kit to arrive and some other small bits and then it can go back together.
The past few years running the Repsol full synthetic may have helped keep me racing. I think the oil did its job well. My motor failures look to be a case of way to aggressive downshifting and flat out over revving.
I think I will keep a better eye on the tachometer this year and save some money on motor rebuilds. I don't think any brand of oil would have kept that little motor together after what I put it through. More corner speed and less revving this year for me.
Gene
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #14 on: January 10, 2010, 01:03:30 PM »
When I was dragracing the turbo, I used the Kendal 20-50 - back when it was the formulation I believe is now cooked up by Brad Penn. The price was right and it worked well for me.
I would change it when shifting became sticky. Yes even with an air shifter you can tell a difference.
I continued to run this oil even while I worked on a racecar that was sponsored by a synthetic oil manufacturer, but today would be a different story.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline ryder60
« Reply #15 on: January 11, 2010, 07:54:53 PM »
Is there a clutch slipping problem with synthetic or automotive oils?
